Question about Karcher 2500 PSI Pressure Washer
Karcher K4 Hello, just cleaning my patio been using it for two days and it has stopped pressuring up, water comes through the lance but there is a humming noise coming from the unit when switched on, weather the trigger is pulled or not. Thanks for your time hope you can help. Regards Gareth
  • Gareth Waters Jun 10, 2008
    Hi, thanks for replying, I got it wrong the number is K2 94M. Hope this help[s.
    Many thanks
    Gareth
  • Anonymous Mar 20, 2014
    why is there no water pressere fro the lance when trigger is activated
    Master:
  • 638 Answers
It sounds as if you might have an air lock/air bubble in your pump circuit. If you've not already done so, try holding the trigger on your high pressure nozzle for several minutes with the engine OFF. (just your water pressure forcing water through the unit) Repeat this a couple of times, if necessary. If an air bubble is the problem, this should clear it. The only other thought I have is one of your household water pressure...is it adequate? Low water pressure at your faucet could also be a factor. Consult your manual. It should specify the minimum pressure for your washer to function properly, probably stated in gallons/minute.
if this solution helps you any way rate it as "fixya". feel free for further assistance. thanks for using fixya
Posted on Jun 10, 2008
  • 13,433 Answers
Check for a leak somewhere, either somewhere in the pipes or in the trigger / gun.
    Brigadier General:
  • 3,614 Answers
May i know the exact model please...?
  • micromaster
    micromaster Jun 10, 2008
    check the unit transformer...
  • micromaster
    its is possible that the humming sound was coming from any of the trnasformer or in the powersupply area..., this will happen for such overloading in the electricity while the unit never meets it normal performance..
    Guru:
  • 1,894 Answers
Think it must be faulty power
  • dewan nafees ahmed Jun 10, 2008
    did u try a different power plug
    your unit uses a 1900W motor.
    this humming noise is from the motor.
    this is my view.
    motor is trying to start.
    but it is not able to.
How do I fix a problem with my Karcher K4 pressure washer.
Sharon, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Grumpy gits and useful tips
How to FIX Karcher pressure washer
Karcher North America Home Garden Online Help
Aug 09, 2016 | Karcher K 5.85 M Electric Pressure Washer
Karcher troubleshooting
check your lance nozzle is not blocked... Remove the lance from the trigger assy and see if you have water coming through then. If you do then the nozzle is blocked :@)
Jul 21, 2014 | Karcher K2.26 Electric Power Washer
Karcher lance fitting
if they are the plastic version, replace them as they tend to "expand" as they age and won't fit properly.
Jul 08, 2014 | Garden
My karcher k7.85 has lost pressure and the motor runs constantly when switched on ,motor only used to run when trigger pulled in on lance ,there is no leaks. Can any one help please.
Sounds like the pump seals are bad. The manual says to only use these a few minutes at a time, most people try to clean the patio etc with them, run them too long, and burn out the pump seals - don't ask me how I know this.
Feb 17, 2014 | Karcher Garden
I am trying to clean my block paving using my pressure washer Karcher 3.99, which I used successfully last summer, however, it is not cleaning well. I have used the high power nozzle but the power seems...
Hello Sue, you don't say where in the world you live, but if you are attempting to clean dirt and algae off pavers, you need to add a solution to the water jet via the inbuilt attachment. Mix a fairly mild solution of bleach and detergent, pus a dash or deodoriser to the cantainer. Put your karcher on low pressure and give all the blocks a good wetting. Do this in the morning so the solution doesn't dry. After 20 ~30 mins, Claen off with the Karcher on normal high pressure (not the tubo lance). HINT: Leave the trigger on all the time and don't stop and start using it. This will prevent hayraulic hammer which can split the pump head.
Apr 11, 2010 | Karcher Garden
I have tried to use my Karcher washer model 411A using the suction tube which is immersed into Patio cleaner bottle but it does not work what am I doing wrong
you have to lower the pressure at the lance for the detergent to be drawn into the hose. It works on a venturi principle.
on the lance you will have to twist or pull back the end for it to go into low pressure mode.
the easiest way to check it is working is to take out the lance extension , the bit that fits into the trigger on a bayonet fitting. run the machine and see if it then draws in detergent.
If it doesnt draw detergent then look to see if there is a detergent valve fitted to the filter that goes into the bottle and check that it is fully open. sometimes ther is a non return valve fitted into the filter too.
it could be that this non return valve has stuck. A poke with a bit of stiff wire should free it off its seat if it is that problem.
hope this helps a little
Jul 17, 2009 | Alfred Karcher Pressure Washer
No pressure on certain settings
Dear Osville,
It is not clear what type of lance or nozzel you have. You said that the machine works fine with the circulating water jet(the turbo). So it seems the machine is fine. I do sometimes service variable nozzels and variable lances. But the best solution is to replace nozzels and variable nozzles and lances with new ones. Regarding the fan spray setting it could have no pressure because it might be in the chemical setting. The chemical setting lets out a fan shape flow of water, but with less pressure. The chemical system only works on low pressure in domestic washers, that is why it needs a low pressure flat spray. The pencil jet has 2 jets comming out because if it is a lance or nozzel with ball bearings, these ball bearings must have stuck in a wrong position. Also 2 jets can come out, due to a damaged nozzel hole.
Altogether, the best advice is to buy a new nozzel or lance...which ever your machine uses. All Karcher machines have their own specific nozzels, lances and high pressure hoses. You cannot change these from one model to another.
Regards,
Fulltech.
Apr 29, 2009 | Alfred Karcher K 5.93 M Electric Pressure...
I have a Karcher 3.99 Pressure Washer. The motor appears to be working and water is passing through the machine when turned to the detergent application setting. However when the lance is tightened to turn...
Hi I have a karcher 3.99 the motor comes on and water comes out however thre is no pressure i have tested the lance on my brothers washer and this is ok what is wrong
Feb 21, 2009 | Karcher K 5.85 M Electric Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
610 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
