Question about Roxio PHOTOSUITE 5 PLATINUM CD for PC
Incompatible Driver(s) I tried to install an old version of Roxio Photosuite 5 in Windows Vista 32. Not knowing it was not compatible. Now I get an incompatible driver error message when I boot my computer. I downloaded a patch from Roxio to try to fix the problem, but when I try to run it, I get a message saying drag to disk vista32 not found. can you help?
  • 2,794 Answers
I would uninstall Photosuite.
I don't think that Roxio is supporting that program anymore. I have version 7.0 and it does some goofy things in Windows XP they never fixed in the slide show mode.
Posted on Jun 10, 2008
Cannot install MGI PhotoSuite4 on a computer running Windows 7 OS
The PhotoSuite 4 program is very old and won't work under Windows 7. http://sonic.net/mnitepub/pccafe/reviews/photosuite4/photosuite4.html says that the version 4 Platinum edition ran under Win95-Win2000 versions of the Windows OS. Thus even the compatibility mode probably won't help under Windows 7 32-bit. You can try it though by right clicking on the installer and then selecting Properties. In the Compatibility Mode tab, select Always Run this program in the compatibility mode and an older version of Windows. Then right click again and choose Run as Administrator. (You may have to do this again on the program itself.) Since Win7 64-bit requires signed drivers or programs, it is not as likely to work. (Check your version of Windows 7 by clicking Start > Control Panel > System and Security > System. If the title of your OS ends with x64, you have the 64-bit OS. Otherwise, you have the 32-bit OS.)
If you have Windows 7 Pro or Ultimate (or upgrade to one of those versions), you can run a virtual version of XP for free. Download and install Microsoft's Virtual PC and then XP mode (in order). This works best if your CPU supports virtualization and you enable the feature in your computer's BIOS. (There are work-arounds for computers without virtualization. See the MS support pages.) Install your PhotoSuite inside the virtual XP program in that case.This old software may run in that case. (However, I've had some Win2K software that ran under XP with the compatibility mode but didn't run under the virtual XP. Note: virtual computers do have some additional limitations. They do not talk to the host hard drive and other hardware directly. (You can install a printer on the host machine or the virtual machine but not both.) You'll need to save files on external media (flash drive, optical disc or other hard drive) to transfer them between the machines).
Another option is to run an older version of Windows on another computer, as a dual boot computer or with Virtual PC (or another virtual computer package - VMWare or Parallels). In that case, you need a licensed version of the older Windows OS. Again install the program while running the older OS.
The final option is to upgrade to a Windows 7 compatible Photo editor and organizer. (Even the Microsoft Windows Live Photo Gallery has some of the features of Photosuite SE.)
I hope this helps.
Mar 24, 2012 | MGI Software PhotoSuite SE V4.0
Running Windows 7 and can't use my Photosuite 7 Platinum
Unfortunately Photosuite 7 is not compatible with Windows 7. It was supported for Windows 2000 and XP.
You can upgrade to the latest Roxio product, http://www.roxio.com/enu/products/allproducts.html?rTrack=m_pro_all . I think you need the Creator 2011. (Creator 2010 is also WIndows 7 compatible with the installation of a patch from Roxio.)
If you have Windows7 32-bit (click Start > Control Panel > System and Security > System for the details), you can try using the compatibility mode. Right click on the installer and select Properties. Then choose the Compatibility Tab. Select Run as Compatible with XP (I am not certain which SP option is best - I know the initial release is listed as SP1). Then right click again on the installer and choose Run as Administrator. Then check if the program is running in the compatibility mode. This may not work (it will not work with the 64-bit version at all).
If you have the 64-bit version of the OS or if the compatibility mode fails, you need a work-around. Your option is to run a computer with an older version of Windows. This can be a virtual, dual-boot, or true second machine. If you have Win7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install your Photosuite Platinum software in the XP mode (as you would if it were a stand-alone machine). It will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them. Also your printer can not be installed on both the real and virtual machines at the same time.
I hope this helps.
May 03, 2011 | Roxio PhotoSuite 7 Platinum for PC
Two computers ago, and two operating systems ago I purchased MGI Photosuite 4 software. I have been using it for about 10 years. I have hundreds of collages saved that require the MGI software to read and...
Wndows installers have changed over the years, so it's not a surprise that the program couldn't be reinstalled. The Roxio Photosuite 8 is listed as a Win2000-XP product; so it may not be the correct release for Win7 either unless you use a workaround. Look here for the current Roxio slide show products: http://www.roxio.com/enu/store/photo.html?rTrack=m_pro_photo
Workarounds: go with a dual-boot or virtual computer system. Win7 Pro and Ultimate let you run a virtual XP computer for free (download two programs - the virtual PC software and then XP mode). All other choices will require a licensed version of XP installed either in the virtual computer program or in a second partition for dual-boot. I've found that files can not be transferred directly from XP mode to the real computer; they must be stored on external media. Then install your software as you would on any stand-alone computer.
