Question about Dishwashers
My dishwasher is leaking water out of the bottom. Please help.
  • Shelton Tom Nov 02, 2008
    My LG leaks a slow steady drip when in the wash mode from the bottom left side corner. Is there a seal issue, door or hinge loose?? Is professional service needed??
  • 3 Answers
I do not recommend using dishwasher tablets, they get stuck in the sump and cause flooding.
Also try cleaning the filter in the bottom, under the basket. If it is full of food it can cause flooding.
Posted on Jun 11, 2008
Water leaking from dishwasher into my basement. Help!!!
I see the water leaking out the bottom plastic cover through the two little holes. I do not see water leaking around the top seal. I assume it is coming from a seal on the bottom.
Is there a manual that shows how to take the dishwasher apart to get to the seals? I have the parts sheet which shows the exploded views where the parts are shown. Much appreciated!
Mar 14, 2012 | KitchenAid KUDH03DTSS Dishwasher
Dishwasher leaking from bottom of dishwasher. Maytag Portable Dishwasher MOD MDC4650AWWO SER NW4610106
Hi
The issue is with the water not draining as something might be blocking the drain pump assembly thus the water is leaking. To solve this issue you'll have to take the front lower access panel out and then clean the drain pump assembly completely, also clean the impeller and chopper assembly located at the bottom of the unit. After this is done the issue should be resolved, if not then check the float switch mechanism and make sure that is fine. Hope this helps...please post back for further assistance.
Daniel
Jun 28, 2011 | Dishwashers
Dishwasher keeps flashing F1
F1 on your dishwasher is the fault code for leaking inside the machine. the water has caused the flood switch to activate. have you put any detergent rather than your normal dishwasher detergent into the machine? if you have, the water probably leaked out of your overflow, if not, then you have a leak on the top drawer or bottom drawer. the easiest way to check is to leave the machine off for a couple of days until it drys then turn on the bottom drawer to go thru a cycle.if the F1 comes up again then the problem is on your bottom drawer. if F1 does not come up then try the top drawer. please reply if you require further help.
May 28, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
The machine shows F1. Not sure what need to do with that. Also not sure what is the madel number. We got it when we bought the house. No user manual.
f1 is leak fault. water is leaking to bottom of unit which has a water detection device. if there is no water at bottom of unit then the board is faulty. r u confident to remove panels and check 4 water or if the board is faulty. if not ring 4 service, but if u want to try please reply 4 more help. it is complicated! even if it has water underneath then u have to find where it is leaking which is hard enough.if u do try to work on it please turn power off to unit, do not want any accidents. good luck.
Apr 09, 2010 | Fisher and Paykel DD605HSS 23 in. Built-in...
Belling IDW604
I found the solution myself. Underneath the machine, there is a plate. On the plate, there is a float and a microswitch, when the water leaks onto the bottom plate it raises the float and activates the microswith which shuts down the machine and shows E4 on display. To get rid of the fault, you have to pull out the dishwasher, then tilt it, and drain the water from the bottom plate. Also make sure that there is no leak in the internal piping, if there is, the fault will come back as soon as the recess in the bottom panel fills with water.Hope it helps.
Jan 20, 2010 | Belling 24 in. IDW603 Built-in Dishwasher
Water seeping out of dishwasher from bottom of dishwasher when washer is on. Washes and completes cycle ok, checked hoses and drains already for blockages but none
I assume you are seeing water coming out of the bottom of the door. If this is where it is coming from and the unit is draining okay then your door seal is bad.
If the leak is actually on the bottom of the dishwasher, then you have a crack or seal breach in the cabinet. It is important to find out exactly where the water is leaking from to determine where the problem is located in this circumstance.
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Dishwashers
Brand new dishwasher installed and water leaks out bottom of door
If your dishwasher leaks, check these:
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal Note…If the main motor of your dishwasher is mounted vertically, beneath thecenter bottom of the dishwasher, the following instructions probablyapply to you. But if your motor is mounted horizontally, the pump isn'tserviceable--you need to replace the entire pump and motor assembly.
Themain tub seal is beneath the drain impeller. It prevents the water inthe dishwasher from leaking out near the shaft of the motor. To get tothe seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal Overtime, door gaskets and seals harden and lose their ability to sealproperly. You can't repair the seals. You need to replace them ifthey've begun to leak.
Water-inlet valve Thewater-inlet valve, itself, seldom leaks. But, the water-supply linefrom the house and the rubber tube leading from the valve to the insideof the dishwasher may leak. Tighten or repair/replace these asnecessary.
The water-inlet valve could mechanically stick open.When that happens, the water continues to flow into the dishwasher,which then floods your kitchen. Turn off the water supply to thedishwasher, and replace the valve.
Hoses Behindthe lower access panel on your dishwasher are several rubber or plastichoses. If the leak appears at a connection, try a new clamp. If thatdoesn't work, replace the hose.
Dec 04, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Plugged in dishwasher and seems to be leaking from the bottow
does it leak when you don't use it? check around the fill valve.
Nov 10, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwasher leaked water once due to an outlet block, then won't start
It obviously has leaked water on the connections underneath, Lean the dishwasher back and see if any water comes out the bottom, then leave it standing for about a week to dry out and hopefully it should be ok.
Nov 26, 2007 | Baumatic 24 in. BFD60SS Free-standing...
Dishwashers Logo
118 people viewed this question
Top Dishwashers Experts
