Question about Lexmark All-in-One Printer with PictBridge
LEXMARK 3500 4500
Printer keeps telling me i have a paper jam although there doesnt seem to be one .How can i resolve this?
  • 2,035 Answers
  1. Turn the printer off and open the access cover.
  2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
  3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
  4. Watch the paper as it feeds through and try to determine where the jam is occurring.
  5. Check to see if all the rollers are turning.
    If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
    If not, there is probably a feed motor or a gear problem and the printer may require service.
  6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
  7. Turn the printer off.
  8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
  9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Jun 16, 2008
I have a 5650 lexmark printer and it keeps saying paper jams but there is not paper anywhere.. how can i find a solution... when you load paper it keepps getting stuck.. help
There could be something blocking the paper path. Try to shake the printer upside down. You'll be amazed of the things that falls off inside the printer. Also, make sure that there's no paper left inside the printer. Tiny pieces of paper will still lead to paper jams.
May 31, 2012 | Lexmark X5650 AllInOne InkJet Printer
Rear door paper jam
Here are some articles on rear door paper jam on Lexmark X646e printer. Just click on these links: ("202 Paper Jam" Message on a Lexmark X642e, X642e or X644e Multifunction Printer) and this link: (A 202.xx (x = any number) Paper Jam Message Is Appearing on a Lexmark X64x Series Printer). These are some guidelines on how to resolve the rear door paper jam on your printer. If you need more assistance, don't hesitate to contact Lexmark Technical Support. Thanks.
Jul 22, 2010 | Lexmark X646e All-In-One Laser Printer
ok im going to guess here that you are getting a 201 paper jam error with no paper in the printer. this would indicate a bad main motor drive replace it.
if its a 202 error check the 2 sensors on the fuser for stuck flags
if its a 241 error clean the pick wheels with aresol elctronic contact cleaner to remove the glue build up from them. or replace them
Dec 04, 2009 | Lexmark T640 Laser Printer
Lexmark x7550 printer jam. I cleared the jam and hit the check mark button as directed, but it keeps looping through the paper jam sequence. It does not seem to register that the jam has cleared. If I...
There will be some form of error clear code that would need to be entered. It would be something like "holding down the print key and powering on the printer at the same time" The manual may tell you.
There are different combos for different manufacturers.
Nov 17, 2009 | Lexmark X7550 InkJet Printer
Paper keeps jamming. seems tp be pulling to one side slightly.
Usually that is a sign of an object in between the rollers.
Check for paper or other foreign body. It will be located on the side that dragged.
Good Luck!
Tinteiros (Ebay)
Oct 31, 2009 | Lexmark X2500 All-In-One Printer
Canon Stylus C64 paper jam
try this link below. Although the printer is lexmark but it can used the idea to solve the problem regarding paper jam issue.
Jul 31, 2009 | Epson Stylus C64 InkJet Printer
Paper keeps jamimg
u break it and put it in the dustbin
Dec 13, 2007 | Lexmark X7170 All-In-One InkJet Printer
Lexmark All-in-One Printer with PictBridge Logo
579 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
