Question about AEG Lavamat 16810 Front Load Washer/Dryer
White lines I have an 16830 machine which causes white lines on dark washing. Its noisey too. This has gone on for some time now. its not the powder as we tried liquid and it still does it. Any ideas? We will have to change the machine otherwise, but its only about two years old.
  • Lavaman Jun 10, 2008
    White
  • Lavaman Aug 01, 2008
    Thanks for the comment. I had a repair man out a couple of weeks ago, and told him the machine was noisy, he suspected the bearings but wobbled the drum a bit and said they were fine. He suggested we tried a "boil wash" ie the hottest wash cycle possible, as the problem was probably caused by a build up of dirt in the machine that was not shifted by a normal low temp. wash. We tried this and had no reported problems for a couple of weeks, but have since had the same problem repeat. So I'm still not sure this is the fix. Do we have to do a boil wash every week? I've never had to before. He also said that this AEG is the cheap AEG range which is basically a Zanussi, interestingly. PS the repair man made NO CHARGE for his diagnosis. As this is not an isolated case, you might have thought there would be more feedback? Anyone?
Undesolved soaps and softener cause deposits like that. try about 2 hot washes per day for about a week to allow soaps to desolve, or drum must come out and be properly cleaned to stop white soap deposits.
Posted on Aug 06, 2008
We have a zanussi and it does the same we have also cleaned the drum and the draq and swapped to liquid but it still does it.
Our machine is also 2yrs old.
Sorry I dont have an answer but wanted you to know it is not isolated to AEG
Posted on Aug 01, 2008
I get detergent marks especially on dark clothes.What causes this?
wrong type of detergent . most do not recommend powders anymore .
Sep 17, 2016 | Washing Machines
Soap streaks on dark clothes what do i do?
reduce the amount of detergent being used as more is not better
use a liquid instead of powder
make for longer rinse cycle
use a softener to help remove detergent in the rinse.
reduce the amount of clothes being washed at each time.
Apr 08, 2015 | Washing Machines
Spots on wash
White soap powder spots can be caused by using the incorrect washing powder or else you are overloading the machine.
Sep 27, 2014 | LG Washer Top & Front Loader Dual Water...
White streaks on dark clothes
The white streaks are of soap build up on your machine tub. You can get ried of that by putting cascade dish washing soap in your washing machine and run full cylece , with out clothes.
Apr 13, 2013 | LG WT4801CW 3.7 cu. ft. top load washer
Calypso stains load
Hi there
I wonder why "dark streaks" on white towels. I presume that you have made sure that there is no dirt flying around in the machine.
Try to let the machine go a circle -without any washing in it- just to see if the water takes color. There are also in the shops washing powder
that remove stains of different types.
Also powder for "only whites"
good luck
Kolbrun
Apr 23, 2012 | Whirlpool Calypso GVW9959K Top Load Washer
Been dealing with a smelly washer- tried the usual, bleach, vinegar, CLR.....it doesn't seem to have a lint trap.....is there one? where might it be?? Its old but works great other than this.....
Have you tried doing an empty 90 degree wash with white powder?
It does have to be white powder rather than colour powder or any kind of liquid, becauses only white powder has bleaching agents.
Add it helps if you leave the machine empty or clothes, towels etc.
Washing machine smells are usually caused by mildew, and a 90 degree wash with bleaching agents ought to help. If you do this about once a month it should keep the machine clear of mildew.
Jul 25, 2011 | Washing Machines
Smelly front loader washing machine. Clothes come out smelly too. How did I fix the problem???
You may have to do this 2 times and you will never find this in any manual. Use 1/4 cup "Powdered" Dishwashing soap and 1 cup of bleach in an empty tub cycle. Run a load of older dark clothes or non flammable rags FIRST after doing this the first time. If they come out with streaks run the cycle of 1/4 cup Powdered dishwashing soap and 1 cup bleach again. Same routine after 2nd cleaning cycle... dark clothes check for anything out of the ordinary. You should not have to do it a 3rd time unless your machine is really gunked up. Hopefully your using HE type soaps in your front loader. Non HE laundry soaps will cause the smelly machine also.
Thanks for using FixYa.
Kelly
Mar 29, 2010 | Washing Machines
LAUNDRY SMELLS BAD
take out powder compartment its more likely its gone all black....also in side of the machine... get white vinager clean all inside and powder capartment .... put 2 ltrs of white vinager in drum place powder unit back were it should be..... turn machine on with no cloths in on full heat wash (boil wash)....wash through again with powder when finished ....twis before putting any cloths in ..there you have it ...oh check pump filter befor all this :)
Dec 30, 2009 | Bosch WFL 2063 Front Load Washer
White residue om dark clothes
Even if you use liquid detergent, if you put too many clothes in the washer, or too much detergent. It has happened to me before.
May 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
AEG Lavamat 16810 Front Load Washer/Dryer Logo
239 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
