Question about Sharp Viewcam VL-A10U Camcorder
Battery charge won't charge just flashes red do i need a new battery
  • 4,234 Answers
I'd start there. Usually the flashing red indicates that the charging function is not working. A defective battery can cause this.
Posted on Jun 10, 2008
Amber flashing light while on home base. New, pulled tab, placed on dock. First time said charge err1, took out battery and replaced. Now just flashes amber. Is this correct?
Your manuals are here. Flashing lights must be covered. A quick look at the site says flashing red is bin full. In fact, I found it. Flashing Amber is CHARGING.
Roomba 600/500 Battery and Charging Overview On some robots, the CLEAN light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged . overview LabeledSupport ... clipped from Google - 12/2015 iRobot: Customer Care - Roomba 700 Anatomy images?q=tbn:and9gcss8oogw3vmcv_uom0z_pxoi9q5tq9n4aqrcwbsxn0zd1blfvnacictdbyn iRobot: Customer Care - Roomba 700 Anatomy Solid Red = Battery Discharged; Amber Pulse = Charging; Solid Green = Fully Charged; Quick ... The battery indicator blinks when there is a charging issue. LabeledSupport ... clipped from Google - 12/2015 iRobot Roomba 500 Series Battery Maintenance iRobot Roomba 500 Series Battery Maintenance Roombas "CLEAN" light should pulse red/amber while charging. ... Green - fully charged; Amber - partially discharged; Red - nearly discharged; Flashing Red - ... LabeledSupport ... clipped from Google - 12/2015 Roomba 400 Series/Discovery Battery and Charging Overview charging-overview Roomba 400 Series/Discovery Battery and Charging Overview Your Roomba's POWER light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged. charging-overview LabeledSupport ...
iRobot Owner Manuals and Quick Start Guides
Dec 31, 2015 | Roomba Vacuums
My Nikon Coolpix S2550 says the battery is low when I need to use the flash - but I have fully charged the battery please help
try leaving the camera on to drain the battery down, then try charging it again.. or could be a bad battery
Dec 30, 2011 | Nikon Cameras
Medion E1210 notebook. Battery has suddenly stopped charging. Didn't get a fall. Laptop works fine when power supply connected, but if plugged out laptop shuts down immediately. When power plugged in...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 21, 2011 | Computers & Internet
Brand new out of the box Volitation 9053 wont take a charge. Charger never goes green to indicate full charge. At most I get 5-10 seconds of weak spin and then the red light on the ECS board flashes. ...
  • If this is a brand new item out of the box, if this were my item, I would send it back for an exchange. The charger never turns green because the battery never gets a full charge. Because of that you won't get a 7.4volt reading out of the battery, Either the battery is not taking the charge or the charger is malfunctioning and not charging proper. The lights may work for a bit while the motor won't spin because a light takes far less voltage than turning a motor. Because you don't know if it is the battery or charger and it is new I have to suggest to take it back. The sooner the better. Messing with it will just void the warranty.
Regards, Tony
May 22, 2011 | xheli 9053 Outdoor Volitation Metal...
Battery will not charge, red light flashing on charging port.
new battery is required as it is too discharged to work after a year's time.
Jul 20, 2010 | Casio EXILIM Digital Camera
Ntn7143cr battery won,t charge. put in charger flashes red then green.
Clean your battery contacts on the battery and charger with a pencil eraser to assure good contact. Flashing red or flashing in general usually is the sign of a too low to charge battery, a shorted battery or a bad connection. In some instances, a battery will begin to charge once left on the flashing charger for an hour or so. Try this and see if the light becomes constant. If so, it is charging. If it still flashes, replace the battery.
Best regards.
Apr 04, 2010 | Motorola MT1000 Compatible 2 Way Radio...
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Dell Latitude D600 new battery won,t charge
the charger in the laptop is not functioning. pc will need repaired
Dec 28, 2007 | Dell Latitude D600 Notebook
Sharp Viewcam VL-A10U Camcorder Logo
178 people viewed this question
Top Sharp Video Cameras Experts
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
