Question about JVC KD-LH7R CD Player
Cl500 cd tv radio unit
I've been told that the fan that cools the tv radio cd unit in my 2000 cl500 is running my battery down, they cannot replace the fan, or turn it off, they say I have to replace the whole unit at a cost of 4,000 Euros, have you any solution for me..
lpdineen@gmail.com
  • Larryartist Jun 11, 2008
    They say the fan cuts in even when the car is turned off, I thought they could disconnect the fan and the TV unit but they say they cannot. It is some problem? and an expensive one, the whole shooting matchcomes to over 6,000 Euros
If you dont want to buy a new radio install a toggle switch to both of the power wires. you will keep losing your presets btu at least it wont run your battery down.
Posted on Jun 11, 2008
1993 Plymouth acclaim I replaced the head gasket and the thermostat but temp gauge seems to climb up to just about the red till I tap the throttle then it drops down to the cold line also revving at 2000...
the cooling fan has problems--shud go on without reving--the coolant sensor probly bad--du a scan or data stream on vehicle to confirm--mite take out sensor and testit
Aug 11, 2013 | Cars & Trucks
The electric fan operates all the time on low speed. Is there a normally open or normally closed sending unit causing this problem? CAN YOU HELP ME WITH THIS? Every morning the battery has run down due...
If the radiator cooling fan is staying on all the time then this is the sign of a failed fan relay. The cooling fan relay is located under the right headlamp assembly.
Dec 22, 2010 | 2000 Jeep Grand Cherokee
How to replace heater fan control switch on 2000 ford escort zx2
why are you replacing it?
SECTION 412-04: Control Components 2000 Escort Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 08/04/1999
Control Assembly
Special Tool(s) st1445a.gif Remover, Audio Unit
415-001 (T87P-19061-A)
Removal
  1. Disconnect the battery ground cable (14301).
  1. Rotate the temperature control switch to the COOL position.
  1. Disconnect the A/C temperature cable (19988) from the heater core housing.
    1. Unlock the heater temperature cable by pulling down the tab.
    1. Disconnect the heater temperature cable while holding the tab down.
  1. Use the Radio Removing Tool to pull the integrated control panel out of the instrument panel (04320).
  1. Disconnect the vacuum harness from the function selector switch.
  1. Disconnect the radio antenna lead in cable (18812) and the electrical connectors and remove the control assembly.
Installation
  1. Follow the removal procedure in reverse order.
Dec 20, 2010 | 2000 Ford Escort
Ive got a 323ci bmw on a 2000 plate with 23000 overheatin
repl temp sensor. run 12v to motor, does it run? could be resistors, they're hidden all over the car, thanks to the ******* engineers that put this piece of **** together. or the fan blades could be blocked.
radiator clogged, did someone put stop-leak in it? Remove thermostat drill two 3/16" holes in it 180degress apart, install 12 degree cooler thermostat.
check to see if fan clutch is working properly.
Jul 10, 2010 | 1999 BMW 323 Series
Car will not start, fan is draining battery I believe, not sure
boost vehicle but before you do that remove the fuse for the cooling fan till you get it to turn over once its running plug said fuse back in and get it to a shop to have them diagnose why the fan is on to long
Jun 02, 2010 | 2000 Volkswagen Beetle
91 Legend cooling fan turns on by itself
Replace the cooling fan engine temp sensor switch, this may be the cause.
Nov 19, 2008 | 1991 Acura Legend
BATTERY BACKUP VS. SURGE SUPRESSOR FOR A KDF-60WF655
Rear projection TV's use a high power light bulb that is cooled by a fan. When you turn the TV off, the fan still runs for a little bit to cool the bulb off. A power outage is nothing short of jerking the plug out of the wall. This is murder on the bulbs because of all of the heat built up in them that the fan cannot remove. I would recomment a UPS (uninterupptable power supply) or as you refered to it "battery backup" to protect your investment. If there is a power outage, this will not really provide enough power to watch tv, but you can safely turn off the tv and it can cool down normally. Also, a UPS can filter and clean up "dirty" power, compensating for over and under voltages that could otherwise cause stress to your electronics. Check the power consumption of your tv, as UPS's are rated by their output capacity. Expect to pay $100 to $200 for a decent unit
Jun 15, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Toshiba 46HM95 Buzzing
I have the same thing, mine is the cooling fan for the lamp. If the sound continues for a short time after you turn off the TV then this is the most likely cause as the cooling fan will continue to run for a short time to cool off the bulb. I have looked into replacing mine, the part runs around $50 but I can't say yet how easy it is to replace yet.
Apr 02, 2008 | Toshiba 46HM95 46" HDTV
JVC KD-LH7R CD Player Logo
246 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
