Question about Dell Dimension 2400 PC Desktop
Integrated Ethernet Port Fried/Trying to Reformat
I have an integrated ethernet port that fried some time ago, I have been using the USB connection for my dsl instead. I recently went to reformat my computer and when it gets to installing the internet devices while installing windows again, it automatically shuts down and the blue screen comes up. Would that have anything to do with my ethernet port being fried? And if so, would adding an ethernet card bypass that problem? The only trouble I came across with my computer was when the ethernet port fried and when my dvd drive stop working, which i replaced already. I don't really want to get a new motherboard unless i really have to. Any help would be appreciated.
Thanks!
  • 1 more comment
  • quiksilver49 Jun 10, 2008
    The blue screen just says it detected a problem and automatically shuts down to prevent any problems. There was no problems with my comp aside from the ethernet being fried. I was thinking of just buying a ethernet card to see if that would do anything, but figure I check on here before doing so.
    I was looking at the BIOS but i dont recall seeing the option to disabling the onboard ethernet.
    I will check again when I get home as I'm at work at the moment.
  • quiksilver49 Jun 11, 2008
    Thank you. That definitely solved that problem.
    But then I mess up again on something else :-(
    Separate post made
  • Tim Babcock
    Tim Babcock May 11, 2010
    I don't think that has anything to do with the ethernet. What does the blue screen tell you?
  • 20 Answers
In the Dell BIOS you can disable on-board LAN by going into the BIOS (hitting F2 at the Dell splash screen), scrolling down to Integrated Devices, and then selecting "Network Interface Controller" (keep hitting left/right until "OFF" is selected.)
Save changes and exit.
Posted on Jun 10, 2008
Try going into the BIOS when the computer starts up (F12 at the Dell Screen I think) and disable the onboard ethernet and see if that helps.
Emachine doesn't recognize the ethernet cord when plugged in
Sounds like the integrated ethernet port has gone bad. You can install a new ethernet card in one of the PCI expantion slots. Then plug the ethernet into the new card, this should take care of the problem. You can not repair a bad integrated ethernet port.
Feb 20, 2012 | E-Machines eMachines Desktop PC
I can't get on line via the Ethernet receptacle. I'm using a MSI Ma inboard # K8MM3-V, installed in my Dell Computer. The original Motherboard was struck by lightning a couple years ago and...
Then the onboard Ethernet circuit has also been fried. Go in the BIOS and disable it then install a simple PCI LAN card (that can be bought for less than $15 at every pc shop) to get a new ethernet connection.
Sep 04, 2011 | MSI K8MM3-V Motherboard
Dear Sir/Madam, I have a notebook TM8572T-484G50 which I put into EZ Port IV port replicator to use it as a desktop. However, when I connected the network cable to the port replicator, it doesn't...
It appears that the ethernet connection from the laptop to the replicator is bad.
This will likely need to be serviced by a qualified Acer repair facility.
Your other option (likely cheaper too) is to simply get a USB ethernet connector to use when it's docked.
Feb 25, 2011 | Acer EasyPort IV LC.D0100.020 Port...
I have an older model armada 7800 that I am trying to get connected to the internet. Where does the ethernet cable go on this model? The only place I see for it is in the back, but the cable does not fit...
It may not have a place for an Ethernet cable. These older laptops required special cards to be attached to them or inserted into a special port for them to work with an Ethernet cable. The port your referring to might be for a phone cable which means it would have a modem and be dial-up only.
Oct 28, 2010 | Compaq Armada 7800 Notebook
I have a hp pavilion 563w, it will not connect with the internet. I was told that I need another motherboard. It has been tested. How do I know if the motherboard is the same as mine??
The HP 563W has an integrated ethernet, so it is conceivable that the eth chipset got fried. I'd run some tests to be sure, actually: it's not so common an occurrence, and usually you fry the whole motherboard when it happens.
But even if you got yourself a deep-fried ethernet, you don't need to replace the motherboard and go through the hassle of replacing the hardware and reinstalling the OS (unless you get an exact clone of your motherboard).
If you have an available USB port, nothing stops you from plugging in an US$ 20 USB-to-Ethernet dongle and use that to connect to the Internet. USB is four times as fast as an Ethernet, so it won't cause bottlenecks anyway.
Oct 28, 2009 | HP Computers & Internet
Ethernet port does not work in computer. The cable company set up a USB connection which worked, but now I installed a wireless router. The ethernet cable from the pc to the router does not show a...
Here are some things to check.
  1. In the system setup, ensure that the network adapter is enabled.
  2. Check device manager and see if the driver is properly installed.
  3. If the integrated NIC doesn't work, you can disable it in the BIOS and install a PCI NIC (Less than $20) and the system will work that way.
Sep 30, 2009 | Dell Dimension 3000 PC Desktop
There is only a phone port and the types of cord thats connected to my dsl are different what type of cord do i need is there a universal one
the one that connects to your dsl should be Ethernet. Are you sure there is no network port on your PC? the image below shows where this port is. does the dsl fit in here? cf5ca22.jpg
Jan 27, 2009 | Toshiba Satellite 1805-S253 Notebook
Replacing an ethernet port on my hp pavillion
Your ethernet port is probably integrated into the motherboard of your computer. Have you tried reinstalling the driver for the ethernet?
If the port is truly bad, my suggestion would be to purchase an ethernet card or NIC (Network Interface Card) and have it installed. You can get them for $15 to $25 at any big box computer store.
Nov 04, 2008 | Computers & Internet
Ethernet for my dell 4600 pc
No, you don't need a card, as long as you have an Ethernet to USB adapter, you should be just fine.
Feb 19, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 2400 PC Desktop Logo
204 people viewed this question
Alun Cox
