Question about Mitsubishi WS-55813 55" Rear Projection HDTV
Mits. 55" Model 55511
T.V. will not stay on. I had it on for 4 hrs, though I did have to push Reset button. Now it will either not turn on, or will onl do so for a few seconds; usually about 5-10 seconds. Could this be th power supply? When we 1st got it, 2nd hand it did not work...but the price was right, $75.00; so I am trying to figure out what could be the problem and find out how much it could cost to repair.
    Scholar:
  • 87 Answers
You probably have a bad convergence output IC causing your set to shutdown. My gues is $250 to $350. to fix. This is not a do it yourself job. Good luck
Posted on Jun 10, 2008
    Novelist:
    Champion:
  • 203 Answers
Get you a little solder and a cheap soldering iron and try soldering the vertical output ic which is mounted on a heatsink on the circuit board. Be careful when disconnecting plug connectors and I suggest marking them as you disconnect them. Also resolder the convergence i.c.s which are mounted on the largest heatsink on the board. Vert. i.c. has about 9 - 11 pins and convergence have about 25 ea. Start by carefully undoing all wire ties, remove the few screws that hold in the board then slide it back towards you to access bottom(solder side). For the most part, any component that is mounted to a heatsink gets hot and cools down when set is off causing cold solder joints. So any part mounted to a heatsink is suspect. This repairs a high percentage of sets like yours. Good luck, Russmann.
Won't turn on after reset ws-55511 hdtv
YOU GOTTA REPLCE THE STK ICS OR THE CAPS ON THE DM BOARD
Jul 18, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Blinking green timer light on front nearpower button keeps blinking, tv will not turn on, unplugged for 24 hours and tried again, also hit system reset and still nothing.
Thats a common problem when the caps on the DM need replacement. They will function fine untill power is interupted then the set will not complete the boot sequence when power is reapplied and the led will just continue to blink. Hers a link to the kit that will usually repair that issue the kit comes with instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
May 09, 2009 | Televison & Video
Device Selection menu stays on constantly and flickers...
sounds like a bad selector switch from the onboard card that has the console controls. my hitachi did something similar, and it turned out to be the board that the buttons are on
Mar 01, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Tv won't turn on with remote or front panel
Try this :
Follow the steps below for the initial set-up:
1. Select the "MENU" display by pressing the "MENU" button once.
2. Press the number buttons "2", "2", "7", "0" in sequence to select the "OPTION MENU" display.
3. Press the "ADJUST" button to select "INITIAL."
4. Press "ENTER."
Good luck...
Jan 11, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mits not working
I posted an update at your original question
http://www.fixya.com/support/t1018613-tv_will_not_stay
Sep 07, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55813 55" Rear Projection HDTV Logo
88 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
