Question about GE Profile Advantium SCB2001KSS Stainless Steel Electric Single Oven
GE Profile Advantium oven (stainless steel)
The inside is dirty with spots that I can't get off with soap and water. Does anyone know how to get it clean?
    Novelist:
  • 161 Answers
Spray a little oven cleaner on a wet rag and wipe. Rinse really well afterwards. Do not spray directly in oven. It could get in the holes.
Posted on Jun 29, 2008
Bread will not brown on bottom
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 19, 2011 | GE Profile Advantium SCB2001KSS Stainless...
How to clean the oven
The inside of the oven can be cleaned with regular soap and water. Dawn works well on built up grease. if you have very stubborn stains easy off makes a low fume oven cleaner, but try hot soapy water first. the outside can be cleaned with any stainless steel cleaner or window cleaner.
Nov 20, 2010 | Dacor Epicure EO127 Stainless Steel Dual...
My scb2001kss ge advantium no longer heats. it turns on and everything else works, but heat
check breakers for oven one side could of tripped if everything else works but the heat this is a normal problem the only other thing could be is that the controles are not working
Jan 26, 2010 | GE Profile Advantium SCB2001KSS Stainless...
Have -F3- on the screen and nothing works
**FIRST; shut off the breaker or unplug the unit before going any further please**
"F3" on most GE ovens describes a fault with the oven sensor or sensor circuit. Ohm out the sensor. It should read approx.1100ohms. @ room temperature.
The other possible faults are a bad solder on the control, a pinched or severed wire from control to sensor.
Having said all that, 99% of the time, its' a sensor. most common GE sensor is part # wb21x5301.
hope that helps
good luck
Oct 01, 2009 | GE Profile Advantium SCB2001KSS Stainless...
Sparking when microwaving
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
gfgh
Mar 08, 2008 | GE Profile Advantium SCB2001KSS Stainless...
F3 Error
This is due to a Defective control board..You have to get it replaced..
Oct 15, 2007 | GE Profile Advantium SCB2001KSS Stainless...
Can't make my oven work after a power loss - GE Profile Advantium
check voltage to oven. if thats ok your control board may be shot.
Feb 01, 2007 | GE Profile Advantium SCB2001KSS Stainless...
GE Profile Advantium SCB2001KSS Stainless Steel Electric Single Oven Logo
154 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
