Question about HP OfficeJet 7410 All-In-One InkJet Printer
7410 all in one (fax)
I can not get my machine to receive a fax. It can send one. What do I need to do?
  • alli4203 Jun 10, 2008
    Yes, the line goes in a box that my DSL line runs in and yes, it has a different ring and number, but the same phone line.
    Thanks
    Alli
  • Jeffrey Pemberton
    Jeffrey Pemberton May 11, 2010
    Hi alli - do you have any other devices on the phone line used for your fax such as a answering machine? Does your phone line have a distinctive ring for your fax?
  • 667 Answers
Hey Alli - if the ring is a distinctive ring setup through your phone company you'll have to set your printer to answer that particular ring such as double ring, triple ring, etc. Also, you may need to get a DSL filter for the fax line. First try setting up the ring but odds are you'll need the filter to filter the digital signal. I could explain more in depth but if you have your manual it has pictures of how to set everything up and how to go through your menu. In case you don't have your manual I've included a link for it. You want pages 81-83 to begin with. Let me know what happens. If this fixes your problem PLEASE rate as fixed. If you need more help with this just add a comment and I'll be more than happy ro assist you further. Thanks.
http://h10032.www1.hp.com/ctg/Manual/c00235090.pdf
Jeff
Posted on Jun 10, 2008
Hello my fax machine keeps giving me error codes how do I fix this, I need my fax machine. thank you
Hit the setup button, select fax setup or setup fax, and make sure the option to "Junk" fax blocker is off. The default when you setup the machine itself is on yes. This helped me with my "error 410" message I received when printing fax log.
Mar 15, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Does magicjack allow the hp officjet 7410 to send and recieve faxes
You should be able to send and receive faxes with the majic jack.
Nov 01, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Error Code 244
It seeme the fax no you are trying to send fax does not receive fax in higher speed or might be it is a older fax machine than the one you have.
Try reducing the fax speed on your machine and trun off ECM mode.
Press Menu / Setup> Press the right arrow key till you see advance fax setup> and press Ok> Again press the right arrow key to locate fax speed> and press Ok> and reduce fax speed to slow> Press Ok. and cancell to come back to the main screen.
To disaable ECM mode>
Press Setup .
Press the Down arrow repeatedly until Advanced Fax Setup displays.
Press OK .
Press the Down arrow until Error Correction Mode displays.
Press OK .
Press the Right arrow > until either OFF or ON displays.
Press OK .
Send another fax to verify that the ECM is enabled or disabled.
Check the link bellow for a detail of all fax error codes:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02549&cc=us&lc=en&dlc=en&product=391194
Good Luck
Sep 25, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Hp 7410 all in one (fax)
I have to order a thing from the dsl to block the noise. I'll let you know what happens, Thanks for the hp booklet on line. I had some other things wrong and it really helped me.
Alli
Jun 10, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Whizzzzzing sound and will not send fax.
The problem is the power supply try to plug to different outlet and then send a fax if it fails then its a power supply fault please change it.............
May 27, 2008 | HP OfficeJet 7410 All-In-One InkJet...
FAX
Go into your set up (above the ok button and print report/fax log and see if they are showing up there. If not I do not believe it is a printer issue.
Apr 10, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Unable to send a fax
Is your fax correctly plug in the outlet line of the wall and the same in the back of your fax....????
Mar 25, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Fax not answering or receiving
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02151&lc=en&cc=us&dlc=en&product=391194&rule=44610&lang=en
Visit the HP Support and Drivers Home page .
Jan 24, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP 7410 fax tone when answering machine starts
you can only have it set to fax or phone at a time; the computer does not know if it is a fax or phone call. Therefore if you are running your fax software it will treat all calls as a fax. You really need two phone lines, one for the fax and one for the phone.
Dec 28, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
46 people viewed this question
Ben Johnson
