Question about Linksys Wireless-G WRT54G Router
Bridge mode how do you set up the modem to bridge mode? I have a wireless laptop which IS working and a main router which IS working. I have a desktop ACER with a new Linksys 54GR which "sees" the access point and will still not connect to the internet. It is driving me mad.
  • pwwatson8888 Jun 13, 2008
    How does one go about doing this? Thanks
  • 611 Answers
In the linksys 54gr in that you have to give the mac address of the router and made a repeater mode so you can get the internet
Posted on Jun 13, 2008
Acer AX1920-UR20P computer will not connect with Internet, I have tried wireless and ethernet connections.
is modem in bridge mode? sounds like you try wireless first. the router would then do the dhcp to get you on the net I would hook modem to router to tower. you may also want to power cycle them.
Aug 11, 2015 | Acer Computers & Internet
When I plug my modem into the computer, the internet works fine. But when I plug the modem into the router and plug the router into the computer, it don't work no more. And I can't get on from my laptop...
>You need to set the modem to Bridged Mode first, then connect the router to the modem so that all configuration will now be controlled by the router.
>Ask your Internet Service Provider on how to set your modem to Bridged Mode.
Oct 23, 2010 | Linksys Wireless-G WRT54G Router
I purchased the AT&T Motorola modem if I connect my desktop directly it works, but my laptops do not - if I connect my Netgear router my laptops then work but my desktop does not...help...
>in order for you not to have more problems at all
>first, ask AT&T to set your motorola modem to BRIDGED MODE first
>then, connect your Netgear router to the modem
>connect the desktop computer to the router and check you connection
>after you got the desktop computer connected to the internet
>try to establish connection to your wireless network using your laptops (Laptops cannot connect to Motorola modem since it doesn't have wireless capability like routers)
>comments suggestions ratings and violent reactions will greatly be appreciated thank you...
Sep 26, 2010 | NetGear RangeMax WPN824 Router
Wireless is nonexistant
You need to bridge mode your modem. And when set it to bridge mode already. Connect the dlink router. Access the gui of the router. Enter there your username and password. Powercycle modem, router and computer. Check connections. I f this didnt work, set again your modem to default, connect your router. Configure your router with username and password. Powercycle again. Check if it is working.
Jul 16, 2010 | D-Link DI-524 4 Port Wireless-G Router -...
Bridge router
1. Use both the Modem and the router as NAT routers. Do this by making your router a DMZ node on your modem, that way ALL traffic will pass to the router, then set up port forwarding etc on the router.
2. Run the router/modem in bridge mode (recommended). You need to set the modem to run in bridge mode, check the user manual for refrences to bridging. Then set the router to connect to PPPoE using a username and password.
Jun 07, 2010 | Encore 802.11G WIRELESS LAN ROUTER...
BRIDGING MODEM AND ROUTER
Your firmware may not support bridge mode, try installing dd-wrt from http://dd-wrt.com/dd-wrtv3/index.php
Aug 19, 2009 | Linksys Wireless-G WRT54G Router
DSL line disconnects on WRT54GS only
Try to change the LAN IP address of your router to 192.168.2.1 by accessing the router's Setup page. You also need to set your Westell modem to "full-bridge mode". You need to ask assistance from your ISP to bridge the modem. After that, set-up the Linksys router to PPPoE then power cycle it.
Apr 15, 2009 | Linksys Wireless-G WRT54G Router
No connectivity to internet
Looks like when you reset the router/mdm you have los all yur configuration and back to the default factory settings.
Bridge the modem first .
1. In your web browser browse to »<your mdoms deault gateway> This address will be found in your manual of your modem
2,Depending on your modem make sure you use "Bridged Mode (PPPoE is not used)"
3. Click Save Changes.
4. Then connect the router
5.Configure the router for PPPoE using your ISP uid/pass
6.Configure your wireless using WEP(if applicable)
7.after all configuration shut the desktop,laptop,router,mdm and pwr them in seg..first modem and then router and then your desktop or laptop
Cheers !!!
Feb 26, 2008 | D-Link GamerLounge DGL-4300 Router...
Netgear Router WGR614 will not connect to internet
Looks like when you reset the router you have lost all yur configuration and back to the default factory settings.
Bridge the 5100 first.
1. In your web browser browse to »192.168.0.1 This address will be located on a yellow sticker on the bottom of your modem.
2. The first screen will ask you for your Modem Access Code. This also will be located on the same yellow sticker.
3. Select Advanced from the blue buttons on the left.
4. Click the PPP locations button.
5. The modem may ask your for the Modem Access Code again. If so type it in again and click continue.
6. Select the radio button labeled, "Bridged Mode (PPPoE is not used)"
7. Click Save Changes.
8. A "PPP Location Warning" page will come up. Click "Change PPP Location."
9. A "Restart Needed" page will come up. Click "Restart"
10. Reboot your computer and and then connect the router
11.Configure the router for PPPoE using your ISP uid/pass
12.Configure your wireless using WEP
13.Desktop : Using Dell wireless client configure the client using the same SSID ,wep as configured in the router
Laptop : follow the same as desktop
(by default dell wirelesss client takes over the wireless configuration in dell pc.to disable it and use windows wireless client..control panel ->administrative tools -> services -> enabl2 wireless zero configuration)
14.after all configuration shut the desktop,laptop,router,mdm and pwr them in seg..first modem and then router and then your desktop or laptop
Cheers !!!
Feb 24, 2008 | NetGear WGR614 Router
Belkin wireless set up
Hi, As you ave the modem in bridge mode and also it works ine with wired connection just follow the instruction below for wireless
1.Login in to the router - > wireless settings
2.Configure your wireless using SSID and WEP and save settings
3.Laptop : Using windows wireless client configure the client using the same SSID ,WEP as configured in the router(view available wireless network in wireless properties)
(by default OEM wirelesss client takes over the wireless configuration in branded pc.to disable it and use windows wireless client..control panel ->administrative tools -> services -> enabl2 wireless zero configuration)
14.after all configuration shut the desktop,laptop,router,mdm and pwr them in seq..first modem and then router and then your desktop or laptop
Cheers !!!
Feb 24, 2008 | Belkin (F5D7231-4) Wireless Router
Linksys Wireless-G WRT54G Router Logo
164 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
