Question about iRiver H10 MP3 Player
Usb my usb is being reconinized
    Problem Solver:
  • 8 Answers
At least something is
Posted on Jun 11, 2008
My dsi will not reconinize my games...
dont blow on the back of the games,blow into where the games go into,or try putting them in,then take them out,then put them back in and see what happens.
Jul 19, 2011 | Nintendo DSi Black Console
Trying to connect HP Laserjet 2100 (works fine with XP) to Pavilion dv7 with Win7 64 bit Professional. I downloaded the PCL5 driver from HP but it will not print. I am using a Manhattan parallel to USB...
Did you download the Win 7 64 bit drivers for this printer. If not i suggest try downloading the drivers from the following link
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=14914&pr...
Check the USB connection
The icon on the USB cable (c01424575.gif ) faces up when the cable connects to the product correctly. Check the back of your product and the back of your computer to make sure the USB cable connects correctly and securely.
After you make sure the USB cable connects correctly and securely, review the following guidelines to check other potential USB-related problems:
  • USB ports on the keyboard. USB ports on the keyboard and in the front of some computers might not be powerful enough to support the product. If the USB cable connects to the USB port on the keyboard, try connecting it to another available USB port on the computer.
  • USB cable length. HP supports USB cables less than 5 m (16 feet, 5 inches) long. However, a USB cable that is 5 m (16 feet 5 inches) long must be of high quality. Otherwise, HP recommends using a USB cable that is less than 2 m (3 feet, 3 inches). Do not use patch cables to increase the length of an existing cable. Use a powered USB hub if you need more length.
  • Alternate USB ports. Connect the USB cable to another port on the computer to make sure that the USB port on the computer is not the cause of the problem.
  • Defective USB cable. Replace the USB cable to make sure that the existing cable is not defective.
  • Conflicting USB ports. Disconnect any other USB printers, USB scanners, USB cameras, and any other USB connected peripherals. Start reconnecting these devices one at a time to determine if one of the devices is using too much power. Consider purchasing and installing a powered USB hub if necessary. NOTE: A USB-powered hub is a device that increases the number of available USB ports on a computer and facilitates communication between the USB devices and the computer. A powered USB hub can resolve communication failures between some, but not all, USB chipsets and HP products.
Jun 23, 2011 | HP LaserJet 2100 Printer
Iomega eGo 1TB USB 3.0 Portable portable harddisk 500GB. while connected to PC show an error on desktop "insufficient power on USB hub port" . pls suggest
Few different things are possibilities.
1. Are you connecting the device via USB 3.0 to the USB 3.0 adapter on the computer? 2. Try switching out your USB 3.0 cable for a different one. 3. If you are using the USB 2.0 instead. Make sure you are using the USB Y cable for the device and not just a standard USB 2.0 straight cable. Using the USB Y cable. Plug the cable into the device first, then make sure to plug both USB's into the computer starting with the short side USB then the longer side USB second. Also try using the USB's on the back side of the computer as they will supply more power than the USB's on the front of the computer.
Dec 20, 2010 | Iomega eGo 1TB USB 3.0 Portable - Ruby Red...
What is the version of the usb port on a compaq presario 1200
Hi again, after extensively searching I believe your Laptop has a USB version 2.0.
Most PC's manufactured before 2001 were USB 1.0 and USB 1.1.
The Spec Guides for your PC indicate 2002 was the year of manufacture.
USB 2.0 is a faster USB connection than version 1.0 or 1.1. You might have trouble connecting devices that are USB 2.0 (which all new devices are now - since 2001).
To double check, use your Device Manager on the PC to look up the USB device and see what is written.
If you are using XP then do the following:
  1. Click Start
  2. Click Settings
  3. Click Control Panel
  4. In the Control Panel double-click the Systems icon.
  5. In the System Properties window click the Hardware tab.
  6. In the Hardware tab click the Device Manager button and you will see a list of devices.
  7. Click the + button next to the word the Universal Serial Bus controllers.
If it is USB 2.0 then it should say something like USB Enhanced or USB High Speed, this means it is USB 2.0 compatible.
I hope this helps. Please rate. Regards,
Feb 12, 2010 | Compaq Presario 1200 Notebook
USB taking too long to transfer vista
Note that USB ports (in your computer) and USB devices can either be "USB 1" or "USB 2" speeds.
While "USB 2" to "USB 2" connections are up to 480 Mbits/second,
any "USB 1" to "USB 2", or "USB 1" to "USB 1", connections,
will max-out at only 11 Mbits/second.
So, check that you have a "USB 2" device.
then check that you are connecting to a "USB 2" port on your computer.
Give more details about your computer, and your USB device.
Nov 04, 2009 | Microsoft Windows Vista Home Premium with...
After install of driver into windows, xp doesnt
Hi, please check the status of the adapter using the steps below:
1. Click Start and go to 'control panel'.
2. Double click on 'system'.
3. Click on 'hardware'.
4. Click 'Device manager' button.
5. Under 'Network Adapters' you will find the name of Netgear adapter.
Check if it shows installed properly or shows with an error code.
You may try installing the adapter on another machine to isolate the issue further.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jul 02, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Usb 1.1 & usb 2.0
USB 1.1 allowed a maximum transfer rate of 12Mbits/second. USB mice and keyboards need only 1.5Mbits/s to function. That performance level is also named 'USB'.
USB 2.0 has a raw data rate at 480Mbps, and it is rated 40 times faster than its predecessor interface, USB 1.1, which tops at 12Mbps. Originally, USB 2.0 was intended to go only as fast as 240Mbps, but then, USB 2.0 Promoter Group increased the speed to 480Mbps in October 1999.
You can use USB device with USB 1.0, USB 1.1 and USB 2.0 as long as your PC or laptop has USB ports, but USB 2.0 device transfer data at 480 Mbps on systems with USB 2.0 support only.
Apr 01, 2009 | Televison & Video
USB Drive
Make sure you are matching the compatibility of USB 1.1 and USB 2.0 between the devices (computer and USB devices).
USB 1.1 device will work in USB 1.1 and USB 2.0, but USB 2.0 devices will not work in USB 1.1 plug in the computer.
How many USB ports do you have in the computer? Which ones have you tried other pen drives in? List the USB ratings for each device and port in the computer to further help.
Have the other USB devices been formatted with other computers? The formatting on other systems might not be compatible.
Nov 21, 2007 | Microsoft Windows Vista Ultimate Edition
No connection when i plug it
You have to leave it plugged in thill its almost fully chared than it will reconine it
Dec 25, 2006 | Creative Labs ZEN Vision:M Digital Media...
iRiver H10 MP3 Player Logo
13 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
SmartAviator
SmartAviator
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
