AC Unit Running Without Freon
What would happen to the outside unit of the AC if it was ran without freon for 4 days?
    Scholar:
  • 165 Answers
There is nothing to worry about at this point, if the compressor was damaged it wouldn't start and if it is running, it should be fine. keep in mind that if the unit is running without freon, it was not doing any work either. The only real issue you should worry about is: where did the freon go? you obviously have a leak somewhere and as long as you do not repair it, you will continue to lose freon and efficiency. So for now, I suggest that you stop worrying and enjoy your A/C and consider finding a competent technician to repair the leak. .
good luck, Elie-tech
Posted on Jun 12, 2008
Why is my new AC running all day and then losing a degree or two
Is outside unit running? If it is not that could be the reason. If it is running then you could be low on Freon. Check to see if outside is running if it is put your hand over the fan if its warm or hot the compressor is running if it is cool then your compressor is not running. Check this out because your inside unit will run even if the outside is not running.
Jul 07, 2014 | Heating & Cooling
Not staying cool
sounds like it is either low on Freon or the compressor is going out. The blowing ice cold is an indicator that it may be freezing up because the low Freon. when it stops blowing cold, turn it to fan only mode and see if it gets colder again. If that is the case then the unit is low on freon and freezing up. I know that sounds confusing but that is how AC works. The low freon pressure means the gas is expanding too fast and the air flow cannot take up the cold from the evaporator fast enough. Turning the compressor off and keeping the fan on will alow the room air to take up the cold.
Apr 22, 2014 | Frigidaire FAM157S1A Air Conditioner
I have a Goodman home A/C unit and the copper line coming into the house freezes up. The unit continues to run with no cold air. I was told it is either dirty or low on Freon. Are they correct? If it is...
Hello
If you have ice on bigger copper line and no cooling then the unit is low in freon.
As far as cleaning it,you should clean the outside condenser in the spring.Use some simple green and a hose to clean the coils,this will make it better for the heat to transfer to the outside and cut your costs of running the unit down.
No you can not do freon yourself you need to be cfc certified now,which means you can not buy freon.Best to have a service person come out.
Apr 04, 2011 | Heating & Cooling
Hello, I have a split level Samsung AC unit. Recently the outside unit formed ice on it, so i had a tech look at it and he said that it was freon low level prob, so we got the level back up and it ran for...
Yes it is! These are sealed systems, so if the tech made no effort in locating your leak, it will continue to loose freon. We are required by the E.P A. law, to make every effort we can to locate the freon leak. We can get away the first time, but always check for any signs of leakage. How much freon did he add? Should say on the service order as we charge by the lb. Look on the data plate on the outdoor unit to see what it holds, and compare how much was added. The compressor is working overtime trying to keep up. I would schedule a leak check to take care of the problem. They will not let us keep coming out to add freon with out finding the leak, its changed so much do to our o-zone layer. Please rate me on my help to you.
Shastalaker7
A/C, & Heating Contractor
The E.P.A. keep records of our freon use, and where it goes.
Jan 21, 2011 | Heating & Cooling
Ice is forming on coil fins
Either your coil is dirty or filter is dirty. Worst case your low on freon which would make a coil freeze.But freon doesn't evaporate if your low there must be a slow leak.
May 19, 2010 | LG Heat cool Window Air Conditioner
Air conditioner constantly running, not cooling house
Check and see if it is froze up. Check big line at outside unit for ice. check filter and replace as needed. Check outside fan to see if it is running. Wash out outside coil If fan and compressor are running and has hot small line at outside unit. If not froze up and coil is clean you will need to call in a pro. If compress over heated you may need to wait for it to restart if coil was dirty. Again make sure out door fan and or unit is running and clean.
Jun 29, 2009 | Goodman CKL49AR49 Air Conditioner
AC unit dripping water and won't cool
The coil is likely froze up due to dirty evaporator plugged ,air filter or low on freon .Tom
Jun 18, 2009 | Heating & Cooling
AC is not cooling
I would say you have a freon leak. May be the outside unit is not running now because the low psi switch has it off because it does not have enought freon.
Apr 07, 2009 | Haier Air Conditioner
Ac will not cool off
There are only 2-choices for this problem,,, 1= low on freon or 2-low air flow across the indoor coils which can be caused by dirty filter--- dirty fan blades and last but not least , dirty or plugged inside coils. After the unit has been cleanned , then he's suppose to check the freon last..
Sep 01, 2008 | Ruud UBHC Air Conditioner
Goodman Model CK60-1C with White Rogers mercury tube thermostat
The contactor on the outside unit is sticking and must be replaced. The inside unit cycles off and the outside continues to run causing the refrigerant lines to freeze up.
Jul 29, 2008 | Goodman CKL60AR60 Air Conditioner
Heating & Cooling Logo
127 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
