Question about Ovens
Cleaning cycle stuck whirlpool rbd245pdb1
Whirlpool double oven wall mounted accubake stuck in cleaning mode for no apprent reason. I removed the controller and it seems that at least 4 relays are fried- burnt ,but in the open position. There are 8 other relays that can't be veiwed. I assume that the entire controller unit must be replaced.
Model rbd245pdb1
  • lenes Jun 20, 2008
    Whirlpool RC8400XAB 1 XD1301800 lock lever stuck in cleaning position, how can I release it?
    EE
Whirlpool self-cleaning electric built-in oven #RC8400XAB serial # XD1301008. Self-cleaning lever locked. How can I release it???????
Posted on Jun 20, 2008
    Where is the controller, the over door cannot open?
I have a whirlpool accubake wall unit oven Took out door to clean glass now I cannot put door back together
you have a couple of hinges you have to pull out at about 45 degrees then slide door down on them and shut door
May 05, 2016 | Whirlpool RBD245PRB 24-inch Double Wall...
My whirlpool double oven accubake GBD307PDS09 display went blank!!!! HELP!
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty. GBD RBD Whirlpool Oven Problems Causes and Solutions
May 03, 2017 | Whirlpool GBD307PD Electric Double Oven
I have a whirlpool Super Capacity 465 self cleaning oven with accubake. About a month ago after using the oven to bake dinner the keypad button(s) became stuck (i figured this out after researching the...
Hello Michelle!
Crazy to hear, but this is actually a touchpad failure.
Luckily, we at FixYourboard.com have a solution.
Read more about the cause and fix in our blog! F5 E1 Error Code Whirlpool Built In Double Wall Oven
Feel free to contact us if you have any questions. info@fixyourboard.com
Mar 20, 2017 | Whirlpool 30" Self-Cleaning Freestanding...
Started the clean cycle but remembered that I wanted to remove the oven racks and quickly tried to turn off the oven but the door had already locked - now I can't get it to unlock - what happened? This is...
It can take 4 hours to complete. I also see that many people have problems with the temperature sensor "Blowing" after they use that function. When you do the clean special door interlocks activate and the oven heats up to like 900 degrees!
Feb 18, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
I used the self cleaning for the top oven of my double whirpool Accubake ovens today. It worked fine during the process. But now, after it has cooled down. The panel is not lit up with the clock etc. and I...
There is a non-resettable fuse on the back of the oven that will have to be replaced. The oven will have to be removed from the wall and the back panel removed from the oven to access the fuse.
Nov 22, 2009 | Whirlpool RBD305PD Electric Double Oven
Whirlpool accubake rbd245pdb no power to control
Make sure there's power getting to your range, oven or cooktop. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
If all check out ok with all the above, replace the ERC
Jun 19, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
We tried using the self clean on our Whirlpool Gold Accubake Duo system range. It locked the oven door and gave code e1 f5. We disconnected the power and turned back on to the same codes. HELP!!!!!!
take the trim peices off. take the screws that hold it to the wall out slidee unit out a little to remove the 2 screws from the consol lift the consol up and off. make sure that you have turned the power off inside the unit you will see a tech sheet that will tell you what that error code means. let me know how it goes the tech sheet is usually on the left side.
Jun 16, 2009 | Whirlpool GBD307PDS Electric Double Oven
Self cleaning oven won't start self clean mode
NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
Self Cleaning Cycle for Oven
I lost the instruction manual for my Whirlpool 30" Electric Built-In Double Oven and want to clean it. Can I get instructions for how to set the cycle for self-cleaning, etc.?
May 10, 2008 | Whirlpool GBD307PDS Electric Double Oven
Ovens Logo
511 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
