Question about Fedders SFPEB08F2A Air Conditioner
Parts for Fedders Portable Air conditioner model # SFPEB08F2A
Someone gave me just the unit itself. I need the vent hose and the window adapter. I found them online, but before I order them I want to make sure I'm not missing some crucial part. Is there a part that holds the hose to the air conditioner?
  • bcbcmc95 Jul 02, 2008
    I need a manual and the hose for this product. Someone gave us the unit and nothing else and it kept leaking water and I just noticed online that it needs a hose and I really would like to have a manual to better understand this product.
  • Anonymous Apr 26, 2009
    I need the manual for this unit
There are two separate solid plastic pieces between the hose and the body of the unit
i have a hose but I am about to donate the unit
Posted on Jul 20, 2008
How do i keep water from draing all over my floor
Your air conditioner may have been installed incorrectly or the drain provision could be pinched or clogged.
Jun 27, 2014 | Fedders SFPEB08F2A Air Conditioner
Tip
Portable Air Conditioning great portable air cooling
Portable air conditioning offers you the convenience of mobility. All you have to do is roll the portable air conditioner to the room in which it's needed. Install an exhaust hose out a window or other opening (everything you need is provided) and turn it on. The installation process for these units is very simple. These portable air conditioning units are built small enough to be very mobile and are supplied with wheels for easy movement. A portable air conditioner will also work very well in apartment situations where you will often find a window unit is unacceptable.
Portable air conditioners are very unique in that they are portable and can be easily moved to different locations in your home or business. They can be a highly effective way to either help out an existing HVAC system in one room or cool a single room entirely. They are also one of the best ways to cool a room or area without having to install a window mounted unit.
These air conditioners use a compressor and Freon to cool just like normal air conditioning. They are very effective in cooling rooms and to keep the humidity low. Like normal air conditioners portable units extract hot air that must be vented. That is why they need to have the exhaust hose to the outside. These units can cool air as well as air conditioning done with window air conditioners. However they do not require installation like conventional window air conditioners this makes them very convenient for seniors or physically challenged people. Most portable air conditioners are supplied with a window kit. This kit contains exhaust hoses that will work in any window: double-hung, casement, awning or slider. Because they vent through an opening like a window they require no permanent mounting like window air conditioning.
Portable air conditioners are a very good cooling option for those who can't use the more conventional air conditioning methods. Remember though that this type of unit is not as efficient as most window units or conventional air. So while they may make your environment cooler, it won’t turn your tent into a room at the local hotel.
So as you can see these air conditioning units have some great advantages over other types of air conditioning. They are a great alternative for unique applications where central air or conventional window units are either unfeasible or too expensive. During special events, portable air conditioning can also be a great way to keep guests or equipment cool and comfortable. Always be aware though that because portable air conditioning will remove moisture from the air, they will also need to be drained occasionally similar to a dehumidifier.
Does your application warrant a permanent air conditioner of some form or should you just use a portable one? There are some interesting things to consider when making that choice. Weigh out all of the different options and make that decision based on what will best suit your needs.
on Dec 13, 2009 | Heating & Cooling
THE UNIT BLOWS COOL AIR OUT THE FRONT BUT HOT AIR OUT THE BACK THE MODEL IS aP076E .i DO NOT HAVE A MANUAL BUT IT DOES NOT SEEM TO BE REAL HARD TO RUN THANKS
Yes, that is the way a typical air conditioner works. The portable types need to have the hot discharge air direct outside via flexible hose and an adjustable window bracket. The window closes on the bracket to create a seal, and the hose connects between the air conditioner discharge and the opening in the bracket. This is called "venting". Most portable air conditioners include (or offer as an accessory) a "vent kit" or "window kit".
Some portable air conditioners do not provide a way to vent - fortunately yours appears to have a kit for this purpose. You may wish to check out this page on venting. It has plenty of ideas and suggestions for venting. This site has some very good pictures to document making a vent - and is worth a look, too.
If this was helpful, please rate it "4 thumbs up" - thanks!
Aug 02, 2011 | Amana Heating & Cooling
My everstar blows hot air out the back and cold air in front i want all cold air
this style unit needs an exhaust hose attached to the rearand be placed out the window to exhaust the heat that is removed from the air in the room, you will also have to empty the condensate drain bucket when it gets full.
Jul 23, 2011 | Fedders Portable Dual Hose Electronic...
Hello, I need the hose to drain water outside that fits the fridgidair portable air conditioner #FAPO9EP1Z1. Is there another small tube or is there any other hoses or vents that I need? I don't see...
impreston - with out the following parts , you really don't have "just the air conditioner."
1- Flexible Exhaust Hose
2- Hose Adapters
1- Sliding Window Kit
1-Foam Window Seal
1-Remote Control
The drain hose is something you supply. A garden hose, no longer than 5 feet will do if you want it to be a continusos drain, rather than drain into the water collectiong bucket. But, without the first 4 items lister above, you won't be able to operate the unit.
Here is a link that may be of some help to you, since you don't have an Owner's Manual.
http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020252a0373en.pdf
You will beed to contact Frigidaire (1 -800-374-4432 ) for the parts you're missing.
Hope this helped you. Please let me know. Thanks.
Jul 12, 2011 | Frigidaire FAP094P1Z Portable Air...
Missing exhaust kit. Need window adapter, hose and connector/adapter for back of unit hot air exhaust port. NMPEB08F2A Rev B made by Maytag / Fedders
Try duct tape , pvc pipping and cardboard, Tape the pipe to the back of the ac and them use a cardboard piece with a whole cut out for the pvc pipe in the window ,coat the cardboard with several layers of tape inside and out..It should work for awhile..Or call the Maytag/Fedders maybe they will send it to you free...
Jun 12, 2010 | Maytag NMPEB08F2A Air Conditioner
Hose connection, need parts list, or picture showing connec.
Hello, the unit is made and marketed under Fedders and Maytag....the only difference is the first letter of the model number. Here is a link to a manual for your unit. It is downloaded at a storage site I use. The only bad thing is a few annoying pop ups, but be patient and you can print off the whole manual. Here is link http://www.mediafire.com/?jd0rmmj3dnu
May 14, 2010 | Heating & Cooling
I can't find the window adapter and hose for the portable Fedder #A6P09S2b.Any suggestions?
Cut a piece of plywood to fit your window opening, install a flex connector ductboard%20collar.jpglike the one shown here, and use flexible duct to connect to your unit and the connector you attached to the plywood. flex-duct.gif
Mar 19, 2010 | Fedders SFPEB08F2A Air Conditioner
Top tray not draining
I called the service tech, before Maytag stopped supporting this unit. (built by Fedders with Maytag name). Fedders has gone out of business (7-09). The tech guy said that the tray gets clogged up with crud and the solution is to try to flush the tray out with water and compressed air. I had the problem of water leaking from the trays but not properly draining through the drain hose. This solution did the trick.
Jul 24, 2009 | Maytag Portable Air Conditioner M6P09S2A
Fedders SFPEB08F2A Air Conditioner Logo
823 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
