Question about Belkin Computers & Internet
Hi, I have a desktop and a wireless router. The desktop was connected to the internet via a Belkin USB wireless adaptor but it has suddenly stopped and does not pick up any signal. I have uninstalled and reinstalled the software and have gone through the software from the Internet provider. The wireless router is working as it works on my laptop, however it is not connecting to the USB wireless connector.
  • 20 Answers
Belkin products are notorious for breaking down at a high rate. If you wanted to rule out your computer as the culprit, you could install the belking adapter on your laptop (disable the built-in one) and see if it still works. I would also suggest going here:
http://www.belkin.com/support/
and typing in your product model # and downloading the latest firmware/software for it. As always, restart your computer.
Posted on Jun 10, 2008
What is a belkin n wireless usb adapter model # fsd8053v4 used for and can u connect to the internet with it and where do i get the driver?
The wireless adapter is used to connect wireless to the internet, You can use it to make your desktop wireless and laptop.
You can connect to the internet as long as you have a wireless router in your place that will supply the wireless signal.
The driver can be download on this website
cheers,
KA
Jun 15, 2010 | Linksys Wireless-G WRT54G Router
Trying to create a bridge with two routers
You do not need a bridge if you are using a wireless adaptor on your pc in the other room. Just set up the Belkin Plus router to the WEP security settings you want and make sure the pc wireless usb adaptor has the same settings as the router. You should be good to go. Good Luck.
Jul 15, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have a Belkin Wireless adaptor and a wireless router. The netgear adaptor I had before on my desktop got borken so I replaced with a Belkin adaptor. The new Belkin adaptor is not recognizing the wireless...
Hi, did you provide the network key/password when you setup the wireless conection on your computer? Is it detecting your wireless router (you should see your SSID or network name) when you click on your wireless icon (in the taskbar) and chose "show wireless connections". If you can acess to your router via it's configuration page(type the router's default IP address in your browser) you can go check the settings and change the key/passphrase if you dont remember it. If all of this is not working, you can also start from stratch. Reset the router to factory settings (check your manual) then reconfigure it the way you want, put the new infos in your wireless network connections properties and try again. let me know with more specific details if you still cant do it
Jun 08, 2009 | Belkin Wireless Desktop (F5D7000FR)...
Two PC's,no access to internet upon PC connected by Adaptor.
solution 1:Reset the new password for accessing for internet.
solution 2:check with adapter.plug out and plug in the adapter(and also antenna too )
Feb 27, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Cant get router to access internet
The easiest way to set up this router is to connect it via ethernet cable and then access the router with the default ip address and configure it from there
Dec 08, 2008 | Belkin N Wireless Modem-Router F5D8633au4A
I unplugged the cable connected to my desktop and the wireless function stopped working
You must always have a 'host' adaptor whether you want a LAN or a WAN. Go to your configuration utility or control panel via your Run command to set or view your options. Steve Medley
Nov 07, 2008 | Belkin (F5D8231-4) Wireless Router...
What is a desktop card? Belkin Wireless G Router questions too.
The only thing you need is a network connection in the back of your computer if you are going wired or a wireless adaptor for each device if you want to connect that way.
I understand the Wii has wireless built into it but you might want to check on that.
Jun 13, 2008 | Belkin (F5D7230-4) Router (587009)
When using the Belkin G router the network connection becomes lost and can not get on the internet. My computer has Vista on it and Belkin says that the router is compatible with the program.
This is possibly caused by your firewall or the wireless security (wpa/wep) on the router if you have set it up.
First of all, if you can connect to the internet via a cabled connection the problem is going to be with the way you've set the router up.
If you've setup wireless security on the router, have you also set it up for your wireless adaptor?.
I suggest you try to connect to the internet via cable to start with, if this works try to connect wirelessly with your firewall off.
If all else fails start from the beginning again.
May 15, 2008 | Belkin Computers & Internet
D-Link wireless router and Belkin Wireless G USB Network adapter
Set your wireless network as a preferred network and to automatically connect to it. Also set it at the top of the list so that it takes precedence. If you continue to get conflicts, change the channel of the router.
Mike
Oct 31, 2007 | Computers & Internet
Belkin F5D8630 wont take my new log in details
check to see if all of the ssid's are all the same or if there is another wireless system interfering.
Sep 11, 2007 | Belkin (A3L85014BLS24)
Computers & Internet Logo
116 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
