Question about Kenmore 19233 Computerized Sewing Machine
Free motion I have tried and tried to free motion quilt on my machine. I have changed thread, changed tension and stitch length and width. (feed dogs are dropped and using darning foot) The result is a horrible mess. I have taken the machine to the local quilt store to see if they can help and they are just as confused. I have went to sears (where the machine was purchased) and they don't know either. I have not messed with the bobbin tension, as I am afraid that it will cause harm/problems when sewing.
  • 1 more comment
  • karen-r Jun 11, 2008
    no, presser foot is down. just double checked again and tried to do a free motion stitch.
  • Anonymous Feb 12, 2009
    I have the free motion foot for the Ellure Baby Lock - the foot does not touch the fabric - will not go down???
  • marianna1 Apr 14, 2009
    I have the same problem. In fact I have encountered virtually all of the problems listed on this site. In this particular case, I have lowered the feed dogs for free motion quilting.....however - the back is a horrible mess and I can't understand why. I have yet to complete a quilt with this machine without encountering numerous problems. The answer may be to move on and buy a Bernina. Frustrated to say the very least.
  • 323 Answers
If the machine works on regular stitching and only messes up on free motion ,the most likely problem is the presser foot has not been lowered. Get everything ready to sew, lower the presser foot lever and pull on the upper thread near the take up lever. It should have tension on it. Raise the foot and try again, it should not have tension on it . If this is what you get, lower the presser foot lever and try it again.
sewman7
Posted on Jun 11, 2008
So I have adjusted the tension for the pressure foot and the thread tension, however, the fabric is still not being fed through.
Are the feed dogs in the raised position for sewing or have they been dropped as for darning or free motion quilting? Is the stitch length set higher than 1.5?
Jan 30, 2017 | Sewing Machines
Janome 1600P DBX
You need to drop the feed dogs, install a darning or free motion quilting foot (make sure the presser foot is lowered). Because you will not be using the machine to move the fabric, the stitch length selection is of no importance. Make sure the stitch width is set to zero. You should test FMQ on a scrap quilt sandwich of the same makeup of your project, ie quilt fabric with batting sandwiched between. The upper tension should be set so that both threads meet in the middle of the quilt sandwich. Because it is FMQ, some extra adjustment may be needed.
Once the tension is where you want it, you can practice FMQ until you can move it smoothly in conjunction with the machine speed.
Practicing on a white board with erasable markers is a handy way to learn to move smoothly. The most difficult part of free motion quilting is learning to move the fabric smoothly. Do NOT lack for practice as that is the only way to improve. Those people who make it look simple have been doing it for years!
How to Free Motion Quilt on Regular Sewing Machine
Free Motion Quilting for Beginners Part 1 Video from Sewing with Nancy
Learn How to Free Motion Quilt Stippling
Oct 31, 2016 | Janome Sewing Machines
Singer model no 9022 feeder feet does not move material thread bunges under material
Check that the stitch length is set high enough that the feed dogs will actually advance the fabric. Setting the stitch length too low will cause the machine to basically sew in place.
Also, check that the feed dogs have not been "dropped" to allow darning or free motion quilting. Dropping the feed dogs lowers them so they will not rise above the needleplate and will not grip nor move the fabric.
If your machine is mechanical (not computerized), it may need a good cleaning and oiling. If the old oil has solidified, it could be preventing the feed dogs from moving like they should.
Aug 27, 2016 | Singer Sewing Machines
Bobbin thread will not catch unless the foot is down?
Ashleigh--Your machine will work satisfactorily ONLY if the presser foot is down. When the presser foot is up, the tension disk is released, therefore, no tension = a big knot of thread.
To free motion quilt, you should drop the feed dogs. Install a darning foot (this foot is shorter in length so when it is lowered, there is a space between the presser foot and needle plate). The space allows the fabric to be moved easily while stitching.
Some sewists will free motion quilt without a presser foot (if they don't have a darning foot), but that is very dangerous as one can easily sew through a finger. However, even when sewing without a presser foot, the presser foot mechanism needs to be lowered in order to properly form stitches.
Feb 25, 2016 | Sewing Machines
Feed dogs will not engage. What to do?
Are the feed dogs in the raised position and not dropped for darning for free motion quilting? Is the stitch length set to somewhere between 10 to 12 stitches per inch? If the stitch length is set too close to zero, the feed dogs will barely move the fabric causing it sew in the same spot.
Feb 21, 2016 | Sewing Machines
How to attach free motion foot
Most free motion feet attach like the other feet.
It is creating "thread nesting" also called birdnesting. Could be several things:
1) make sure before you thread the upper thread, RAISE the presser foot so the thread will seat properly in the tension disks
2) drop your feed dogs before you begin to free motion
3) your free motion quilt foot, when lowered, should not rest on the fabric. (Be sure you are lowering your presser foot when you want to stitch!) You should be able to move the quilt sandwich easily under the presser foot. If the foot applies any pressure to the fabric, you may need to release the presser foot pressure (consult your manual). Or you are using the incorrect presser foot for your machine.
4) If none of the above, you need to tighten the upper tension AND
try this method before beginning to free motion stitch:
How and Why to Bring up the Bobbin Thread
Aug 09, 2015 | Sewing Machines
Pressure foot for free motion quilting and settings
I have used the embroidery foot, which has a round hoop about 1/4" in diameter on the "business end." You can also use an open-toed foot. You want to set your tension so that the bobbin thread doesn't show on the front. You can free-motion quilt with the feed dogs either up or down; some people feel that leaving them up gives a more regular stitch length. You should try both ways to see which you like better.
Also, there is a really neat website with tons of free-motion quilting designs, each with a little video of how to do it; I recommend checking it out:
http://freemotionquilting.blogspot.com/p/365-designs.html
Mar 12, 2014 | Sewing Machines
How to set 2140 for free motion sewing
Which model are you using? Creative 4.5?, On the newer machines it drops automatically once the embroidery attachment is hooked up. On older Creatives v2.x there is a slide lever in front of the presser foot on the front.
Sep 26, 2012 | Sewing Machines
How do I set my pfaff mahine up for free motion quilting
try dropping the feed dogs, & reduce the top thread tension one number at a time till the stitches are normal
Feb 27, 2012 | Sewing Machines
How do I set the tension on my Necchi 3101? I want to freehand motion quilt on it.
The tension is not changed.
You lower the feed dogs, or change the stitch length to zero and cover the feed dogs by taping an index card (make a hole for the needle) over them.
Be sure to use a darning or free motion foot and have the presser foot down when stitching.
Mar 17, 2010 | Necchi 3101 Mechanical Sewing Machine
Kenmore 19233 Computerized Sewing Machine Logo
313 people viewed this question
Top Kenmore Sewing Machines Experts
SewTechWayne
SewTechWayne
Page Gettman
Level 1 Expert
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
