Question about T-Mobile Wing™ Smartphone
Jas jam screen can't align
Hi I tried the hard reset twice and i failed to align my screen it is getting worse i even can't use my touch pen on it why i don't know why keys are ok lights on keys are fine help me pls asap
zozo
  • buddy0225 Jun 14, 2008
    cracked screen on wing. how do I realign it
Tap the screen with thumbs very lightly,sounds funny but it worked. then use a stylist after wing recognizes the taps
Posted on Jun 11, 2008
My htc tytn II screen suddenly became unresponsive to the stylus or even my finger. I can only open my screen lock through the keyboard which worked but takes longer time to use. many commands can only...
Hi. You need to replace the digitizer. This happens to many touch screen phones from all brands.
you can purchase from:
http://cgi.ebay.com/US-NEW-HTC-TyTN-II-TILT-8925-TOUCH-SCREEN-PAD-DIGITIZER-/350435156469?pt=LH_DefaultDomain_0&hash=item51979021f5
After purchasing you can have it replaced in a cell repair shop or similar shop. Or you can chose to replace it yourself.
Thank you for using fixya.
May 24, 2011 | HTC TyTN II Smartphone
The touch screen is not working on my Samsung Epix. Tried a hard reset, now the align screen is up and, with touch screen not functional, I am unable to align screen. Stuck.
If your Touch screen has failed, then the only thing you can do at this point is to get a replacement for the phone.
You can call AT&T's Warranty Line at 1-800-801-1101 and explain the issue. The will ship you another device - but be aware that it'll likely be a refurbished phone.
Dec 12, 2009 | Samsung Epix Cell Phone
Palm treo smartphone upon reboot gets stuck on "align screen"
yes u cant exit the screen until u do the align test for the touch screen its a easy fix on the back of the phone on the left side top there is a hidden pen that comes out of the phone and when u get the pen out use the point of the pen to touch the center of the circle on the align screen test it will ask u to do this in every corner of the screen after that the phone should get out of the align screen test and be able to work good luck
May 29, 2009 | Palm Treo 755p Smartphone
Hi i have a I9 phone and the touch screen is acting up
The factory reset code is 1122 or 2211 it's one of these I just dont remember it exactly
Dec 08, 2008 | Dual Electronics CECT P168 Cellular Phone
Screen problam
Have you aligned the screen?Go to settings,click screen folder and tap align screen.
Sep 03, 2008 | i-mate JAM Pocket PC
Touch screen doesnt work
you will find a screen on www.ebay.com.au, or prefferrabl you can go into any phone hardware store loated near you to solve your issue.
Jul 15, 2008 | BenQ P50
I-mate, K-Jam - screen input does not always work
DO YOU HAVE INSURANCE? YOU NEED TO BRING IT BACK TO YOUR CARRIER SO THEY CAN FIX IT FOR YOU OR EXCHANGE IT WITH A BETTER PHONE .
Jan 01, 2008 | i-mate K-jam Smartphone
Cant get out of screen alignment program
OK, Now anyone watching this forum can hear the truth. Well start with how to get out of the designator, however this will make the screen out of alignment by about 2mm. tap on the corner targets until you get to the center one. Try tapping off to the side top or bottom of the target further and further away until the program exits.
To fix the problem first try using the corner of a piece of paper and run it along underneath the plastic covering the edges of the touch screen. Use as much force as you can without creasing the paper. Do NOT press down on the touch screen!
Other than that the reason why you can't tap on the center of the last target is either a marked or damaged screen. Look at your screen carefully and identify any smears, marks or fingerprints. Clean these using a soft cleaning solution (such as for camera lenses etc.) and try the designator again. If this does not work look for scratches. If these are found in the area of the target then sorry, but you can never designate your PDA again.
Dec 08, 2007 | Palm Tungsten E2 (Multilingual) Handheld
K jam screen align does not work after hundred or so attempts
Well, folks i had the same problem with the damn i-mate K-JAM model but i have figured out its solution. Well screen alignment options will always come on ever reset whether it is hard or normal and further more it would be nail biting for most of us because it doesn't work at all. It seems like some sort of a bug either in Windows Pock PC edition or HTC manufacturing bug. Whatever u call it only we would be the victim of it. Here is the solution.
When the alignment screen comes Just Tag the {+} << in the exact centre it will then move to the top let corner of the screen again tag it from the middle and it will then jump to the lower left corner now don't tag it from the middle instead tag the lower left corner of the screen. It will then move to lower right corner of the screen now tag it again in the middle and finally it will fly to the top right corner now again instead of clicking in the middle just hit the top most right corner of the screen and now u r done. Screen is finally aligned whoops!
Sometimes even when the screen is aligned the touch pad malfunctions if this is the case with you u need to update the firmware like i did just search through Google the i-mate k-jam windows Pocket edition update.
Thanks
Jun 25, 2007 | i-mate K-jam Smartphone
They can tend to have a freeze now and then Make sure you havent overloaded your memory & make sure your screen isnt slightly open mine refuses to answer ever now & then when someone rings it drives me crazy
Jun 07, 2007 | i-mate K-jam Smartphone
T-Mobile Wing™ Smartphone Logo
52 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
