Question about Motorola Mobility RAZR V3m Cellular Phone
No display in my motorazr
I dropped the phone down and the left top silver thing is broken.The display does not light up at all..The keypad lights up.I can hear the sound when i press the keys..Plesae help me.This is my husband's phone.He is not talking to me properly after i did this..If this phone can work..then i am very thankful to u...
  • 20 Answers
Chances are if the screen isn't working (even if it appears white, or a deep blue) the ribbon connecting the board to the screen is damaged. If there is someone in the area that repairs phones (look for someone that installs them that's not a stereo shop or ask your carrier about one) he can probably repair it for $20-$40 with used parts. Your easiest bet would be to file an insurance claim if you have it on your account. Make sure and save your phone since contacts can be transferred at the store (even in this condition) and you can still sync the phone, or use a memory card to save pictures.
Posted on Jun 16, 2008
Need to clean laser **** glass
reply +/- I just stumbled across this site and this post. I don't know if you still need this but I had to do this very same maintenance on my 2210xi.
The top frame that holds the glass is held on by 3 screws. You'll need a Torx T-15 screwdriver to remove them. One is really obvious. It's on the left hand side, at the back edge. The other two screws are under the silver plastic plate that frames the keypad and the LCD display.
Here's what you do:
1) remove the flip top lid by pulling it gently upwards. It should snap out.
2) Remove the silver plastic keypad cover that frames the buttons. It's the one that has the "hp psc 2210xi all-in-one" printed on it. Remove it by inserting a small screwdriver about an inch down from the upper right hand corner (next to where it says "Photo Card") and prying it up gently. This helps to loosen a retaining tab. There's another retaining tab about 2-1/2 inches below this one. Work the keypad cover loose.
3) With the keypad cover off, you'll see a small square hole just below the black print button. Push a small screwdriver down into this hole. You'll feel a little springy resistance from another plastic retaining tab. While gently holding the tab down, slide the silver keypad/display assembly toward the front of the printer. It should slide forward easily. Don't move it so far that you damage the flex circuit cable that's attached though. Take note of the two screws we're looking for. One is at the right rear and one is at the front.
4) Remove the three screws (back left, back right and front right). Lift the plastic
top frame off starting from the back. There are two retaining tabs along the front edge (on the left and in the center). With very little effort, you should be able to get past these.
5) The glass should be accessible now.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : HP Support
Mar 04, 2014 | Brother HL 5150D Laser Printer
Display problem in motorazr
Try pullling the battery out for 10-20 seconds. PUt it back in, and press and hold the power button for 5-7 seconds. Until it lights up. If it doesn't light up, or doesn't respond, nor makes any noice. Test the battery with another RAZR. Or, if you have another battery, test with another battery. To narrow it down to whether its a phone or a battery issue.
Plus, you wanna make sure the phone is shut down once a day for about 10-50 seconds. To refresh it.
Feb 08, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Moto roker E6 is not power on
use your travel charger,connect it to your phone, does the battery indicator went up? if it does, it means the on-off switch get broken, fix the on-off switch only.
if the indicator doesn't go up. try another battery, is your battery broken?
if another battery(probably u can borrow from ur fren who has the same phone or same type battery) doesn't solve this problem, here the hard part goes..
1. did your phone just fell down hardly ? if it did, ur phone got to be fixed by professional technician, probably some component inside get broken.
2. did ur phone just get dropped to water, or just face a lot of water splash? if it did, the water can cause short electricity problem to your phone's component..
3. notice if any light, any sound come out from ur phone when you switch it on, if there's light on the keypad, or any start up sound or keypad's tone when u press it, it means ur phone is ok, just the LCD (display)
4. If none of above occur to ur phone, ur phone might face software problem. fix it to the professional technician.
Hope thissolve ur problem.
Nov 12, 2008 | Motorola Mobility ROKR E6 Smartphone
Display problem!!
Hi there polarized.
All you need to do is this.
1. Switch your mobile phone off then switch it on again.
2. Click the MENU button which is the top left keypad (the silver colored one)
3.Scroll down once, then to the right once.
4. Click the MENU button again.
5. Scroll down twice. Click MENU button.
6.Scroll down once or twice and click MENU button again.
This should either reset your theme to the default themes.
Nov 09, 2008 | Sony Ericsson T280i Mobile Phone Silver on...
Keypad light n display light not working
display light and keypad not working i have changed keypad light ic and keypad coil what to do?
Jan 11, 2008 | Nokia 6070 Cellular Phone
Motorola V265
1 of two things: Go into your settings and look for either "Keypad" or "Display" and see if keypad lights are set to ON.
2. Your phone does have a light sensor built into the keypad, normally the keypad will not illuminate unless insufficient lighting conditions are present. If it's pitch black out and the keypad still isn't illuminating and your settings have the keypad lights ON .... You should bring your phone to the nearest Verizon wireless corporate store to see about either replacement or upgrading.
Tanya
Dec 19, 2007 | Motorola Mobility V265
Keypad tones - D900i
Change the dialing font style to Normal and then set off keypad tones on setting menu.
Oct 07, 2007 | Samsung SGH-D900 Cellular Phone
Motorola RAZR V3m External Display Problem
Ive had 2 silver razrs and my first did the exact same thing it's a sensor intenally that wears out ecspecialy on the silver ones dont ask why? But i sent my back and replaced it. If you pay insurance everymonth like me use it!!
Jun 01, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3m Cellular Phone Logo
55 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
