Question about Magellan eXplorist 500 GPS Receiver
Error Message on Explorist 500
Did you happen to get a solution to your problem with your Explorist? I am also having the same problem after updating the system.
(unit displays press ENTER to configure NAND........)
  • darylr Nov 03, 2008
    I have the "UNIT CURRENTLY CONTAINS NO MAP! - INITIATING MAP UPLOAD"
    report on my Explorist 500. When plugged in to PC it will recognise the
    SD card but will not recognise the internal memoery. Plugged in to PC
    and switched on it firstly checks media then to the globe screen and
    asks to press "enter".Then asks for language selection which I select
    english and press enter. It then goes to "WARNING!" screen which I
    press enter to agree. It then momentarily goes to the sattelite screen
    and then to USB file transfer screen "Press enter to select different
    USB mode" At this point the E: drive screen appears on the PC screen. I
    have reloaded the basemap but when switched on it still cant find the
    map.What does "Initiating map upload" mean. Where is it uploading from?
    Darylr
    Problem Solver:
  • 14 Answers
With you 500 turned off press nav + power; then change the numbers 00 in 95 by using the joystick and and then press the joystick itself; accept what proposed.
after turning the gps on again and pressing enter the NAND will be configured and your gps will become in order again. if necessary, in usb file transfer mode, reload the basemap in the directory background maps
Posted on Jun 13, 2008
Cant not get watereays on explorist 500 in canada
You can try to update your GPS firmware.
Before you update your Magellan eXplorist 500 firmware or install a custom basemap, Magellan recommends that you backup all of your GPS data.
Click here to download the firmware update (Version 2.57)
Connect your Magellan GPS unit via the USB drive.
Double-click on the update file to begin the installation process.
Follow the on-screen instructions .
Jun 17, 2011 | Magellan GPS
No base map message
heres the basemap
http://rhamphorinkx.newmail.ru/maps/na_lb112%20(ex_400-500-600_na).rar
Copy attached "BASEMAP.MGI" to eXplorist, in "Background maps" folder.
These downloads are in rar compressed format if you need a free decompressor one can be downloaded from www.rarlabs.com
Jun 28, 2008 | Magellan eXplorist 210 GPS Receiver
Magellan Explorist 500
The necessary map software is not installed - did you buy the unit with software?
Mar 19, 2008 | Magellan eXplorist 500 GPS Receiver
Hi Guys: On turning on my explorist 400 a message appears. UNIT CURRENTLEY CONTAINS NO MAPS! INITIATING MAP UPLOAD This message wont go away, and all buttons refuse to work. The only way I can turn it off...
Jeff, I had the same problem with my explorist 500. Your unit lost the "BASEMAP.MGI " file. You will need to get a copy of that file. Then install it.
Try this site http://imhz.com/2006/05/my-explorist-is-screwed.html
(I would recomend all explorist GPS owners copy and save that file and store it in a safe place. I have mine on a thumb drive).
Dec 05, 2009 | Magellan eXplorist 400 GPS Receiver
Help Explorist 500 jammed (locked up) wont even turn off
To speed things up a bit with frozen Explorists, you can undo the battery cover and pull out the battery then replace and start again. I have had to do this many times.
Jun 10, 2008 | Magellan eXplorist 500 GPS Receiver
NMEA communication does not work ( but file transfer is OK)
Try rebooting windows, with gps off connect the cable to gps.
Go out side get a good gps signals on nav menu.
Set the gps communications menu to , nmea, 2.1
Plug the device into a good usb port.
If you look under modems, in control panel you should see a new modem called explorist xxx
If you look at the properties for that you can see its com port number.
I just tried this program http://www.visualgps.net/VisualGPS/
and it views nmea from the explorist, just set the com port to the one in the explorist modem .
Jun 06, 2008 | Magellan eXplorist 500 GPS Receiver
No map
Install the firmware again:
Go to: http://www.magellangps.com/support/product.asp?prodid=1114
Or, if this doesn´t work, go to www.magellangps.com, click on "support", click on "legacy products" (left) and click on "eXplorist 210 Europe" (do NOT click on "eXplorist 210 North America")
On this page click under Updates/Upgrades on "version 2.57", and follow the instructions. You will have to register your GPS, register it under a European country.
After you have installed the firmware you will have the basemap and some new windows on the GPS. Good luck and enjoy!
Apr 13, 2008 | Magellan eXplorist 210 GPS Receiver
Magellan
You can download the US basemap for the 500 at
http://www.megaupload.com/it/?d=EJTNQH03
Rename it BASEMAP.MGI
Then copy it in the directory "background maps" in the SD card of your 500, by using a SD card reader/writer.
Insert the SD card in your 500 and connect it to your PC; then turn it on;it will turn on regularly, because the basemap in the card will be detected; turn it to USB file transfer mode, and copy the basemap from the SD card to the directory "background maps" of the 500.
Mar 28, 2008 | Magellan eXplorist 210 GPS Receiver
Explorist 500
Dec 28, 2007 | Magellan eXplorist 500 GPS Receiver
Fault mesage on screen when first strat magellan 500
Sep 04, 2007 | Magellan eXplorist 500 GPS Receiver
Magellan eXplorist 500 GPS Receiver Logo
436 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
