Question about Dell OptiPlex 170L PC Desktop
Fan is continually running
Recently the fan in my desktop began to operate and hasnt stopped. I do not have any processes running, nor any processor intensive programs open. The fan is very loud and obnoxious and i was hoping to find out how i could get it to stop. Thanks.
I got the same problem. i've clean all the dust there, but the fan is still running out loudly :(
Posted on Sep 15, 2008
  • 2,794 Answers
Some are controlled by a thermostat. It could be the thermostat isn't working. It also depends on what the temperature of the room is that you have it in. If the room doesn't have air conditioning, chances are it needs the fan.
One way to try to cut the noise is try to clean the dust out of the fans and power supply by taking and air compressor or using some canned air. You should be very care when using the air compressor to make sure that you don't knock off any components.
Insect your fans and power supply. There are less noiser ones you can find at a computer store for a reasonable price. It could be the bearings are bad on a fan as well. If you replace it, the noise will go away.
Good luck on that.
Posted on Jun 10, 2008
CPU Fan Failure
ask the Dell support of directions, they will guide you.
Mar 27, 2012 | Dell Inspiron 620 ST Desktop Computer...
Acer 5520 turns off randomly
can you check to see if the fan is moving, it can over heat and shuts down when the processor gets hot you would not feel it though case. also make sure the vents are clean as this is were the fan blows cooler air over to cool the processor-s down.
May 27, 2017 | Acer Aspire 5520-5908 Notebook
My fan is running constantly computer seems
Yes, the fan should run continuously else the processor will get toasted. It get very hot without the fan even when the PC is not doing anything visibly.
Dec 15, 2009 | Acer Aspire M1201 Athlon X2 320 Gb PC...
Toshiba laptop fan speed up and then slow down issue. Feedback
I have a toshiba and that is exactly what the fan is doing to cool off the processor. That is because when you boot XP the fan stops after 30 seconds is simply it has no difficult operation on it. But when you choose to switch on to Ubuntu your fan doesn't stop is because ubuntu requires more air since it has so much effort on its operation. Mind you when you installed ubuntu, it requires larger video graphics memory than the XP OS. Try to execute more websites on different tabs on your XP and you will find your fan will work overtime because you put much required operation for the processor. But to help the fan cools off the internal devices, place cooling pad beneath the notebook so that your PC will be safe.
Thanks...
Dec 11, 2009 | Toshiba Satellite P105-S6124 Notebook
I recently had a new power supply installed in my compaq presario SR1318NX, now the fans run almost constantly. The air from the fans does not feel hot, nor does the tower. Is this serious?
In a desktop computer the fan is supposed to run constantly otherwise the processor would get that hot the system would repeatedly shut down or even damage the processor or motherboard.
If the fan is noisy then chances are that the fan blades need cleaning of dust.
Other than that you have nothing to worry about.
Regards.
Dec 02, 2009 | Compaq Presario 5000 PC Desktop
Why does my PC fan run continuesly?
Usually, there are two fans on a desktop PC. Some computer have three.
One cools down the power supply and it may be quite noisy after a while because the dust in the fan. The second one is to cool down the processor and usually it doesn't stops, it only changes its speed according the heat.
If there is a third one, it will stop when the temperature is cool enough for the system.
Only on notebooks the processor fan stops completely after a while to save some energy.
Sep 30, 2009 | HP Compaq Presario Media Center SR1750NX...
My CPU fan for my Dell Dimension 2350 has stopped turning!
If your fan is not turning at all then it is probably dead, the bearings are likely clogged with dust and such. The PC is shutting off because of heat buildup on the processor chip. You need to do an Ebay search for your model and order a fan right away. Continued running of your sysem without a fan will kill the processor and motherboard. You should be able to get a replacement fan for your computer for less than $15 including shipping. Your local computer store may have one to fit your system but they may charge more for it. To change the fan is very easy, the left side of the case will come off your system, right under the power supply is the processor and heatsink and the fan. Disconnect the old fan and reconnect the new unit.
I hope this helps, if so please rate my solution
Buddy
Corporate Computer
WWW.CCL-LA.COM
Jul 02, 2009 | Dell Dimension 2350 PC Desktop
Computer noise
More likely one of the fans, but could be the hard drive. Open the case and listen. Fan on power supply, fan on processor, or hard drive are the most likely sources of the noise. Processor fans and power supplies are both cheap and easy to replace. Hard drive is a bit more expensive and you must back it up (which you already regularly do, right?) if you want to keep your data.
Apr 24, 2009 | E-Machines T3112 (RBT3112) PC Desktop
My computer fan is running continuously, from the time it turns on. (even before booting in to windows xp) why does my hard drive fan kicks in all the time - its loud and annoying
The fans in most desktops do run whenever the unit is on. Only high end/ performance/ or self built systems usually have self adjustable fan speeds.
Mar 12, 2009 | Compaq Pesario S4120WM (DK216AR#ABA) PC...
Noisy fan - ~Dell Dimension 5150 (3 years old)
This issue is discussed here: Click Here
As for the fan check it inside the pc sounds like you may be missing a screw
Mar 07, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell OptiPlex 170L PC Desktop Logo
1,039 people viewed this question
Alun Cox
