Question about Whirlpool GEW9250P Electric Dryer
Control lock stays on and nothing else works on the panel. No other lights, no other controls.
I have ck the thermal fuse and have continuity, light inside the drum works, power to the plug, vent not clogged...what could be the problem
  • Anonymous Jun 24, 2008
    Same problem, control light on, no response from other buttons.
    Sergeant:
    Champion:
  • 291 Answers
Sorry to tell you but you have a bad control board
Posted on Nov 25, 2008
Exhaust fan and lights do not work
see this steps and fix it. God bless you
Switch If the range vent hood fan and light are not working the switch might be defective. Watch our video on switch testing and test this switch for continuity.
Selector Switch If the range vent hood fan and light are not working the selector switch might be defective. Watch our video on switch testing and test this switch for continuity.
Rotary Switch If the range vent hood fan and light are not working the rotary switch might be defective. Watch our video on switch testing and test this switch for continuity.
Rocker Switch If the range vent hood fan and light are not working the rocker switch might be defective. Watch our video on switch testing and test this switch for continuity.
Switch Kit If the range vent hood fan and light are not working the switch kit might be defective. Watch our video on switch testing and test this switch for continuity.
Micro Switch If the range vent hood fan and light are not working the micro switch might not have continuity. The best way to test the switch is with an Ohm meter. See our switch testing videos for help testing this micro switch.
Thermal Fuse If the range vent hood fan and light are not working the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Main Control Board If the range vent hood fan and light are not working the main control board may be defective.
User Control and Display Board If the range vent hood fan and light are not working the user control and display board may be defective. Check other causes before ordering this board.
Oct 02, 2012 | Dacor Millennia DHI602 Kitchen Hood
Kenmore HE5 dryer won't start
Several different problems could prevent your dryer from running. Make sure that the door is firmly closed and hold down the start button for a couple of seconds to start the dryer. If you hear a click from the control board then the door switch and the control board are likely okay. You could have a blown thermal fuse or a broken belt in the dryer. To check these components,unplug the dryer and remove the bottom front service panel as shown in the first image below. With this panel removed, you can tell whether the drive belt is broken. If the drive belt is okay, I recommend checking the thermal fuse. This fuse is located on the blower housing as shown in the second image below. It will have light blue wires attached. To test the fuse, remove one wire and measure the resistance across the leads of the fuse with a volt/ohm meter. You should measure near zero ohms of resistance (continuity). If you measure infinite resistance, then the fuse is blown and will need to be replaced. You can verify that this is your failure by taping the contacts of the light blue wires together with electrical tape to "bypass" the thermal fuse. Reassemble the dryer and see if the motor runs with this fuse bypassed. If it does, then this verifies that the blown thermal fuse prevented the dryer from running and that this was the only failure. NOTE: Do not continue to run the dryer beyond this brief test with the thermal fuse bypassed. This component must be replaced. It is an important safety feature of the dryer.
You can order a new thermal fuse from the Sears PartsDirect website. The part number is 3392519.
May 01, 2012 | Kenmore HE5 Electric Dryer
Has power to it but doesnt turn on or do anything motor burnt up?
there is a thermal fuse located on the electronic control that generaly goes bad ( within the door panel)to prevent further function, power to unit, but nothing lights up, id check this fuse for continuity first!
May 17, 2010 | KitchenAid Dishwashers
Sears model 665 ultra dishwasher has no power,breaker not blown but nothing works,no lights nothing
There is a thermal fuse located in the control panel that is probably blown out.
Open the control panel by removing the 6 screws around the top inside of the door. The thermal fuse is located on the top right side. Remove the wires from the fuse. Use a volt neter set for continuity to test the fuse. No reading is a bad fuse.
This link will show the fuse.
http://www.appliancepartspros.com/part_details.aspx?part_id=3115186&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d5162747%26diagram_id%3d914101
Jan 04, 2010 | Kenmore Dishwashers
Kenmore Elite Dishwasher(665.15979990) wont drain
If the control panel is still lighting up I think it the thermal fuse has blown if you can take out the control panel and in that you will find the fuse you can test this with ohm test and here is a pic of what the fuse looks like and if you do replace this make sure you replace the new wires that come with the new fuse good luck hope this helps
Nov 21, 2009 | Dishwashers
Why my dishwasher kitchenAid control panel does not turn on?
If you have no lights at all, check the thermal fuse located inside the control panel If the thermal fuse is good, check the continuity in the door switch.
Jun 07, 2009 | KitchenAid Dishwashers
Have power to the control panel but the thing don't work????
I take it nothing lights up at all? In the 665 it is very common for the thermal fuse to go out. It should be on the control panel with 2 wires coming out of it with spade terminals. Disconnect that and see if there is continuity
Apr 30, 2009 | Dishwashers
Hi, I have a KitchenAidDishwasher (Model KUDP01FL). It's worked well for a few years. Yesterday, when we went to turn it on, none of the lights on the buttons were on. WE can't turn it on at all. The...
Kill the power to the unit. Pull the control panel down to access the control board located on the right hand side of the panel. There will be 2 wires coming in to a white plastic clip on fuse located on the side of the control board. It will have a plastic pliable shield over it. Pull the 2 wires and check for continuity across this fuse. If no continuity then go to parts house with model number of unit and ask for thermal fuse for your unit. Replace this fuse following the instructions included in the kit and use all the parts included in the kit.
Apr 11, 2009 | Dishwashers
Control panel locked light is on
ck for a button with hold to lock under it hold button 3-5 sec
Jul 02, 2008 | Whirlpool GEW9250 Electric Dryer
No power
check the thermal fuse located on electronic control 2 inch square fuse problalby no continuity through it, Replacemant comes with wires attached and instructions for installation
Feb 20, 2008 | KitchenAid KUDR01TJ Dishwasher
Whirlpool GEW9250P Electric Dryer Logo
107 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
