Question about Microsoft Xbox 360 Controller
My batteries in my controller don't stay in
Every time i put the batteries in the controller they keep popping back out. Is there anyway to fix this problem or do i have to get a new controller?
  • dmags2000 Jul 07, 2008
    the battrie pack will not stay in
Tape it...
Posted on Jul 04, 2008
Airbag light comes on and stays on what can i do on a very fixed budget no money for car repairs now would like to fix on my own but how
Hi Greg there are several possible causes. The connections under the seat. The air bag squib under the stering wheel the control units. First you need it pluged in to find out which one. Then you can discied where to go from there. Regards Jim...
May 09, 2015 | 2000 Hyundai Elantra
2006 volkswagon jetta
well you can always reset the cars computer by simply unhooking the battery which will make all the lights go away, but if there is a problem with the car, they will come back on within an hour or two from unhooking the battery. but you may get lucky and they may stay off.
Jun 03, 2013 | Cars & Trucks
I cant use my controler because the green part keeps bliking and wont turn on so i cant play my xbox 360
I had this exact same issue the other day. Changing the batteries did not work for me, but don't cross that off of the list quite yet. This worked for me:
1.) Pop the battery pack off of the controller. This is the only way you're going to be able to turn it off. Wait about 5 seconds and put the battery pack back into the controller.
2.) Turn on your X-Box with the power button ON THE CONSOLE. It should turn ON. If it doesn't, unplug the X-Box for 30 seconds, plug it back in, and try again.
3.) When your X-Box turns on, go ahead and hit the controller's power button. Things should function normally from this point forward.
Please let me know if this works for you!
Sep 30, 2011 | Microsoft Xbox 360 Controller
HI, I have a IBM Thinkpad R50e and i had a CMOS battery failure. After replace the battery it has now started to ask me to check the date and time and when i press enter it is asking for a BIOS...
Dear john, replacing CMOS Battery usually RESET password ( plug out your laptop battery,then plug out the CMOS battery. keep it out for 5 minutes.)
After 5 minutes by, put back on the CMOS battery. put it back all together. laptop battery the last one.
On the first boot you need to set the time and date. or by pass it by pressing ESC. >> If your Operating System goes >>> right click on clock task bar >>Adjust Date/Time >> set as you wish >> apply >> ok >>>RESTART your unit.
akee_akee@live.com
Aug 16, 2011 | IBM ThinkPad R50e Notebook
Have a kitchenaid microwave KHMS2040WSS brand new. Is there a way to set the popcorn sensor for a smaller bag? Right now it is set for 3.5oz and burns all the popcorn.
I have never seen a microwave that doesn't burn popcorn if you use the "popcorn" button. Why the manufacturers keep putting them on I'll never understand. There's nothing you can do change the presets on an oven since they are built into the controller. Instead of relying on the oven, you should follw the directions on the bag. These tell you to use high power, stay by the oven and stop the cooking when the time between pops drops to 1 or 2 seconds. Stored heat will continue to pop kernels for a bit, and you won't cremate your popcorn. You'll also avoid the possibility of the bag catching fire and damaging the oven, which I have seen several times. Finally, don't expect 100% of the kernels to pop. There wil always be a few duds, and extending the cooking time just results in burned popcorn.
Jun 05, 2011 | KitchenAid KHMS2040W Microwave Oven
My save files continusly corrupted and the game also says the time is not set after I turn the Game Boy Advance off then back on. I'm also wondering if it has to be a Game Boy Color.
The internal battery inside the game cartridge has died and needs to be replaced. This watch battery is what keeps track of the save file and the time in the game. Remove the screw on the back of the game cart (you may need a special screwdriver) and pop off the cover, revealing the main PBC (PCB?) circut board of the cartridge. You're doing game surgery, so be careful with doing this. Bend the contacts keeping the battery in place and remove the battery. If you accidently broke off the contacts, you'll need to solder some more back on. Anyway, replace the old battery with a CR 2032 battery (common watch battery sold at retailers), or a CR 2025 will work as well. Just make sure the contacts are touching the right sides of the battery. I believe the default would be negative side down. It's recommended that you tape the battery down to keep it from coming loose. After all that is done, put the cartridge casing back on, screw the screw back into place, and insert it into your Game Boy. It really does not matter wether you're using Game Boy Color, Advance, Pocket, or any model. Your game should be able to keep the time and its save.
Jul 10, 2010 | Nintendo Pokemon Crystal
My Camera stopped working on my DSI, how can i fix it???
Okay, mine is like that too Niky Rixono but, I emailed Nintendo about it.They said that it's possible to be fixed but your DSi has to be under warrenty. Anyway, they said to call this number, 1-800-255-3700. Any time around 6:00 AM - 7:00 PM. I hope this helps. There is no way to fix this problem but to call this number. IT'S NOT FAKE!!!!!
Oct 30, 2009 | Nintendo DSi Black Console
Led light constantly stays on remote rcr4358
First off, put in brand new batteries. Not just batteries that are kind of new, i mean BRAND SPANKING NEW batteries right out of the packet.
If you still have a problem:
~hold down the DVD-VCR button-> the red led will stay lit.
~holding down the DVD-VCR button press the number 2 --> the red led will turn off
~Release the DVD-VCR button--> the red led blinks 4 times and turns off.
Hope that helps!
Rate me!
Feb 11, 2009 | RCA Universal Remote Control
Menu keeps popping up
Hi, heres your fix, replace all of the front control board tact switches, part number is 23344443 & have a Merry Christmas, BMW Rider
Aug 24, 2007 | Toshiba 32A43 32" TV
Microsoft Xbox 360 Controller Logo
29 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
