Question about Canon PIXMA MX310 All-In-One Printer
Where do i put the paper on a PIXMA MX310?
Where do I put the paper on a PIXMA 310??
  • 1 more comment
  • Anonymous Sep 12, 2008
    i cant load the paper
  • Anonymous Sep 30, 2008
    this is such a confusing printer.
    it is not obvious where you load the paper.
    there is a little trap door, so to speak, in the back of the printer. you wouldn't expect it, but you pull it out, and load the paper in that way.
    thanks for posting that link, i thought i was going crazy!
  • Anonymous Apr 25, 2009
    This printer is so confusing.
  • 2,012 Answers
Go to this link. Type "how to load paper" in the Search box and click Search. Now click on the "How do I load the paper?" link, and you will get specific, illustrated instructions for loading paper.
Posted on Jun 10, 2008
Not a problem,but I own the canon pixma 310 and I'm not sure how setting it up to print photos is different than regular document printing?
Hi! here is your solution. 1. Select your image. 2. Click your mouse i.e. right click. 3. Select Print. 4. There are many size for example 4x6 5x7. Chose your size you want to print. 5. Select Photo plus Glossy paper. 6. Press print. thanks
Sep 05, 2011 | Canon PIXMA MX310 All-In-One Printer
Hi my canon mx 310 is jamming all the papers sent through it goes in ok and once it hits the wheel that turns the paper it is pushing it to the right and ripping the paper
check for paper residue at the right roller...then...
.The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease.
Jul 07, 2011 | Canon PIXMA MX310 All-In-One Printer
How to replace ink cartrages in pixma 310 canon
Follow the link for manual on how to replace Fine Cartridges.
http://www.cybernates.com/manual.pdf
Refer page 69,70, 71
Hope this helps..
May 21, 2010 | Canon PIXMA MX310 All-In-One Printer
MX-310 has fax's in memeory but keeps printing the first page of the first fax only. Screen says check paper size. When i push ok it only will print the first page over and over. How do I change it?
If your Canon MX-310 has been set up to print faxes as they are received, then what is actually in memory is a "received fax report". If you select a particular fax in this report, it will print the first page of the fax to remind you of the content.
Your Canon MX-310 will store fax documents in memory if:
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
Dec 04, 2009 | Canon PIXMA MX310 All-In-One Printer
I have a canon pixma 310 that I need to
click here
Then download driver for your operating system like xp or vista.
Then connect usb cable of printer to usb ports on computer.
Then install driver from download .
Then it works fine.
Let me know if you need more assistance.
Thanks.
Oct 07, 2009 | Canon PIXMA MX310 All-In-One Printer
MX 310 says no paper.
try wiping off the rollers that grab the paper. sometimes the get dusty and can cause that malfunction.
Mar 01, 2009 | Canon PIXMA MX310 All-In-One Printer
BARRIE@NORTONBARRIE.CO.UK
RECEIVED IN MEMORY
If the machine receives a fax under one of the following conditions, the machine will not be able to print the received fax and will store it in its memory.
When the problem is resolved as described, the fax stored in memory is printed automatically.
bullet_s.gif Ink is low or has run out while receiving a fax: replace the FINE Cartridge.
bullet_s.gif Paper size/type setting is incorrect: correct the paper size/type setting.
bullet_s.gif Paper has run out while receiving a fax: load the paper and press the OK button.
bullet_s.gif Output Tray is closed: open it.
bullet_s.gif OFF is selected for AUTO PRINT RX: select ON.
bullet_s.gif You pressed the Stop/Reset button to cancel printing of a fax: press the FAX button.
Jul 18, 2008 | Canon PIXMA MX310 All-In-One Printer
Reset mx 310
This really worked with my MX 310:  http://www.fixya.com/support/t378057-reset_ink_levels_canon_mx310
Jul 03, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
5,253 people viewed this question
old marine
old marine
