Question about Janome Memory Craft 9000 Computerized Sewing Machine
Re: possible solution for the 9000 errors.
Although I have noted your sound advice in your response, I didn't tell you about the recent regular service that hadn't remedied its error. You pointed towards bobbins and cleaning which did remedy the fault. So my current theory is clean under the bobbin holder more regularly and use only "pucker' Janome bobbins. Thanks very for your help.
  • Anonymous Nov 26, 2008
    don't know how to insert janome sewing machine needle
  • Janome Master
  • 1,388 Answers
Ohhhhhhh yes,
Clean under and around the bobbin case regularly.....my wife has a small brush to hand, and does it at every bobbin change.
The quilters of the world need to be especially vigilant, as the wadding and layers generate lint at a remarkable pace.
As to bobbins, they do vary from brand to brand, diameter and height, so this can be an annoying apparently "intermittent" problem if you happen to have a few different brands kicking around.........I had one customer who had me on 3 house calls before I realised that she had been collecting blinkin' bobbins where and whenever !!
Another thing with the brown magnetic donut in the middle of your white hook race.........best to use Janome plastic bobbins to avoid any other troubles, rather than the older metal bobbins.
Glad it all went well.
Cheers
Martyn
www.bargainbox.com.au
Posted on Jun 10, 2008
  • Bargain Box
    Bargain Box Jun 10, 2008
    As a further tutorial on getting the balances right in the future, this generic tension setting guide will walk you through attaining the correct balance of tension for any machine.
    Ensure that all is clean and free of lint jams....now for tension troubleshooting .......
    This
    solution is for tension problems...if you cannot form any sort of
    stitch, the issue is quite different, so please let me know if you need
    a different problem solved.....
    It is quite long, but just work through each section in order.
    The
    "knotting up" can reveal a lot. If you have loose threads on one side
    or the other, the tension on the opposite side will be the culprit.
    QUICK SUMMARY FIRST:
    Ensure sharp new needle,
    Thread guides and Bobbin are Clean & Clear of lint
    Set Top Tesion to 4 ....then....
    Balance Bobbin to suit.
    TOP THREAD TENSION:
    If
    the looping threads are on the underside as you sew, it is the top
    tension. Top tension ought to be between 4 & 6 (this variation to
    allow for the different weights of fabric in your
    projects).
    IS YOUR NEEDLE SHARP ?
    If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
    TOP TENSION & GUIDES:
    Make
    sure that when you thread the machine the presser foot is up so the
    thread goes between the discs and not to one side, top tension between
    4 and 6, and that you have threaded through all the guides, including
    the last one, usually on the needle arm, just above the needle clamp.
    It
    may be there is lint trapped between the discs, this will keep them
    slightly apart and reduce the actual tension, sometimes dramatically.
    If
    tensions appear correct, and the thread is definitely in the channel
    between the discs, but still too loose and looping, try raising presser
    foot and remove your thread.
    Now, with a 2" (50mm) wide strip
    piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or
    denatured spirit, gently insert the fabric strip and clean between the
    discs with
    a see saw / to and fro action.
    In the worst
    cases, gentle use of a needle to pick & remove the jam may be
    necessary, but be very gentle and make sure the tension is set at Zero
    and the presser foot is raised, (to
    disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
    BOBBIN TENSION:
    Far
    less common, but if the loose threads are on the top, it is bobbin
    tension that is loose, it too may have lint in the spring and be giving
    a "false" tension.
    I would not recommend fiddling with bobbin
    tension without good reason, it may end up with missing small screws
    and spring pieces, however, you can take the needle plate off to clean
    the hook race area (where bobbin case sits)
    ...this is just good housekeeping, my wife does this every time she replaces the bobbin....
    just
    take it out and clean the bobbin case and the fixed metal hook race
    with a small brush to remove lint. If there is a significant amount of
    lint, use a vacuum and small brush to get the worst.
    Then wipe
    all this area with a cloth or cotton bud (Q tip) moistened (not soaked)
    with methylated spirit, especially if there appears to be fine dirty
    deposits....oil and lint combine to conspire against you.
    If it
    seems likely that you ......really ....do .....actually .....need
    .....to adjust the bobbin case, first check there is no lint trapped in
    the metal spring where the thread is tensioned.
    TOP LOADER:
    Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
    ...the other screw at one end is holding it all together, so
    beware....it is not a tragedy to undo the whole lot and clean it, but
    very gingerly and lay the bits out in sequence and orientation, or you
    risk tearing your hair out !
    FRONT LOADER:
    ....this is a
    bobbin case from a front loading machine and works in a very similar
    fashion to the top loader with drop in bobbin, again, if you dismantle
    it, take care so you can put it all
    back properly.
    FINISHING UP
    GETTING THE BALANCE RIGHT:
    When
    you are certain there's no trapped lint in top tension or bobbin, set
    the top tension to 4 and the bobbin tension to a point where you just
    begin to feel resistance.
    Try using good quality thread of contrasting colours so you can more easily spot the changes.
