Question about GE Heating & Cooling
I purchased a window air conditioner, Model # ASTO5LKSI and installed it this morning in my kitchen window. I heard the pinging sound discribed in the instruction book and read that sound is O.K. due to humidity. My question is: When I went outside to check out the pinging noise, there was a white milky liquid running out. What is this and do I need to be concerned?
    Champion:
  • 230 Answers
I would return it and get another. The only thing that supposed to be coming out is water.
Posted on Jun 10, 2008
I just purchased this portable air conditioner. I have a few questions about its operation and intimation. First, my window is a vertical sliding window that is about 55u inches tall. Do u have anything...
LG does not currently have an extender panel. However, call Vance Baldwin/Encompass at 1-866-779-7906, as they may can help you with that.
As far as noise is concerned: Generally speaking, most noises heard from the air conditioner are normal sounds of operation. Most of the time, noises are muffled during the day by activity in the home, but heard at night when it is more quiet.
Vibrating Noise? This is most likely the result of improper installation. Check that the unit is secured properly in the unit. Make sure the filter and the front grille are attached properly.
Hissing/Gurgling Noise? At the ON/OFF operation is caused by the refrigerant flowing inside the air conditioners sealed system. THIS IS NORMAL. This sound is a little louder for 2~3 minutes when the unit is first turned on. This is the sound of the compressor start-up. THIS IS NORMAL.
Beeping sound when control settings are selected/changed? THIS IS NORMAL. This noise is a signal that the control panel settings have been changed.
Pinging Noise? THIS IS NORMAL. This is the result of moisture in the base pan being picked up by the fan (called a slinger fan) and thrown against the condenser. This helps to discharge the heat and make the unit cool more efficiently.
Is the unit installed in an enclosed are? A unit enclosed by many walls is likely to produce more noise as the sound waves will be reflected and echoed.
Once the room temperature is met, the compressor should turn off automatically. But, the fan may run for several more minutes.
I hope this helped you. Thanks for choosing FixYa.
Jul 24, 2011 | LG LP0910WNR Air Conditioner
Just installed a new Friedrich CP06C10 window air conditioner that I purchased from J&R. Turned it on and it makes a loud rattling sound. I installed a Friedrich CP08C10 window air conditioner in...
its the fan hitting the shroud, look inside for the fan hitting anything and check for the copper lines vibrating against each other, also, it could be the plastic front vibrating, put your hand on the front to see if you can stop it,
Apr 17, 2011 | Friedrich CP06C10 Wall/Window Air...
White smoke coming from vent in room air conditioner
it sounds like it was humid which is normal for the cool air to mist, it will happen in your automobile ,also
Jul 24, 2010 | Airtemp B3Q06F2A Air Conditioner
Need window air conditioner to fit window 23" wide. Studio apartment main room is 13'X17' with kitchen 6'x17' and walk-in closet and bath 5'x17'. Would like a kenmore and quiet while in operation.
Hi; Try purchasing an up right portable ac unit. Then all you need to do is vent the hot air tube out a convienant window or dryer duct. Needs to be at least 12,OOO BTU. I size my installs to 400 sq. ft. per ton(12,000 btu)
Jan 18, 2010 | Kenmore 75085 Air Conditioner
Window unit not cooling properly, minimal cooling
SOUNDS LIKE ITS LOCKED OUT ON LOW LIMIT OVERLOAD CHARGE THE AC SHOULD START UP WHEN COMPRESSOR GETS AMPLE FREON
May 03, 2009 | Frigidaire FAC107P1A Wall/Window Air...
Through the wall vs. window installation
window mount doesn't have to extend out on the back to clear the side /top intake vents because a window is about 2" thick,
but a wall mount has to have about 6 to 8 " clearing before the intakes vents can be exposed. you can't have your intakes buried in the wall.
in short if you see about 8 " of dead metal in the center area (just behind the window sill) then you can mount it in a wall as it will protrude far enough to clear the side /top intakes.
a sleeve just gives you a way to balance / attach to the outside wall
Jun 12, 2008 | Heating & Cooling
I just purchased an alleged "window mount" air conditioner with the closest dimensions to the existing model. Do these mount as through the wall as well? My current opening = 18 x 26" the new purchase is 16 27/32 x 26.
There are 2 different types of window air conditioners – there are the window type of which will fit in a window that opens top to bottom and there is the slide in model of which the actual air conditioner will slide into a metal sleeve which is very common in apartments. In either case you need to measure the inside of the metal sleeve and then give that to the air conditioner dealer and he will know what to do and there is also a POS (point of sale) @ the store of which will also assist you in the measurement of the A/C unit – the window unit you need to measure the opening of the window itself, I hope this was helpful
Apr 09, 2008 | Frigidaire FAC124 wall/Window Air...
Heating & Cooling Logo
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
