Question about Whirlpool 24 in. DU1050SS Built-in Dishwasher
Whirlpool DU1050 will not start
My ex'es dishwasher will not start. It acts as if there is no power. It has worked and the outlet is hot. The cord is good. It stopped with water in the bottom. The machine is 2 years old.
  • 413 Answers
There may be a thermal fuse located on the electronic control board housing that may have failed.This replaceable part (gray or white) is clipped on to the side of the housing. Unplug DW and remove console to gain access.
Posted on Jun 10, 2008
We sold our bosch dishwasher, working perfectly. New owners transported it on its back. Now it won't start, or even show that it is getting power, though the outlet works. What has happened?
Hello KT;
My name is Peter. I am a retired field service appliance technician.
Transporting the dishwasher on its back should not have been a problem. It is only with refrigerators and freezers that need to be transported up right, to prevent compressor oil getting into the refrigerant sealed system.
You may have a power cord problem. You have a 3 or 4 wire power cord. If you have a 3 wire power cord you need a 15 amp circuit breaker. If you have a 4 wired power cord you need a 30 amp circuit breaker.
The wall socket that you are plugged into my not have a ground.
You need to check the wall socket and the wire connects at the dishwasher. Send me a model number so I can see what you have. If you have a 4 wire connection you can chance the cord to a 3 wire. On a three wire you have a neutral and two hot with a small green ground wire. On a 4 wire you have a neutral two hot wires and a neutral in the center with a ground wire.
I would put my money on the wall socket not having a ground.
Send me a model number and I will help you.
Feb 07, 2015 | Bosch Dishwashers
How do I fix -no power issue on my samsung dmr78ahs dishwasher?
To eliminate a dishwasher problem, run a heavy 3 pronged extension cord from a known working outlet to the dishwasher and plug the dishwasher into the cord. If you still have no power (dishwasher is not showing any signs of life) then it is a dishwasher problem (circuit board, bad connection from dishwasher cord to dishwasher, etc).
If the dishwasher actually shows signs of life, then you may have a tripped breaker. Check the breaker to make sure it is on and that the tab is not either in the center or the off position. Also, try moving the dishwasher cord's plug from the outlet it is currently in to another outlet in the under sink area. There is a chance that the plug got switched from the normal outlet to the outlet that controls the garbage disposal, that outlet should only be hot when the disposal wall switch is flipped to the on position.
Dec 18, 2014 | Samsung DMR78AHS Builtin Dishwasher
My dishwasher DU1050 is stuck on Lock and I've
Hi! cccole
Dishwasher may be in bind. remove kick plate and make sure adjusters are not putting case in a twist, or pressing unit to tight to top of cabinets.
InMrFixIt.
Jun 19, 2011 | Whirlpool 24 in. DU1050SS Built-in...
Keeps flashing pf while not on. try to run and it starts and stops after a short wash. have to reset to empty the dishwasher.
Flashing PF = power failure. The power source and connections need to be inspected for bening loose or hot. This would be at the wall connection and in the bottom of the dishwasher. If the supply power source is good all the way to the dishwaher and to the dishwasher control.. suspect corrosion in the control area as the source of the problem. When corrosion gets on an electronic board it starts acting like a conductor for the low voltages produced by the PDB transformer which starts causing all kinds of weird symptoms. If the PCB can be cleaned carefully you can maybe get 6 months to a year out of a PCB that has / had corrosion problems. My 40 years experience is that only one in 5 can be salvaged back into service. Additionally those that are placed bacm in service eventually have other problems.
If you have a loose plug, wires, outlet or power cord... your in luck.
Thanks for choosing FixYa,
Kelly
May 29, 2011 | Dishwashers
I need a heating element (i think) for my whirlpool quiet partner 1 dish washer, but i need the model number and I dont have it with me, do you know the part number for the heating element that I need or...
Your Whirlpool Quiet Partner 1 should have its model number inside along the left side. Mine is DU1010XTXT1. Your heater part is original Manufacture # W10518394. Can be purchased for about $38.00 at
http://www.partselect.com/PS8260087-Whirlpool-W10518394-Heating-Element.htm?SourceCode=3&SearchTerm=w10518394
or order an after market heater element part # AP5690151 for about $33.00 at
http://www.appliancepartspros.com/whirlpool-heater-w10518394-ap5690151.html
Hope this helps!
Apr 04, 2011 | Whirlpool Dishwashers
The "clean" light blinks
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 06, 2010 | Whirlpool 24 in. DU1050SS Built-in...
WHIRLPOOL DU1100XTPS ACTS AS IF NO POWER LEFT WATER IN THE BOTTOM, CHECK ALL POWER CONNECTIONS AND FUSES ANY TIPS
there is a fuse in the door by the controls it blows if it gets too hot so change the tub thermostat to
Dec 21, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Kenmore dishwasher... filled up with water and its lights went off.. no buttons work acts like no power. check the house fuse box - ok ... check the 2 door switch - ok .. checked the thermal fuse - ok ...
Did you check power to the unit? Double check the common and grounds. When servicing I will disconect(unplug from wall) power to the unit. Is it pluged in? Use another outlet(the outlet under the sink may be wired thru a switch for a disposer)even if you need an extension cord. Hope this helps.
Nov 12, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Whirlpool DU1100XTPS 9 Dishwasher acts as if no power
Is your dishwasher have a power cord and plugged into a wall outlet under the sink if the answer is yes then maybe the GFI outlet has tripped and all you need to do is reset the button on the outlet
Sep 22, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Whirlpoool dishwasher not turning on model du1050
Make sure you have power to the dishwasher, check circuit breaker. If circuit breaker is ok, then remove toe panel at bottom front of machine, on the right hand side is where the power cable goes into a little metal box. Turn off circuit breaker to kill power to the dishwasher, remove electrical box cover and check to make sure that the wire nuts are tight. Reapply power and test. If still no go then remove tech service sheet from toe panel insulation, get yourself a multi-meter and start test individual components until you find the one that is bad. Hope this helps.
Dec 11, 2008 | Whirlpool 24 in. GU3200XTP Built-in...
Whirlpool 24 in. DU1050SS Built-in Dishwasher Logo
281 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