    Set
    your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5
    etc) and sew a sample for a few inches and check the result.... adjust
    the bobbin tension screw very little at
    a time, perhaps 1/16 of a turn.
    You
    may find you are playing with this balance for some little while and if
    you are putting the needleplate on and off each time begin to think it
    cannot be correct to do this.....BUT....it is,
    and eventually, you
    do get a "feel" for the correct tension and then it happens quite
    quickly.....as a user you won't be doing it very often unless there is
    lint built up (or are there small hands at work around the house !?!?!)
    OTHER ISSUES:
    If
    you live near the ocean as we do, salt air can play havoc with
    metalwork inside and out, so to help minimise this, keep a few small
    packets of dessicant (silica gel) in your machine
    case....no case ? then make some sort of cover !
    Same applies in any damp or humid environment, keep your machine dry and dust free.
    Budget
    for a proper full service every couple of years (more often if heavily
    used) and if you don't use your machine for a few years, be aware that
    old oil will dry out and combining with
    dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
    FINALLY, A WORD ON THREAD:
    If
    it is worth spending the time, energy and money on making something
    that you would like to give lasting enjoyment......use quality thread,
    .......it may seem to cost a little more at the
    time, but the
    results, ease of use and added longevity will be worth the extra, and
    as a bonus, your tension troubles may be fewer and further between,
    because there is a more consistant diameter with good thread, and less
    compensating to be done by your tension plates and less thread breaks !
Just recently my screen has started to flash on and off, is this a computer problem?
it is very possible that it is a computer problem and it would be a good idea to have the machine checked.
Nov 09, 2013 | Janome Memory Craft 9000 Computerized...
Memory craft 5200 showing error 3
If your user manual doesn't tell you, and your dealer doesn't know,
you can go to the Janome website, go to tech support , and they can answer your question.
DO NOT use your machine until you get the error corrected.
Apr 10, 2013 | Janome Memory Craft 9000 Computerized...
My 9000, on regular sewing, is My 9000, on regular sewing, is "jumping" ahead as I sew....kinda like the foot pedal is stuck. Anyone every have this and if so, is it something I can fix or do I need t
it's definitely not suppose to be jumping ahead.
have you checked the foot your using on the machine to make sure it's on correctly?
you might also check the feed dogs to see if there in the up position, in the needle plate.
if nothing I suggests works then I agree to take it to a janome dealer & let them sew on it & see what it does with them
Mar 30, 2012 | Janome Memory Craft 9000 Computerized...
I have looping underneath. Top stitch looks great.
top tension is too loose,check threading up and tension dial. should be on 4-6. read manual and if possible clean tension device. if it is accessible you turn dial to zero and "floss" between tension discs using selvage edge of clean piece of cotton fabric. you can moisten it with denatured alcohol if very dirty. thread sheds dye particles, especially black or cheaper threads. needs to be removed regularly to keep tension discs clean. turn back dial to 5 after and thread up again. often this will resolve the problem
Aug 27, 2011 | Janome Memory Craft 9000 Computerized...
What are the considerations in purchasing hardware
as this machine is old, you will find it hard to buy anything that allows you to load designs off the internet, although i believe this is possible. For feet and memory cards look at ebay. Also, some janome outlets still have some design cards for sale, is that what you were after?
Oct 08, 2010 | Janome Memory Craft 9000 Computerized...
Where can i find an operating manual for an Elna Diva
Look up a manual for the Elna 9000. They are available on eBay and from sewing machine part suppliers. I used to sell Elna's, and they are the same machine. The first version (9000) had black face detail and buttons, which didn't sell well, so they just changed the facade to white with gold writing and renamed it "Diva." It is one and the same.
Mar 03, 2010 | Elna Sewing Machines
Stepping motor error on janome mc 8000
From what I've read here, it could be one of two things: a blown motherboard or a scratched bobbin case.
Before you do anything else, I'd remove the bobbin case, clean it and the area around it thoroughly (and check it for scratches or dings -- perhaps a needle broke recently?) and then replace it and see if that fixes the error.
If not, unfortunately, I'll bet it's time for a check-up with a repairman. :(
Best of luck to you!!
Apr 12, 2009 | Janome Memory Craft 9000 Computerized...
Error; after checking bobbin threads, press start button
This is most probably solved by an adjustment to your bobbin thread sensor, and not something for the home handy fellow......especially without a manual.
Be sure that there is no lint build up in or under the bobbin case as a first measure, and give this area a good clean anyway as normal housekeeping.....this will probably make little difference, but may let you finish any urgent job over the weekend.
When was your machine last serviced ?
2 years or more ?
When was your car last serviced ?
Your best solution is to take it to an authorised Janome Service Centre (make sure they have the Service Manual for this model) and make sure to tell them about the bobbin sensor issue so that it can be specifically targeted during a full service.
This MC 9000 was expensive and the top of the range in it's day and deserves good regular care to work to its optimum for many more years.
Jun 08, 2008 | Janome Memory Craft 9000 Computerized...
Janome Memory Craft 9000 Computerized Sewing Machine Logo
98 people viewed this question
Top Janome Sewing Machines Experts
Bargain Box
Bargain Box
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
