Frigidaire GLET1142CS0 washer wont spin
Hi, I have a Frigidaire Glet1142CS0 washer/dryer combo. The washer fills up and agitates then when it gets into the spin cycle it empties but doesnt spin. I took the front panel off and you can see the motor turning when the tub supposed to spin (so I know the motor is good) also I checked the spin lid switch and that also seemed good. any Ideas what would cause this problem? I hope it's not the transmission!
  • 3 Answers
I Changed the TUB belt and now it spins.
Posted on Jun 12, 2008
Troubleshoot washer
Leslea,
You might check your lid switch for the washer. It sounds like the controls are thinking the lid is still up and that will normally not allow the agitation and spin to work properly.
May 25, 2015 | Frigidaire GLET1031 Top Load Stacked...
I have a frigidaire heavy duty extra large capacity 2 speed combination 3/4 horsepower.washer dryer. The washer fills,drains and spins. It does Not agitate. I can spin the tub counter clockwise. The thingy...
Hello Marjorie, thank you for your post!
From the information you have provided water will fill, drain and spin but your Frigidaire washer is not agitating. This could be a problem with your motor, belt, or pulley. Locating the problem is not a simple DIY job and I would suggest seeking assistance from a professional. They have the appropriate tools needed to disassemble your washer and prevent any future issues. I hope this information is helpful to some degree. -Matt
Mar 10, 2015 | Frigidaire Washing Machines
My Frigidaire FLSE60RGS1 washer/dryer combo. the washer does not agitated it spins but doesn't do the washing movement stuff
Hi friend, I appreciate your post!
Based off the information you have provided regarding your Frigidaire laundry center it sounds like a possible problem within your control panel or agitator. Since it could be any one of these underlying issues I would recommend having a professional come out to your home to properly diagnose your washer. If you do not have a professional connection you can visit the manufacturer website to find a service provider in your area. Hopefully this is helpful. -Matt
Sep 24, 2014 | Washing Machines
Older maytag stackable washer and dryer combo washer fills , washes and spins but water wont pump out
check for the pump belt broken or off,clogged pump or sock or small item clogging the tub outlet to pump hose. the pump pulley may have become loose on the shaft also
Feb 28, 2013 | Maytag LSE7806A Top Load Stacked...
Washer not agitating, fills, spins and drains but wont agitate. grease at bottom of shaft above belt puley
Check the splines on the drum. Take the cap off and remove the lock for the nut, take the nut off and you can pull the whole agitator out of the drum. Look at the splines on the shaft and in the agitator. Make sure they are not worn down to nothing.
Oct 14, 2012 | Frigidaire FEX831CS Top Load Stacked...
We have a frigidaire washer dryer combo. after a bad storm (our electric kept flickering off and on) our washer no longer works. we noticed that it would only fill up with water while dryer was on. now it...
Possible damage on the program control panel as it is most likely to be damaged due to a power outage. remove panel and check to confirm if the board is burnt or damaged
Jul 03, 2012 | Frigidaire FLEB8200DS Top Load Stacked...
I have a frigidaire glet1142cs0 top load stacked washer/dryer. the dryer turns but doesn't heat. not sure how to change the fuses or the heating element. please help
UNPLUG THE MACHINE. Take the back off the dryer, usually 4 to 6 screws. On the backside of the panel you just took off should be a schematic showing where the thermo fuses are.
Take an ohm meter and check across the prongs sticking up, you may have to unplug them to get good contact. They should show 1, open, if they show 0, short. they need replaced. There are online parts companies that can help you get the right part.
It is unlikely that the element is bad, but if the thermo fuses show open, then you should be able to see the element, and replace it.
Mar 26, 2011 | Frigidaire GLET1142CS Top Load Stacked...
Washer does not agitate
hi thanks for the question it looks like a problem with the transmission but only if afer the water fills the tub the motor starts running if te motor docent start after its full look for a timer problem . so if motor runs on wash cycle and no spin transmission problem thanks the appliance doc please rate me.
Feb 23, 2008 | Frigidaire FEX831CS Top Load Stacked...
Washer repair
The transmission might have locked up causing the motor to overheat.
Nov 10, 2007 | Frigidaire FWS833A Top Load Washer
Washing Machines Logo
167 people viewed this question
Top Washing Machines Experts
