Question about Sharp AL 1631 Copier
Got a alternate 4- h
Flashes 4 the h
any ideas ??
thks
  • Sharp Master
  • 2,794 Answers
Thats a heat roller low temperature detection error. It needs to have the thermistor and the heat lamps checked.
It may need a whole new fuser assembly.
Posted on Jun 12, 2008
MERCEDES C200 Kompressor 2001. battery alternator visit workshop is flashing on trip computer. i have replaced alternator. everything is ok. battery getting charge... i cant see any thing wrong so why...
You must check max voltage output on alternator, the cars electrical sysyem is prone to damage if regulary overcharged as this effects nearly all the sensors and management componants.
Apr 03, 2010 | 2001 Mercedes-Benz C-Class
Flash player dosent work cause i have filter(access denied) by administrator please tell me how i change flash player by another one and how to disable flash in my pc thks
If a flash player is installed it is difficult to remove or disble from your pc.In order to remove flash player you have to download aflash player remover.You can easily get one by searching it on the internet.
Mar 03, 2010 | HP Pavilion dv6000z Notebook
P-reg 96 escort, my battery is dead after only a few hours however when the car is running (after jump starting it) the immobilisor light comes on for about a minute, then starts to flash every 3 seconds....
Bad Alternator.
After Starting or Jumping your vehicle: Remove the Negative Cable from the Battery.
If the Engine dies or runs really rough it is a bad Alternator.
The Battery Starts the Engine and runs nominal operations. The Alternator runs the Engine after it is Started by the Battery.
If the Engine does not die or runs really rough after removing the Negative Cable, then you have a malfunctioning Battery.
Let me know if this helped, or if you have additional information or questions. Feel free to contact me at FixYa.com!
Feb 25, 2010 | 1996 Ford Escort 4 Door
Battery alternator visit workshop is flashing on
MERCEDES C200 Kompressor 2001. battery alternator visit workshop is flashing on trip computer. i have replaced alternator. everything is ok. battery getting charge... i cant see any thing wrong so why workshop flashing?? maybe something wrong with new alternator 4 exampel voltage sensor??
Jan 02, 2010 | 2003 Volkswagen Passat
Hyundai getz 1.1
Wow...good one, need to know what model and year also I strongly suggest you buy a diagnostic tool (around 50$ in Canada at Canadian Tire) which you can just plug in a connector in you car (under dash on driver side..easy..) especially if you are into used car, not only it will save you money in the long run but you will have a good idea about where the problem is located and won`t get screwed around when you go to a garage for repairs....believe me!, I bought one and would not let it go!.
thks,
Lucus123
Apr 02, 2009 | Hyundai Motor S Cars & Trucks
PC with poss ASUS A7N8X - VM motherboard problem
Can you give me motherboard & pc infoinfo, the symptoms certainly suggest mobo failure
Dec 02, 2008 | AMD ASUS A7N8X-VM/400 Motherboard
LG 36" LCD Flashing Picture
Most likely cause:
Backplane lamps, and or the backplane power supply is defective.
I don't know the particular model, but in most of these models, these parts are replacable. I suggest giving out the set to a tech who is experieced at doing this type of work. The parts would have to be ordered from the manufacture.
Jerry G.
Jul 01, 2008 | LG DU-37LZ30 37 in. LCD HDTV
Nikon SB - 800 LCD Defect
Impact has damaged the LCD assembly .
IF you want it repaired contact the email address below
Berrie Smith Camera Repair
bbmw@bellsouth.net
Oct 29, 2007 | Nikon Speedlight SB-800 TTL Flash
Sharp AL 1631 Copier Logo
64 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
