Question about Maytag PYE2300AY Electric Dryer
Maytag PYET244AYW Electric dryer
Will work for about half the cycle and then shut off. If I let it sit for awhile I can start it up again.
  • 77 Answers
Could be an overheated motor, but always clean venting and make sure it is under 20' with fewer than 4 elbows. mat'l should be metal. filter housing sometimes get clogged also, look inside and remove any lint build-up. there should be very strong flow of air out vent with hose removed.
J
Posted on Jun 11, 2008
Our dryer heats for awhile, then shuts off. If we let it cool down,it will turn back on for awhile., then get hot, then turn off again
Check to make sure vent/air flow is not restricted.
Try to start dryer soon after it stops. If it hums and does not start, motor is cutting out.
If you touch the motor you will find it to be 'very hot' Touch only for 3-4 seconds.
Oct 18, 2013 | Maytag Neptune MCE8000AY Electric Dryer
I have a Kenmore Elite older model dryer that will fire the burner up when started, but when the burner shuts down and then tries to cycle on again, the glow igniter starts but no gas is released and the...
most likely its gonna be your coil kit, but it could also be ur gas valve,but the gas valve is not common. I would go with the silinoid coil kit first, its much cheaper too
Oct 11, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
Need to convert electrical Maytag Performa Dryer (Model:PYET244AYW) to propane gas system. It can be converted?
No that can not be done fairly inexpensivly...it could be converted but would actually cost more to purchase all needed parts that it would be to buy a brand new gas dryer
Oct 16, 2011 | Maytag PYE2300AY Electric Dryer
Dryer starts drying but shuts off after awhile
I'm having the same issue....also sometimes it will run all night...can anyone answer this post
May 29, 2010 | Maytag SDE4606A Electric Dryer
It starts out fine but shuts itself off after only a few minutes.
It appears that you don't have air movement through the machine. Check the vent hose and outside fixture for lint build-up. Vacuum the machine's inside pipe and underneath the lint filter. Wash the lint filter in hot water and detergent to remove fabric softener deposits (which will block air flow). Check for airflow outside when the dryer runs. Hope this helps!
Apr 02, 2010 | Maytag PYE2300AY Electric Dryer
Dryer shut off during cycle, unable to restart, does not start when pushing knob.
sounds like your blower is either clog, or the exhaust duct is clog with lint. also pull the front face off and clean out the location where the filter sits, they become clog over time and no ones cleans there. Your over heat protection circiut shuts down the dryer when it cannot exhaust enough air.
Jan 04, 2010 | Maytag PYE2300AY Electric Dryer
Maytag pyet244ayw---the dryer would not turn off.it had to be manually shut off. now, it turned off during a drying cycle. i can hear a whining sound when i tried to restart it.
Could be the belt.
Disconnect power.
Using a putty knife, slide it under the top and front panel of the dryer. There is one clip near each front corner. Pull up on the top panel while depressing the clips.
With the top up, you can see the drum and the belt should be around it and tight. You should be able to rotate the drum with your hand with some resistance. If the belt is not present then it is probably broken and under the drum. If this is the case, the whining you hear is the motor turning under no load.
Please post if this is the problem or if other to assist others with a siimular problem.
Dec 15, 2009 | Maytag PYE2300AY Electric Dryer
The Dryer stopped and will not start again
Just had a similar problem with our Maytag Electric Dryer. The dryer shut off mid-cycle and wouldn't start again, but the timer kept running. We purchased a "Thermal fuse replacement kit" at a local appliance parts store for $38 and replaced the fuse ourselves. The dryer is running great! Here's a couple of website links that were helpful in figuring out out how to replace the fuse: http://www.partselect.com/repair.aspx?appliance=dryer&part=replace-thermal-fuse
http://www.davesrepair.com/DIYhelp/DIYthermalfuses.htm
Hope this helps!
Jul 09, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Performa Electric Dryer Won't Start
check the blower wheel, sounds to me like it is loose on the blower motor, common on these dryers. One sure sign would be a warped filter and a rusted top. The blower aint putting out enough and the dryer is over heating .
/uploadswith image
Mar 08, 2009 | Maytag PYE2300AY Electric Dryer
MAYTAG PERFORMA PYET244AYW
It could very well be a thermostat problem, however, it could also be the drive motor itself starting to burn out. Some dryers are equipped with a "Thermal Limiter" that will cut the power to heat. It doesn't seem to be the case for you. I would defiantely look into another thermostat but if it comes down to the motor, depending on the price, You may want to buy a new dryer.
Apr 01, 2008 | Maytag PYE2300AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
358 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
