Question about Toshiba Satellite P105-S9722 Notebook
Toshiba satellite p105-29722 overheating/vid car
When i play games the computer gets so hot it will burn my legs if its in my lap...i tried finding the proper video drivers for it but it seems iits only supported by windows vista...but the laptop came loaded with windows xp. just browsing it seems the fan turns off on the inside... also when it gets hot it seems the machine hiccups and goes from 60fps to 4-7 fps...ive tried different home-made drivers but i cant get it to function properly...thanks
  • flamdrag Jun 14, 2008
    I have the same problem.
    I even purchased a notebook cooling pad with a lot of fans.
    I believe the problem is the fan for the video card.
    I can hear the fan kick on once in a while but it shuts off within 2 or 3 seconds.
    If anyone has a solution please let us know. Thank you
I recently had the same problem. I had just updated the drivers for the Nvidia card and after that the fan stopped working. It would cause the computer to overheat and the screen to shut off. I reverted my computer to just before I updated the drivers and the problem went away. If you recently updated your driver you might have the same problem. I play several graphic intensive games and dont have any issues as long as the fan is working on the video card. It will get pretty warm even with the fan working.
Posted on Oct 17, 2008
I had the same problem. I sent it back in to Toshiba and they fixed it.
The problem was the fan on my motherboard. I think it had some bad bearings because it would run sometiems and not others; and when you would hear it run; it would do a lot of clicking.
It was overheating the core, and while I was playing games it would just stop processes.
Just call up Toshiba and tell them; they should let you send it into the UPS store for free. It will take about a week or two.
Posted on Jul 10, 2008
L455D-S5976 fan
Your laptop is getting too hot therefore you need to place in on a wooden surface like a table instead of your lap to prevent it from getting overheated.
Jun 06, 2012 | Toshiba Satellite L455D-S5976 Notebook
Toshiba Satellite P205-S8811 all of a sudden it shuts down when i try to play games.
Sounds like it's overheating.It's a common problem with alot of Toshiba's.
Nov 25, 2011 | Toshiba Satellite P205-S8811 Notebook
Toshiba a30 laptop over heating problems
It is obvious that your computer shutdown because it is overheating. try to get a chill mat to place it under computer. you said that it does not shut down when is on battery??? do you play games when is on battery?....computers normally overheat during large processing tasks such us playing video games. Try to fans clear do not place your laptop ontop of your bed or anything that will obstruct the fan under computer.
See if that works
best luck
Apr 10, 2009 | Toshiba Satellite Pro A30 Notebook
Overheating
Hey,
wow at the scars thats bad. I would suggest you use a cooling device under the laptop. And blow the dust out from the fans with canned air.
look around on ebay for one that fits your budged and the size of the laptop
http://computers.shop.ebay.com/items/Laptop-Cooling-Pads__W0QQ_armrsZ1QQ_mdoZComputersQ2dNetworkingQQ_msppZQQ_pcatsZ31530Q2c58058QQ_sacatZ96915
Let me know if you need anything else.
if you want me to recommend one let me know.
Thanks,
Ekse
Feb 17, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite L15-S104 Gets VERY HOT
Make sure that there is good air flow all around the laptop, including the bottom. By resting it in your lap, you may be constricting the air flow. This is one of the reasons why laptops are now called notebooks! They really don't work well on your lap. When I use my notebook, I make sure that the fans have a clear path so that I don't have this problem. Try that and see if it works. You could also use a notebook cooler. They run about 20.00, depending on the type and size.
Feb 03, 2009 | Toshiba Satellite L15-S104 Notebook
Computer shuts down on its own
Usually what gives these types of sighns is that the laptop is overheating.
It hasn't cooled down yet and that's why it will continue to reboot a couple of times it's a safety catch so you don't fry anything within the laptop.
A couple things you can do put it down on a hard surface when in use do not cover the bottom vents that let's the computer breath and cool down.
Also they sell in many stores you will see laptop coolers.
They are flat and light which you put your laptop on there's fans on the bottom that blow up at the bottom of the laptop to keep it cool
I use one it let's the laptops life last longer plus it don't burn the legs or heat up the legs while on the laptop.
Happy Holidays
Dec 25, 2008 | Toshiba Satellite M205-S4806 Notebook
Overheating
Its pretty easy to tell when your laptop is overheating. Youll have those tell-tale red marks on your legs from where the hot bottom of the laptop has been resting against your legs.
Fortunately, most laptops will automatically shut down if they are over heating to prevent any further damage to hardware like hard drives and motherboards.
If you would like to know the running temperature of your laptop, download this little utility.
Hope this helps,
TJ
Dec 15, 2008 | Toshiba Satellite A35-S1592 Notebook
My toshiba wont start it keep's restarting at the black loading screen.
have you done a maintainance on it to get rid of all the excess information?? if not..go to start--then all programs, then accessories, then tools, click on disk cleanup. click on yes to all when the pop up box show up.
after this do a defragmentation-- go to start, all programs, then accessories, then tools, then disk defragmenter. click on analisys-- this will tell you if you need to defrag your system. if yes-- do it..it will take time to defrag, but it will speed up you game play ability.
Oct 13, 2008 | Toshiba Satellite P305D-S8828 Notebook PC
Toshiba Laptop overheating
Your Problem is of overheating the unit.
Pls check the Air exhaust of the Laptop. The fan may be blocking air and may be causing the processor hot. It's better to
service the Laptop if problem still persists.
Viren
Jul 17, 2008 | Toshiba Computers & Internet
TOSHIBA LAP TOP A135-S4656 SCREEN WENT BLANK BLACK
over heated the video area in it will have to cheak video card inside or motherboard chips on it got to hot when u play games on labtops u must ua labtop cooler never set it on your bed
Jan 27, 2008 | Toshiba Satellite A135 Notebook
Toshiba Satellite P105-S9722 Notebook Logo
251 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
