Question about Canon PowerShot A70 Digital Camera
My Canon PowerShot A70 Digital wont take pictures!
When i turn on my camera on the little screen it says memery card error
what gives?
  • Canon Master
  • 4,738 Answers
There are several possible possible things might cause this error. The first obvious is the card has gone bad. Try a different memory card to verify.
Second thing is to inspect the pins in the card slot. Look for bent or missing pins. If you find a bent pin, don't fret as it's relatively easy to fix:
- Remove batteries and card. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. Take your time and use as much patience as you can muster (take a breather in between if needed).
- It doesn't have to be perfect, just as close as you can get it. When it's there, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
If it's neither of the above, the next thing to try is replacing the camera's "CR 1220" clock battery. Its compartment is located under the rubber A/V cable mat on the left side of the camera. You can buy this inexpensive battery at most department or drug stores. Just open the door by prying it open with a pin or small screwdriver, take out the old battery, and put in the new.
Posted on Jun 19, 2008
Canon Powershot A70. I get a 'Memory Card Error' when I turn it on. Did this three different cards. They don no appear to be defective. I just transferred all of the pictures form them to another hard...
When you transferred the pics from the cards to your computer, did you use the "safely remove hardware" function before removing the cards or cord or whatever method you used? If not, this is why you're getting the error message. If the pics are safely downloaded, format the cards in the camera to get them working again.
Sep 03, 2010 | Canon PowerShot A70 Digital Camera
After taking a picture, no photo is displayed.
Most cameras give a countdown in the corner of the lcd screen. Also, when the card if full, the camera will tell you so.
Aug 31, 2009 | Canon PowerShot A70 Digital Camera
A Canon Power shot A70 was demagnetized.
Its known problem of CCD Imager in your Canon A70 camera and Canon will repair it free of cost.
Click Canon CCD Imager Advisory for details.
Jun 25, 2009 | Canon PowerShot A70 Digital Camera
Canon Powershot A70 black screen
Try by pressing the DISP. Button until you have picture
if this didn't work, please notify us
Thank you
Aug 25, 2008 | Canon PowerShot A70 Digital Camera
Video problems
probably the memory card is corrupted try a new memery card if the error persists contact canon at www.canon.com and ask them what else could be done to fix the error
May 13, 2008 | Canon PowerShot A95 Digital Camera
Canon powershot A70 digital camera
The memory card may be failing. Recommend trying a different memory card to verify. Do you still have the original low value card that came with the camera? If so, try that one to see if you still have the problem. If that one checks fine, then you know it's time for a new card.
Feb 14, 2008 | Canon PowerShot A70 Digital Camera
Canon Powershot A70 Digital
When I got my A70 I got a CD with the software. If I connect the camera with USB cable to the computer, set the little lever on the back for the camera to display whatever pictures are in it, and turn the camera on, the computer recognizes the camera, opens the software and leads me through the process.
If you have some other photo software than the Canon software, it should still work.
Nov 28, 2007 | Canon PowerShot A70 Digital Camera
Digital Camera Malfunction
mine just started doing the same thing a few weeks ago. I had downloaded pixes to the computer, went outside to take picture and it started acting up. strange lines appear on the screen, but the codes are all there, and you can view the pictures that are on the card. no, the card is not full, the batteries are fine. I think it has a virus built in to start trouble so we will go buy a new one!
May 27, 2007 | Canon PowerShot A70 Digital Camera
PowerShot A70
This comes up when the lens sticks. Try removing the colar around the lens, then turn the camera on/off and give it a "little help" to open or close, it's probably just a little stuck
Dec 14, 2006 | Canon PowerShot A70 Digital Camera
Canon PowerShot A70 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
