Question about 2wire 2700HG-B Router (2700HGB)
How do i sync windows vista with my router?
Im using the 2Wire 2700HG-B router and i have at&t dsl and im told i need to sync windows vista with my router how do i do this?
  • 144 Answers
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
if you are still having trouble configuring your device, try to call supportrix and use supportcall as your promo code for 1 free technical support.
Posted on Jun 11, 2008
Hot to make my gateway 2700hg-d modem/router
you just need to things for ATT your user name and password that you registered to them. Then you need to get inside the 2wire by using the IE or Mozilla. On the address bar, type in Inside you will see there setup then just follow the prompt but if you got lost on the process just call att dsl
Mar 07, 2010 | 2wire 2700HG-B Router (2700HGB)
It only supports WPA and WEP. If you need help setting it up, here is a great guide:
Good luck
Dec 28, 2009 | 2wire 2700HG-B Router (2700HGB)
The power went out last night and now the dsl box will not conect
Do a reset on your 2wire by pressing the reset button of it for 15 seconds while power is ON and then after that power it OFF for 10 seconds and then reconfigure your unit and check if its working already....
Dec 13, 2009 | 2wire 2700HG-B Router (2700HGB)
Connected io router with excelent signal but won't connect to internet , using Beklen adapter , happened overnight.Did work well before.
It sounds as though you are using both a belkin wireless router and the 2wire 2700HG-B Router.
Setting up 2 routers to work together can be tricky and unless there is some specific reason to do so I recommend you just use the 2wire router.
Oct 29, 2009 | 2wire 2700HG-B Router (2700HGB)
I received a new 2wire 2701HG-B modem router for AT&T DSL (replacing an older 2wire that burned out) and was able to hook up laptops right away no problem, but desktop doesnt recognize new modem how do...
are you on windows XP, Vista, MAC ???
you start out by seeing if you can ping the 2wire. The ip address you ping from a command prompt is the 2wire's gateway,
(you can get to the command prompt by clicking start, then click run, and type cmd and click ok on windows XP)
(on vista, you just click start and type cmd right above it where it says start search and hit enter on your keyboard)
(MAC's have a ping utility located by clicking on the harddrive, applications, network, network utility, and then the ping tab)
a little black window pops open, thats your command prompt
type ping and hit enter on your keyboard
if you dont get replies, then your computer doesn't see the 2wire.
call tech support at 877-722-3755 24/7 for further support if required. We can make sure you nic is config properly, working properly, your not being blocked by a firewall, etc.
Sep 13, 2009 | 2wire 2700HG-B Router (2700HGB)
2wire att dsl modem/router on vista
Connect your DSL to wireless router and enable automatic ip on wireless. check whether DHCP is enable in DSL router or not.
Apr 24, 2009 | 2wire 2700HG-B Router (2700HGB)
No connection for laptop
when your DSL goes red call the ISP you are having intermittent sync try powercycleing the router but call them up and ask for line test
Mar 28, 2009 | 2wire 2700HG-B Router (2700HGB)
Unable to connect 2 routers need help!
Do you have any funky subnets for your Cisco router? Do not connect the wireless router to your network yet, as it may have the same IP address as your other router.
Basically the easiest way to do this is to set a dedicated IP for the 2Wire router on the Cisoo router. Then make them stay on the same subnet, but give an IP range for your Cisco router, like 1-50 or something. If you give the 2Wire router IP .51 for instance, then give the Wifi users on the 2Wire IP range from .52-75 or something.
Make the 2Wire router only use wifi and not serve DHCP addresses. Then you setup the 2Wire router to get its info from the Cisco router.
I searched and there is no howto out there for doing this with a Cisco router. However, here is one I used to setup a similar scenario with a Netgear router. It worked. If you are able to translate a bit, it might work for you:,235,239&
Here is another article:,246,260&
Let me know if you are able to work through this. You need to give the 2wire router a static IP and you need to NOT use it for wired connections, and not use it to serve DHCP settings.
Jan 21, 2009 | 2wire 2700HG-B Router (2700HGB)
2700HG Can't Sync to DSL Signal
The gateway is made by 2Wire contact them for repair.
Sep 12, 2008 | 2wire 2700HG-B Router (2700HGB)
2wire 2700HG-S
you need to find instructions cos this router is also a modem/router, so if you already have a dsl modem, you will have to remove it as there will be conflicts.
The driver can be found here,427,969&p_faqid=8661
Aug 19, 2008 | 2wire 2700HG-B Router (2700HGB)
2wire 2700HG-B Router (2700HGB) Logo
90 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
