Question about Toshiba TP50H95 50" Rear Projection Television
Toshiba tp50h95 Hi, I just picked up this used tv and it has a curved blue line running vertically in teh upper left hand corner. I replaced the convergence Ic's and still have the same problem. Could this be a tube problem or am I looking at something else? Thanks in advance for your help
  • 2 more comments
  • Wes Kauffman
    Wes Kauffman Jun 10, 2008
    When you go to the convergence menu to adjust the convergence the blue convergence is only out of alignment on the two upper left hand "icons". The rest of the icons are perfect. The blue does not ever change position.
  • Wes Kauffman
    I did recalibrate the convergence using the focus and convergence knobs and using the remote control. Neither fixed the upper left hand corner.
  • Wes Kauffman
    Wes Kauffman Jun 11, 2008
    First of all I am comfortable with electronics repair (I repair cameras for a living). Secondly I am not really sure what you are talking about. My problem is with the blue being out of convergence on the upper left hand part of the screen no where else. The picture looks perfect otherwise. It is just that the blue is "bowed" out in a C shape in the upper left quarter of the screen. My question is if I need to replace the tube or another portion of the blue driver, and if so which part might it be. Thank You
  • Wes Kauffman
    Wes Kauffman Jun 12, 2008
    I am trying to get info on this television repair. Your help is appreciated
    Master:
  • 638 Answers
Hey i m my self a tv n monitor tecnician n hve a come across a same problem long back.i tried out all the possible things but nothing helped SO I FINALLY CHANGED THE TUBE N EVERYTHING WAS FINE THERE AFTER.hey buddy dont try anything else now n just change the tube i know how it feels after getting no results after taking so much pains .its definately tube.thanks and feel free for further assistance if any. rate it FIXYA if u feel it helped u to save ur time solving ur problem.thanks n bye
Posted on Jun 12, 2008
    Sergeant:
    Champion:
  • 230 Answers
I think the problem is only with the tube you better consult with the near service center
    Brigadier General:
  • 3,614 Answers
Possibly it was on the tube..
Posted on Jun 10, 2008
  • micromaster
    micromaster Jun 10, 2008
    is this blue never change color or any position...?
    Guru:
  • 1,894 Answers
I think u have to adjust the settings
  • 1 more comment
  • dewan nafees ahmed Jun 10, 2008
    after changing the convergence settings u will have to bring the unit back to factory settings.
    this would help you surely.
  • dewan nafees ahmed Jun 11, 2008
    sorry for getting back very late to you
    First thing first - If still under warranty or if you have no
    electronic repair experience you should take the set back to the shop
    or to a repair person. Some of the solutions described below can be
    dangerous, TV's are very hazardous to service.
    If you don't have any repair experience my suggestions can only be
    usefull to get a repair estimate, or in order to get more familiar with
    these kind of problems, impress your local repair person etc...
    actually tat effect(convergence) wil be in some red colour..(assuming tat its of red colour)
    switch to test mode to check the red crosshair compared to the green or
    blue - if it seems out of focus, open the set and mark the position of
    the lense. Then adjust it to tighten the line.
    Find out why
    the Red has shiffted(pin trouble). look for bad solder joints on that
    board. Its also Possible that you have a failed component.
    Try resoldering the STK Output IC's very carefully.
    In a worst case scenario , you may need to change the STK that controls the Red Convergence .
    Yank out the convergence board(the one that has several
    controls) on it, then you will find a few contols that have RED PIN
    (whatever). on them. Adjust them untill you get it right
Toshiba 42h83.... The blue convergence will not line up. The horizontal will but the vertical will only move so far. when touch focus starts the reds and greens are perfectly strait the blue vertical is...
bmarino18,
Initially I would have told you to replace the convergence ICs but after reading your post carefully I think you could have a problem with the convergence box. The lines can only be bent/curved for two reasons. One - the yokes are bad causing an undue strain on the power supply and not being able to correct the problem. Two - the convergence box/board is bad and is not holding the settings causing the curve you see. I cannot tell you which problem you have. You wil have to determine this. I do have a tip at http://www.fixya.com/support/r4273935-replace_digital_convergence_box which may be helpful.
Thanks for using FixYa and for the great rating.
hardrocko
Dec 08, 2010 | Toshiba 42H83 42" Rear Projection...
Picture has red vertical lines, will become
The problem is most likely the panel itself where the ribbon cables are corroded. There is however the also possibility that the tcon connectros need A clean.
May 23, 2010 | Toshiba Regza 47ZV650 47 in. LCD TV
Green vertical lines in bottom left corner
IN THE MENU USE THE CONVERSION OPTION IF IT HAS IT
Apr 22, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Color issue
Replace 120k resistor on the blue video output module. Resistor is located next to the blue video output transistor (has heat sink). If you replace it with a 1/2 watt carbon type, it will probably never happen again. I recomend the same resistor on the red and green video boards at the same time.
Jun 17, 2008 | Toshiba 57H83 57" Rear Projection HDTV
Toshiba TP50H95
It sounds like intermittent loss of convergence and you should be able to cure that by taking a look at the convergence amps and locating one or more ring-cracked solder connections. Resoldering them should fix the problem. The amps are two STK392-110 Sanyo Ic's mounted to an aluminum heat sink. Remove that board and visually inspect where they solder to the foil side of the board.
Good Luck!
Bill
PS I'll send the manual via Pando to your crazy4quads@hotmail.com address. You'll need Pando to download it and a PDF reader to view it. Both are free downloads if you don't already have them....
Apr 22, 2008 | Toshiba TP50H95 50" Rear Projection...
Screen problem blue area in the corner
remove any big speakers that are close to the tv
Dec 17, 2007 | Televison & Video
Toshiba 40h80 picture problem
replace c449 and also the damper diode
Nov 19, 2007 | Toshiba 40H80 40" Rear Projection...
Samsung 27" Dynaflat that warps image
the problem is into your power supply try to check you b+. it is a low b+
Apr 28, 2007 | Samsung DynaFlat TX-P2775H 27" TV
Televison & Video Logo
59 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
