Question about GE Microwave Ovens
I have a GE Microwave/ Convection Oven (M# JVM1790BK01). I have trouble not burning cake products. Here is the set-up: 1. Using Comvention Bake with a metal pan. (As directed, size, rack setting, etc.) 2. "Auto Recipe Conversion" is ON. 3. I set the temp as per recipe. (On cake box) 4. I preheat as required. 5. I place cake into oven & cut the cook time about 50%. (From suggested cake box instructions) 6. At "Cook time-out", cake is not done. (Tooth-pick test) 7. I set the timer for another 10 minuets. 8. Cake burns before time out. (Top & bottom) Questions: 1. Is there a better way to judge cook time? 2. Is the temperature to high? 3. How can I control this cooking better. EM
  • GE Master
  • 5,568 Answers
I would check GE's website, they probably have a forum where you could get a better answer.
Posted on Jun 10, 2008
How to set degrees
Microwave ovens can't be used to bake cakes. One needs a regular convection oven to make things that rise.
Apr 24, 2014 | Microwave Ovens
Baking cakes and quiches
i use the micr-convention mode to bake and preheat it at 200 C ,the cake rises unevenly and falls unevenly .i open to check if the cake is done .why does it rise unevenly and why does it fall ?
Jul 18, 2012 | Microwave Ovens
I hv got a ifb microwave oven 23sci with grill , i have tried baking cakes many time and every time it gets burnt. The sides get baked and the central zone is unbaked. MY method is , I take a glass utensil...
You should be using convection mode first of all. It's not clear from your post if you are. Also looks like you're oven is baking at higher temperature than it says. Try 170 degrees for 13-14 mins instead.
Feb 28, 2011 | KitchenAid KHMC107BT Convection/Microwave...
I have an electrolux convection model. the manual does not have suffiencient information on how to bake a cake. could you please explain me the precedure interms of the power selection, time required,...
Firstly I would suggest contact Electrolux for more info.
But in general all cakes are baked and no microwave energies are used.
An oven timer is critical to avoid over-baking.
Nov 02, 2017 | Electrolux E30MO75HSS Microwave Oven
I have samsung CE103VD microwave.could you plz tell me what temperature n what time should i set to bake a cake on convection mode?
I too have the same problem i try to bake cake and it turns to become biscuit or it dosnt cook in the centre
Sep 17, 2010 | Samsung MT1066SS Convection/Microwave Oven
Cooking temp to bake cake inn convection mode samsung model
Hi I guess you are cooking usng the combination setting? if so The cake will be hard due to increased microwave energy, I would suggest reducing the microwave energy on the Samsung unit when using the combination setting.
Hope this helps
Jan 07, 2010 | KitchenAid KHMC107BT Convection/Microwave...
Bake
back in the 1980s and early 90s there were cake and cookie mixs designed for microw use, you would have to go to market and read lables to be sure
Dec 13, 2007 | Sharp R-220BW Microwave Oven
Open Questions:
GE Microwave JVM1441BH04: Safe to reconnect replacement stirrer & turntable motors after accidentally burning out the turntable motor? GE JVM1441BH04 Over Stove Microwave: Tapping noise was coming from the 21v AC stirrer motor which sits atop the cooking chamber. I disconnected the two connecting leads, unfastened the single screw holding it on, placed in on my scanner glass to get a high rez photo of all the specifics listed on the motor label. Bad news: While waiting for the scan to finish, I warmed my coffee in the microwave on the highest heat for 30 seconds. I subsequently discovered the 21v AC turntable motor, which had been working just fine, was now no longer working, with infinite resistance across its terminals, and a burnt electrical smell. Both the stirrer and turntable motors are powered by a 24v tap off the magnetron fan. My theory: By running the microwave with the stirrer motor out of the circuit, I delivered excessive voltage to the turntable motor, which quickly fried. The 24v tap off the magnetron fan motor currently shows the correct 24v output. However, with both the stirrer motor and turntable motor disconnected, running the microwave for a few seconds shows approx 95v across the wire leads for both of the 21v motors. I have obtained replacement motors for both the noisy stirrer motor and the fried turntable motor. My question: Can I simply reconnect both motors in their proper locations, vow never again to run one without the other connected, and all will be well? Or will the newly installed motors simply be fried in a matter of seconds?
Jan 04, 2018 | GE Microwave Ovens
Microwave Ovens Logo
291 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
