Question about Whirlpool GEW9250 Electric Dryer
Whirlpool Duet Electric Dryer
I have been trying to use my dryer for the last 2 days. When I push the start button it beeps once and the sensing light comes on. It is as if it is stuck in sensing mode. But there should be nothing but the dampness of the clothes too sense as each time the dryer is cool. Can you offer some assistance?
  • DinSue Jun 14, 2008
    We are experiencing the same problem. Have un plugged and re plugged unit, switched circuit breaker on and far nothing is working. Any help would be appreciated.
  • Anonymous Jun 19, 2008
    My dryer is beeping once and not turning on. The sensing light is on when it does this. It won't work.
  • 525 Answers
As this issue involves multiple user's, I am going to provide a link directly to the Whirlpool Corp. so that any information provided or collected will be documented to the factory in an effort to maintain quality service.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
If this doesn't help, post me back and I will do some more research to help resolve your issue.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 27, 2008
  • David Emmel
    David Emmel Jun 30, 2008
    Just checking back to see how you are doing and to offer more assistance, if required.
    Thank you,
    Dave E. (Illeagle)
I have a Whirlpool Duet Dryer GEW9250 which has all panel lights light but when you push the start button it beeps once and the sensing light is on and it doesn't start. I changed the Thermal fuse...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Aug 19, 2011 | Dryers
Dryer will not start when pushing start button it just clicks once
This sounds like a problem with the thermal fuse blown which is wired in series with the motor. Power to the motor is terminated when the thermal fuse blows and the motor cannot run. No dryer function works when the motor cannot run. Click on the link below for the detailed instructions in troubleshooting this kind of Whirlpool Duet or Kenmore Elite dryer problem.
Troubleshooting Whirlpool Duet and Kenmore Elite Electric Dryers Not Starting
Mar 23, 2011 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Dryer lights works, but when the start button is pushed the drum does not spin. the timer shows the minutes counting off, but no spinning. the dryer worked yesterday, but no today. dryer is a duet...
I am having the same problem. Dried towels last night. This morning, I loaded it, turned it on, it did not lock the door or start drying (spinning) but the timer started counting down. I pressed Cancel twice, unplugged it for a few minutes then tried again. Problem still exists. Any suggestions?
Aug 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Won't start, keeps beeping when i push start.
The door switch has gone bad. Replace door switch and you should be good to go.
May 16, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Can not get my dryer to turn on
There is a set of instructions available at for this problem. Specifically at:
It's a quick and easy fix.
Aug 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet gas dryer that will not turn on. When I press the start button it makes a beep three times then the lights go off.
I had the same problem with mine. As it turned out the dryer door wasn't completely shut. You really have to push them hard when they are brand new and you should feel a second "click" when it pops in all the way.
Jun 12, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Whirlpool Duet dryer won't move past sensing function on any cycl
Found the culprit. The thermal fuse was blown. Had no conductivity with ohm meter so I placed a jumper around it and presto dryer runs. Cleaned the exhaust and fan but found no blockage and really was not that bad. Hoping maybe just a weak part. The model on the Whirlpool Duet electric dryer is GEW9250PWL I believe the the last three are just the color. The part number on the Thermal Fuse is #3392519. This is easy to get to through the front panel just below the load door. Hope this helps some else out.
Jan 14, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet dryer won't start
whirlpool duet dryer has power but will not start--when I press start, it beeps once and the sensing light comes but the dryer doesn't start
Nov 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool dryer,duet
check the door switch for operation, if the machinr thinks the door not closed == no operation
Jan 11, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
431 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
