Question about Whirlpool GEW9250 Electric Dryer
Model lgn20000kq1 I bought a used dryer that didn`t work as I found the belt for the drum to turn is missing. I`m going to buy a new belt later this week. Any problem installing a new belt or do you have a picture as how the belt goes on? Imperial series # mp321728....Thanks, Bob or I`m at bitsy5085@sbcglobal.net.......Have to go back to work now.
  • 525 Answers
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
http://www.repairclinic.com/0079.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 27, 2008
  • David Emmel
    David Emmel Jun 30, 2008
    Just checking back to see how you are doing and to offer more assistance, if required.
    Thank you,
    Dave E. (Illeagle)
Belt is to big, it will not turn the drum
What is the model number of the unit?
Nov 10, 2012 | Dryers
Should my drum stop turning when i push it after the belt has broken
Dryer drums aren't always the easiest to turn but not difficult either. If you know for a certain that the belt broke and the drum is still reallty hard to turn then you probably have something caiught in the blower wheel area, like a sock or whatnot
May 10, 2012 | Dryers
The drum will not rotate. I found the belt is broken. How can I get a new belt and replace it?
Use your model number to get the correct belt. Here is a page which shows how the various dryer belt configurations go. Basic American dryer repair photos
May 12, 2011 | Dryers
Dryer stooped working suddenly.
Replace the fan belt that turns the dryer drum. Use only the genuine replacement spare part for your dryer.
Jun 07, 2010 | Frigidaire GLER331A Electric Dryer
How to put new belt on dryer model
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Nov 14, 2009 | Dryers
Drum will not turn
YOUR BELT ON YOUR DRYER IS BROKEN. THAT IS WHY YOUR DRUM WON'T SPIN. YOU CAN BUY A NEW BELT FOR YOUR DRYER AT ANY PLACE THAT SELLS APPLIANCES.
RODNEY
May 15, 2009 | Estate TEDS740JQ Electric Dryer
Neptune Dryer Just Stopped
The user manual can be found here: http://shared.whirlpoolcorp.com/assets/pdfs/literature/2206682B_MD55.PDF
The service manual can be found here: http://www.servicematters.com/maytag_library/docs/16023110.pdf
It does sound like the belt.  Refer to the service manual above on installing a new belt or troubleshooting for other issues.
Apr 14, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Drum in dryer not turning but still heat
Sounds like you need a new dryer belt, call sears for new belt. Install the new belt around the drum and to the motor located near the bottom of the machine.
Oct 19, 2006 | Hotpoint TDC32 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
102 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
