Question about Mr. Coffee ARX23 / ARX20 Coffee Maker
MR. Coffee ARX23/ARX20 permanent filter
What size permanent filter should I use for this machine?
    Master:
  • 497 Answers
8-12 permanent filter...i also came across that "MR. COFFEE® brand" is a good brand .
Have a nice day!
tc
Posted on Jun 10, 2008
Need a manual for JWX27
You can find the manual for this coffeemaker directly at the following link (for as long as it lasts): http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-mr-coffee-Site/Sites-mr-coffee-Library/default/v1414150683537/documents/instruction-manuals/JWX27_43_56431310.PDF
With this coffeemaker, you can brew with the cover open. I recommend observing a brew cycle to see if the coffee with floating grounds are overflowing the filter into the strainer basket. If this is the case, inspect the strainer basket's valve to make sure it is not blocked and working properly. Also make sure the pot is fully in place so that the lid aligns properly with the strainer basket to open the valve adequately. Otherwise, the filter and/or the coffee grounds are too fine. I recommend a permanent filter basket (around $5) and course-ground coffee. Both will add to better tasting coffee.
Oct 08, 2012 | Mr. Coffee JWX27 12-Cup Coffee Maker
How do I set the delay brew?
hold delay brew button in with one hand while setting hour, then min.. Make sure clock has rolled over to AM if you want morning. Also make sure the correct time is set on pot.
Apr 04, 2011 | Mr. Coffee ARX23 / ARX20 Coffee Maker
The red light on my coffee pot is on and will not go off. I have run cleaner thru the regular cycle now what? Its a 12 cup programmable Mr. Coffee.
I know this sounds like a pain but it takes a while toget that silly light to stop. Decalcifying your MR. COFFEE® Coffeemaker Minerals(calcium/limestone) found in water will leave deposits in your coffeemaker andaffect its performance. It's recommended that you regularly remove these depositsusing MR. COFFEE® Cleaner or vinegar. MR. COFFEE® Cleaner is available at manyretail stores or by calling the MR. COFFEE® Consumer Service Department at 1-800-MR COFFEE(1-800-672-6333). 1. Follow packageinstructions to prepare one batch of MR. COFFEE® Cleaner. Pour the mixture into the water reservoir. Before decalcifying,remove the water filtration disk from the machine. NOTE: 4 cups or 20 fl. oz. of undiluted, white householdvinegar may be used as a substitute for the cleaner. 2. Place an emptyMR. COFFEE® 10-12 cup basket-style paper filter or MR. COFFEE® permanent filter into the filter basketand slide the brew basket in place. 3. Place theempty decanter back in the unit. 4. Press theCLEAN button until the CLEAN indicator light turns on (Figure 9). For your convenience the cleaning cycle isautomatic. The entire cycle will take 45-60 minutes to complete. During thecleaning your coffeemaker will: a. Slow brewapprox. 3 cups of cleaning solution. b. Pause for 30minutes (the CLEAN light will remain on to alert you that the process is active). c. After 30minutes, your coffeemaker will brew the remainder of the cleaning solution. d. When complete,the CLEAN light will turn off and your coffeemaker will turn off. 5. Discard the cleaning solution and rinse the decanterthoroughly with clean water. 6. Fill the water reservoir with clean, fresh water. 7. Place the empty decanter back on the coffeemaker. 8. Remove and discard the paper filter usedduring the cleaning cycle. If a Mr. Coffee® permanent filter was used during cleaning, remove it andrinse it thoroughly before replacing it in the filter basket. 9. Begin brewingand allow the full brew cycle to complete. 10. Repeat steps 5 through 9 one more time.
Mar 31, 2011 | Vacuums
This morning when my wife went to make coffee. The clean light came on. we couldn't get it to shut off. She went through the clean cycle.The light came back on again. What should we do ?? Mr. Coffee...
I know this sounds like a pain but it takes a while to get that silly light to stop.
If you have problems call the 1-800 number below.
Decalcifying your MR. COFFEE® Coffeemaker Minerals (calcium/limestone) found
in water will leave deposits in your coffeemaker and affect its performance. It's
recommended that you regularly remove these deposits using MR. COFFEE® Cleaner
or vinegar. MR. COFFEE® Cleaner is available at many retail stores or by calling the MR.
COFFEE® Consumer Service Department at 1-800-MR COFFEE (1-800-672-6333).
1. Follow package instructions to prepare one batch of MR. COFFEE® Cleaner. Pour the
mixture into the water reservoir. Before decalcifying, remove the water filtration disk
from the machine.