I hope this helps.
Aug 21, 2010 | Computers & Internet
Windows 7 not compatable with photosuite 7platinum is there a patch? thanks, carol-b
Hi Carol,
I'm going to have to assume you have the standalone version of Photosuite, and not the version that comes with Easy Media Creator 7.
I don't know for sure if this will solve your problem, but try downloading this update:
http://www.roxio.com/enu/support/photosuite/software_updates.html
As a side note, if this doesn't solve your problem, could you elaborate on what you mean by Windows 7 isn't compatible? As in what happens when you try to run it?
Feel free to leave a comment if you have any further questions.
Good Luck :)
Nov 29, 2009 | Roxio PhotoSuite 7 Platinum for PC
When installing Roxio Easy CD & DVD Burning in Vista message pops up saying the software is incompatible.
Yes, Roxio Easy CD is not compatible with Windows Vista. You either need to remove windows Vista and install Windows XP, or purchase the newest, latest copy of Roxio.
Jun 29, 2009 | Roxio Easy CD & DVD Burning
Installation and operating failures to save or burn.
When you install the program, it provides an Ignore button to avoid the conflict? It's strange that you must uninstall one software to use the other one.
May 12, 2009 | Roxio PHOTOSUITE 5 PLATINUM CD for PC
Running MGI Photosuite version 8.05 in Vista
MGI Photosuite on Vista, THE FINAL SOLUTION!!! First you need to get hold of an MGI disc or a download. I have been trying to get MGI Photosuite III SE to install on Vista for months without success and then when I thought I'd finally sorted it I could not launch the program due to a script error. You do not need Virtual PC, Virtual XP or any add-ons. Simply find and right click the the MGI setup file, check the run in compatibility mode as Windows XP SP2 and install. After install, send a program launch shortcut to your desktop, right click, go to properties and check the Windows XP compatibility mode once again. Finally, while you still have the compatibility screen open add a tick check to Run As Administrator. Hey presto my beloved MGI Photosuite is back! MGI is fantastic for being user friendly and simple, and although I know other users insist there are better programs, I’ve tried loads and I still think it’s a winner.
Mar 25, 2009 | Computers & Internet
Problem: Roxio easy creator 10 installed on Vista ...I have downloaded all the software updates...Videoware will not run....need help!
have you tried changing the compatibility of roxio. All you do is left click the main folder in which all the Roxio 10 suite is install go to compatibility tab and check box next to run this program in compatibility mode make sure that in the box under this it says window xp sp2 then hit apply. If this doesn't work let me know if you are using the 64 or the 32 windows vista and i can help more.
Oct 26, 2008 | Computers & Internet
Driver
Download and install adobe reader for manual, if needed
use Get Adobe Reader button on this page
http://www.adobe.com
Manual link (two choose based on directions)
http://www.bushnell.com/customer_service/manuals/binoculars.cfm
There may be no driver required for vista for the USB access to the camera.
However one of the manuals indicate Roxio may provide updates for photosuite. No assurances there are that either link to provided software is applicable to your version however generally updaters will not update the incorrect software. There is also no notation that these are or are not Vista Compatible.
This Vista support link may help
http://kb.roxio.com/content/kb/General%20Information/000004GN
This Update is PhotoSuite Version Specific, you will need to find the version of PhotoSuite installed on your system before selecting the update.
To find the version of PhotoSuite that you have installed first open PhotoSuite and then Go To "Help" and then to "About Roxio PhotoSuite", once the About box opens you will find the version at the bottom center.
If you have version 5.1.2529.0 or higher this update is not needed.
Updates the PhotoSuite components of Easy CD & DVD Creator 6 PhotoSuite version 5.0.1366.0 only.
Note: The latest Easy CD & DVD Creator Engine update should have already been installed.
(This update will take 5 to 20 minutes to install, there is no progress bar, so you should not interrupt it.)
Download
Updates the PhotoSuite components of Easy CD & DVD Creator 6 PhotoSuite version 5.0.1419.0 only.
Download
Update PhotoSuite 7 Platinum to 7.0.430.0 (English Only)
Important Note:
This updater is intended only for the stand alone version of Roxio PhotoSuite 7 Platinum. If your version of PhotoSuite 7 was included with Easy Media Creator 7 then please (use those listed above) for the correct updater.
Download
Dec 22, 2007 | Bushnell ImageView 11-8200 Binocular
Driver
Manual link (two but these appear to be the same)
However the manuals indicate Roxio may provide updates for photosuite. No assurances there are that either link to provided software is applicable to your version however generally updaters will not update the incorrect software. There is also no notation that these are or are not Vista Compatible.
Download
Download
Important Note:
Download
Dec 22, 2007 | Bushnell ImageView 11-8321 Binocular
Roxio PHOTOSUITE 5 PLATINUM CD for PC Logo
219 people viewed this question
Top Roxio Computers & Internet Experts
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
