Question about Refrigerators
Water inside the refrigerator
I have a Kenmore top freezer frost free refrigerator which worked fine until I put it in the garage. While it seems to cool and freeze properly, water accumulates on the shelves and in the vegetable bins. It appears that there is excessive condensation inside the refrigerator section. (The ice maker is not hooked up and I see no other source of water.)
    Genius:
  • 1,073 Answers
Check for a door gasket problem on one of the doors if it is not sealeing all the way you will get moisture in the fresh foor section and additional forst in the freezer
Posted on Jun 10, 2008
Why is ice build in my frost free/refergirator, and water dripping into refergirator?
Your Kenmore may not perform well in the garage environment. Since it isn't practical to move it back inside, you may have to abandon the idea of having a second operating unit.
Dec 15, 2013 | Refrigerators
I have a Kenmore Model 60192000, freezer on top and no ice maker. Have a leak on left side over top shelf. It is coming from apart in the refrigerator above the shelf, has kind of a square neck. I do I...
Is it a leak or a drip? A leak means you have continuous running water and a drip is more inconsistant.
I would suspect that you have a drip, that is caused by your cooling tube having frost or ice buildup in it, which is quite common for some units. The fix that seems to work the best is to defrost your unit, making sure the cooling tube is completely free of ice and frost by blowing hot air from a hair dryer down it. Then cutting a piece of bare electrical (solid core) wire that will fit down the tube but not extend past the opening. Then you form a hook and put it around your defrost heater.
That way the heat from the defrost heater will be transferred down the wire and keep the tube free of ice and frost.
Jul 28, 2011 | Kenmore 18.3 cu. ft. Top Freezer...
10 yr old, sits in a garage. Worked fine until a
is the fan operating,if so then check your damper vent door that throttles cold air from freezer to refrige compartment they can freeze shut and a hand held hair dryer will thaw them out,then adjust its control to make sure the door moves when control is adjusted
May 08, 2010 | Kenmore 72102 / 72104
Water is leaking under the refrigerator. This is
If everything else on the refrigerator seems fine (freezing and refrigerating are fine), then you probably have a problem with the drain hose under the evaporator coil. On frost free freezers, there is a heater that comes on periodically to melt off all the frost on the evaporator coil, and that defrosted frost (water) goes out a drain hose and collects in a pan at the back of the unit where it can evaporate.
Either the drain is clogged with ice inside the freezer, (in which case you might notice ice building up on the bottom of the freezer, or perhaps water collecting on the bottom of the refrigerator if your freezer is on top) OR there is something wrong with the pan at the back of the refrigerator, like a crack, or it somehow got tilted so that the water pours out. It is located behind the panel on the back.
Or perhaps, and this would really ****, the water line that supplies your ice maker is leaking, if you have one. If you do have one, I would recommend turning the water line to the fridge off before pulling the fridge out.
Sep 14, 2009 | Kenmore Refrigerators
Bottom of refrigerator is not cooling
Hi: Is your freezer so full it's blocking the vents? If so unblock the vents. If not put your food in a cooler, frozen and fresh. Unplug your refrigerator. Take a hair dryer to the back of the freezer to melt frost accumulated behind the panel. I know it's supposed to be frost free. You have a problem with the defrost heater or the timer. The frost is blocking the vents. Most likely it is the later, but if you see no frost it could be the circulating fan. The location of these will be in your parts list. Kenmore still gives these with their products. If you don't have it go to sears.com and use parts direct. They will have a diagram. I hope this helps, Jeff By the way, If you are not handy just do the hair dryer thing and it will work for a weed or two until the frost plugs it up again.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water is leaking on the top shelves in my kenmore refriderator water is leaking on the top shelves in my kenmore I have water leaking onto the top shelf of our Kenmore refrigerator. I believe it goes into...
During the defrost cycle heaters inside the walls of the freezer turn on to melt the frost. The melted frost "water" is supposed to drain into a pan under the fridge where it will evaporate. I think the drain line from the freezer to this pan may be blocked. I'd also check the seal on the freezer door. If it's not sealing well it lets a lot of moisture into the freezer which means more water during the defrost cycle. I'd also recommend checking to make sure the ice maker is not leaking.
May 31, 2009 | Kenmore 64802 Top Freezer Refrigerator
I have the top mount refrigerator - 4years old. Ice maker was installed then removed because it broke about 2 years ago. Suddenly I am getting a huge amount of water in the crisper drawer but no other...
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer side works fridge side doesnt
    click on the required option.
Feb 20, 2009 | Kenmore Refrigerators
Kenmore frost free refrigerator
Hi thanks for te question .If all the coils are frosted. no its not going into the defrost cycle. and you also have a problem with a clogged drain thanks the appliance doc
Sep 18, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore refrigerator not cooling
Is there frost on the back wall? If so your coil is frozen up and you have a defrost problem. The water coming out of the freezer door could also be caused by the same problem.
May 05, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
213 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
