Akai s6000 sampler unused for most its life. Just when we need it it fails on the third full day. On power up the display is blank and all led buttong thats 8 under the screen stay fully lit. Power supply seems ok,...wonder if it is an eeprom or something. Akai dont support this. Any info most appreciated.
  • Darkred May 24, 2009
    Hmmmm Mine too! I am going to check the memory
Same problem with an Akai S5000.
Display gets darker because power supply outputs for the mainboard starts falling after start up.
Don't know if its the mainboard is causing the problem or is a problem of the power supply itself.
A S5000 service manual will be helpful.
Best regards
Posted on Mar 21, 2010
Mine died after a failed OS update...
After trying to get the update through the USB input and failing, I decided to put the s56v214.bin file directly onto a floppy disk and switch the machine on. It went through a couple of steps which were OK, then showed up the error message 'BAD FORMAT', it continued to work until I switched the unit off and on again.
Now I just get a blank screen and all the buttons under the screen lit. Nothing else seems to do anything.
Basically the floppy lights come on upon power up, and you can hear a blip from the drive as it tries to access something, maybe the system is not finding what it's looking for, or simply can't read the floppy in the drive. I have no idea beyond this. I've tried moving the jumpers on the motherboard (tried every combination with and without the internal battery), all that happened was different lights displaying on the front panel.
I wonder if there's some kind of system reset (most hardware has a combination of buttons you hold while powering up)?
Anyway, if anyone can help out, I would be most grateful.
Posted on Oct 15, 2012
I've just noticed that one of the caps on the PS is bad so this could be the issue. Planning to get that repaired this wk.
Posted on Sep 06, 2012
How do I fix akai TV model #lct2785ta? TV screen remains blank and black, after I power it on.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 15, 2015 | Akai Televison & Video
AKAI PDP5006H Plasma tv
1) Is the TV plugged directly into an outlet or is it plugged into another device, such as a cable box or audio receiver? If it is, try plugging directly into a wall outlet. Sometimes, devices like cable boxes don't provide enough current to power on more powerful newer TVs (like Plasma, LCD, etc) .
2) Check the manual to see if the flashing LED is a code for something you need to troubleshoot. The number and color of flashes may correspond to a problem that may or may not be easily fixed.
Hope that helps. Let me know how you make out.
Jan 15, 2008 | Akai PDP-5006HRB 50 in. Plasma Television
Where can I get drivers for my mpd 24 to work with windows
You should be able to get them from the AKAI website. Else, try here. http://www.driverscape.com/download/akai-mpd24
Oct 14, 2014 | Akai MPD24
Power saving mode
Power saving modes are automatic for some LCD monitors some have setting like after 20 ,30 mins to an hour the computer monitor itself will go into standy saving modes like power led switch indication go to yellow led lighting or the monitor of the lcd screen go blank if ur computer have no pictures for displaying as a screen saver modes.Power saving modes it best for uses if ur computer it on all day long.If u don't touch the mouse or a keyboard the monitor will go in the power saving modes for less electricities consumption for less stress for the monitor electronic components for working to hard for the monitor not to malfuctions sooner or the monitor life cut too short because the computer it on all day.
Oct 12, 2012 | Computers & Internet
RC1 - New batteries fitted but display still blank.
Hi,Not nessarly shot.The stat uses low voltage from the equpitmemt also.You neea a volt meter to check.Remove stat from mounting plate.Check power at terminals RH&W or at RC&G they should read 24volt.If not check emergency switch off or fuse/breaker.
Apr 15, 2010 | Heating & Cooling
2006 Akai 23" Led TV says it gets no signal.
hi, the input blocks are where you will need to look for this problem. sometimes these block connection become lose and detached from the main logic board. this could happen due to a minor crack in the solder or to much pressure when inserting cables and input rac jacks etc.. replacing or repairing this section of your TV's board will fix this issue.
Feb 25, 2009 | Akai PT4298HD Rear Projection Television
AKAI WONT POWER ON!
The power supply on your LCD failed and will need to be replace or repair.
Let me know if you need further assistance.
Aug 28, 2008 | Akai LCT3201AD 32 in. LCD Television
This is not a Samsung/Akai tv, but it is a cheap Chinese "counterfeit" tv. Here is the makers' info:
APH USA Inc.
5900 Canoga Avenue
Woodland Hills, CA 91367
United States
Phone Number: 800 837 4685
Fax: 818 702 2289
Nov 14, 2007 | Akai LCT3201AD 32 in. LCD Television
253 people viewed this question
 Grubhead
Grubhead
