Monitor Ghosting My Product is an lcd monitor that's what threw me - it's an envision en7750 and is less than 2 years old. Am I now monitorless? Thanks Artp
  • Anonymous Nov 07, 2008
    Same problem here on a Samsung CRT and a change of cable did not help. The ghosted image is not faded, it has the same luminance and resolution as its counterpart and it is on the same horizontal plane or perhaps one pixel below. To me it looks as if a horizontal scan engine is having problems. Does anyone here know how and where Samsung does its horizontal image processing?
    Champion:
  • 220 Answers
You didn't descibe your problem.If you are seeing double image/ghost first try replacing signal cable.
Samir
Posted on Jun 12, 2008
Monitor went dark after working fine for some time
is the power light blinking or turned orange? If so, the power supply needs to be repaired. If not, the flourescent lamps are burned out.
Feb 24, 2014 | Envision En7750 17" Lcd Monitor - White...
I have a Envision monitor EN7750 and now I get a black screen that say (input not supported).
Sir,
This happens when you have set a resolution that's not compatible to your Envision EN7750.Have u used the same monitor before with your Pc successfully? If you have just bought it and have got another monitor which worked with your Pc then connect that monitor monitor again and change your display resolution to 1280x1024 (its the default resolution supported by EN7750) and then connected back your Envision Monitor and it should work.
If you need assistance on how to change display resolution,then let me know.Hope it helped.
Oct 28, 2010 | Computers & Internet
Screen ghosting & horizonal lines
ulrit, If no warranty, then you too, will need to contact Dell for cash+old unit swapout for refurbished unit or repair/refurbish the power-supply printed circuit board inside unit. Haven't you been to YOUTUBE to see DIY video clips on repair of lcd monitors??? You may even find one for your model among all the videos you can find there!!! Then remember to come back to fixya and do extensive reading and follow the links you find in the PROFILES of "louie12fix" "12fixlouie" "budmrtn" "buddymc".
I hope this response helps you understand problem and guides you to a "fix" for your unit. 12fixlouie Bye for now.
May 25, 2010 | Dell E176FP 17" LCD Monitor
The monitor is only 2 years old. less then 50
If you left it plugged into the outlet, the power supply is still running 24/7 even you never trun it on! Look inside for bad caps first, see example of failed SAMSUNG monitors: http://s807.photobucket.com/home/budm/allalbums
Jan 24, 2010 | Samsung SyncMaster 932GW LCD Monitor
Envision 19" Monitor is "ghosting" . It is about 3 years old. Just starting doing it. Nothing has really changed on my computer. Thanks for any help.
Try reseating the input cables. If that doesn't work then you could try a new input cable. Updating your video card drivers might also do the trick.
Sep 23, 2009 | Envision 19" Widescreen Flat Panel LCD...
Envision LCD monitor: ''Auto Config Please Wait'' is always on
Just tell me why this message comes up and if it means my monitor is going
Dec 21, 2008 | MPC Computers Envision EN 5100e 15" Flat...
Envision color monitor, Model EN910e
Hi..there! Barb,
It's seems you got a busted backlight inverter... Need to replaced a new one or repaired it. Have a nice day!
Oct 22, 2008 | Envision EN-7220 17" Flat Panel LCD...
Envision LCD EN-7100e Monitor "Input not supported
Either your display card is not supporting the LCD resolution.
Apr 23, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Envision EN 7100si LCD 17" flat screen
First try auto-adjust with the auto button on the screen
if not worked
Make sure she installed the envision driver. I jus saw it's a discontinued product. Also this product has a maximum resolution of 1280 x 1024.
If installed check her resolution. Right mouse click on desktop>properties>screen. Try alternate resolutions and see what happens but don't set it higher then 1280 x 1024 if possible.
Nov 28, 2007 | Envision EN-7100e 17" Flat Panel LCD...
Computers & Internet Logo
1,230 people viewed this question
David Payne
David Payne