NOTE: 4 cups or 20 fl. oz. of undiluted, white household vinegar may be used as a
2. Place an empty MR. COFFEE® 10-12 cup basket-style paper filter
or MR. COFFEE® permanent filter into the filter basket and slide
3. Place the empty decanter back in the unit.
4. Press the CLEAN button until the CLEAN indicator light turns on
(Figure 9). For your convenience the cleaning cycle is automatic.
During the cleaning your coffeemaker will:
a. Slow brew approx. 3 cups of cleaning solution.
b. Pause for 30 minutes (the CLEAN light will remain on to alert
c. After 30 minutes, your coffeemaker will brew the remainder of the cleaning
solution.
d. When complete, the CLEAN light will turn off and your coffeemaker will turn off.
5. Discard the cleaning solution and rinse the decanter thoroughly with clean water.
8. Remove and discard the paper filter used during the cleaning cycle. If a Mr. Coffee®
permanent filter was used during cleaning, remove it and rinse it thoroughly before
9. Begin brewing and allow the full brew cycle to complete.
Mar 27, 2011 | Microwave Ovens
The light is on to clean it and I do not have an owner's manual. Can you please explain? How do I get the light to stop blinking?
Most coffee makers are cleaned by filling the reservoir with undiluted white vinegar (3 cups). (Do not add coffee.) Remove the water filtration disk if you use it before starting. Then start the brew cycle as if making a cup of coffee (including putting a paper filter or the permanent filter in the filter basket and close the lid). Put a decanter on the warming plate. After brewing, turn off the coffee maker and let stand for 30 minutes. Run another cup of vinegar through the coffee maker. Take the decanter filled with vinegar and discard the liquid (pour down the sink drain). Rinse the decanter. Fill the reservoir with clean water and put in a new paper filter (or clean the permanent filter and put it back). Again do not add coffee. Run a brew cycle to rinse the unit. Discard the water that is in the decanter after the brew cycle. Do a second clean water only brew cycle (with new empty paper filter or permanent filter after cleaning again). However, if you notice an odd taste, repeat the rinse cycle.
You can alternatively use the Mr. Coffee Coffee Maker Cleaner (mix as directed on that package). In either case, this removes mineral deposits (calcium from hard water). For soft water, the cleaning should be done every 80 brew cycles. If you have hard water, do this every 40 cycles.
The manual is available from www.mrcoffee.com/Product.aspx?pid=121 , if I have the correct product version. For some reason this site isn't coming up for me today. Check the manual to find out if there is any specific details for cleaning that aren't shared with other Mr. Coffee products.
I hope this helps.
Oct 29, 2010 | Mr. Coffee 12-Cup Programmable Coffeemaker
Our Mr Coffee maker has slowed down since new, it's a 4 cup size
Hi, Don't have much to work with here so I will do the best I can, I am going to assume the water where you live has scale or calcium which builds up in the coffee maker over time. Go to your grocery store and buy some cream of tartar which you can find in the spice section, it is a white water soluble powder. Dissolve about a teaspoon full in a pot of your coffee water, put in a filter with nothing in it and cycle the water through the coffee maker, if it is really scaled up do this a couple of times, discard the filters which probably will have some little white and yellow chunks in it and this should speed her back up. Good Luck!
Feb 02, 2009 | Mr. Coffee CGX20 12-Cup Coffee Maker
Won't Brew. No water from resovoir to fileter.
To clean your coffeemaker:
1) Pour four cups of undiluted white household
vinegar into the water reservoir.
2) Place a paper filter into the removable filter
basket and close the brew basket lid.
3) Place the empty decanter on the
warming plate.
Make sure to accurately place the
to avoid the possibility of overflow.
4) Start the brew cycle:
a. Turn the switch to On. Then, press the
brew button to begin the brew cycle.
b. When the water has flowed into the
decanter, turn the coffeemaker Off
and let the water stand for 30 minutes.
c. Repeat Steps 1 – 4b.
Have a nice day!
tc
Apr 16, 2008 | Mr. Coffee ARX23 / ARX20 Coffee Maker
Carafe Replacement
Medelco, Inc. Makes one. www.medelcoinc.com
It's their model number GL220
Nov 21, 2007 | Mr. Coffee ARX23 / ARX20 Coffee Maker
Mr. Coffee ARX23 / ARX20 Coffee Maker Logo
81 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Henry  Thomas
Henry Thomas
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
