Question about Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera
Date stamp I try to highlight the date stamp option in the startup menu but it skips right over the option. How do I get the date stamp to function?
  • 3boysmommy Jun 10, 2008
    Thanks so much for the quick solution!
  • 2,039 Answers
In order to use the date stamp option, the image size (L, M1, M2, M3, S, Postcard) has to be set to Postcard. Press the Func/Set button, scroll down to the image size icon (lower left corner), then scroll over to Postcard, and press the Func/Set button again.
Posted on Jun 10, 2008
I would like to turn the date stamp off... I do not like it in the pictures
Using the Capture Menu
The Capture Menu allows you to adjust camera settings that affect the characteristics
of the images and video clips you capture.
1. While in Live View or Playback, press , then use to highlight .
2. Use to highlight a menu option, then press to display the menu option's
sub-menu.
3. Use to highlight a setting, then press .
4. Press to exit the Capture Menu.
For on-camera information about an option, use to highlight Help... in the option's
sub-menu, then press .
In the capture menu goto
Date & Time Imprint Imprints date in lower left corner of image.
Off Default No date or time imprinted on the image. (this setting)
Date Only Date permanently imprinted.
Date & Time Date and time permanently imprinted.
this should fix your problem
Mar 18, 2014 | HP Photosmart M525 Digital Camera
How do you stamp date photos on the M580 easyshare camera
1. Press the Menu button.
2. If your camera displays a menu with tabs at the top:
a) Press the Right/Left buttons to highlight the Setup tab.
b) Press the Down button to highlight Date Stamp.
c) Press the OK button to add the date stamp to new pictures.
3. If your camera does not display a tabbed menu:
a) Press the Down button to highlight Date Stamp. NOTE: Depending on your model, Date Stamp might be within the Setup choice.
b) Press the OK button to add the Date Stamp to new pictures.
Apr 11, 2011 | Kodak EasyShare M530 Digital Camera
How do you date stamp pictures
Apr 11, 2011 | Kodak Easyshare M580 Digital Camera
How can I set up the camera to put a date stamp on each photo when it is taken?
Press the Menu button. Use cursor-up/down to highlight Setup and press OK. Use cursor-up/down to highlight "Date Stamp" and press OK. Choose an option and press OK. Press Menu to exit.
Mar 11, 2011 | Kodak Easyshare C813 Digital Camera
How to remove date stamp from screen?
In the lower left corner of the back of the camera just to the right of the LCD screen is a button marked "disp" by pressing the button it will change the different screen modes on should show only the picture without the numbers or writing on it.
Dec 26, 2010 | Canon PowerShot SX20 IS Digital Camera
Date stamp will not show on my camera
I found the solution o-line. All I had to do was switch the camera to the 'postcard' mode and instant presto, I was able to access the date stamp mode. I want to express my thanks to the (I don't remember who) person who posted the solution.
Jun 29, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Date stamp option in menu will not highlight to change it just skips past it change daye and time
For some cameras this option only works when the camera is set to a specific resolution. Some calle this resolution "Postcard" resolution, and is usually 1200 pixels width. Try setting your camera to its other resolutions to see if this ocrrects the problem. Suggest that you start with 1200 x 900 resolution. Keep in mind that this 1200 x 900 gives only 1 megapixel resolution. Most newer cameras are capable of taking much higher resolution pictures, so this may be a trade-off if you want to use the date stamp option.
May 10, 2009 | Cameras
Canon sd 750 how to put the date in the picture?
here is the solution:
The date and time can be included on the pictures taken only with the camera in postcard mode. You must also activate the date stamp option in the menu.
To set the camera into postcard mode, press the [Func.] button on the camera, then use the [arrow down] key to go down to the last option in the menu, and there you can choose the [Postcard mode]. Press [Func.] again to exit the function menu.
To set the date and time stamp, press the [Menu] button and then use the [arrow down] button to go to the [Date stamp] option in the menu. You can set this to "Date" or "Date & Time". Press the [Menu] button again to exit the menu.
dsc_include_date02_tcm14-520511.jpgyour date and time are set now
congratulations!
Rate this answer if it is working with you
thank you
with all my best regards
huetrichard@gmail.com
Feb 25, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Date/time stamp control in Menu won't allow access
In many cameras these settings depend on the shooting mode. Did you change the shooting mode? If so, return to your normal shooting mode and the function should be available again.
If this doesn't fix your problem I need to know if you have your camera's user manual. If I can find the solution in your user manual I need to know if you can read the steps in your own manual or if I need to provide you a link to read the manual online.
Jan 11, 2009 | Canon PowerShot A530 Digital Camera
Canon A540
The date will only show up on the picture under a limited set of circumstances on the Canon PowerShot digital cameras, of which the A540 is one. You've probably found the Date function in the menu, but discovered that it was off, grayed out, and skipped over whenever you tried to reset it.
Date stamp will only work in "Postcard" mode. Press the Function button (labeled "FUNC SET"), then press the down button until you reach the Recording Pixels selection (usually labeled "L", but not always). It's probably the bottom onscreen selection. Use the right or left buttons to select Postcard, then press the Function button again.
Press the Menu button and scroll down to Date Stamp. Now you should be able to select "Date" or "Date & Time" with the right or left button. Press Menu again and take your pictures.
Sep 29, 2008 | Canon PowerShot A540 Digital Camera
Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera Logo
437 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
