Question about Carrier Access Bank I Multiplexer (930-0002)
Need link to a manual
I have a Carrier Access Corporation Access Bank 1 T1 channel bank. I am switching T1 carriers and on the new T1 the analog sets that are connected constantly ring. I can go off-hook on any one of them and get dialtone though. The new carrier says that commonly they need to have the vender change their equipment to 4 wire E&M signalling instead of Loop or Ground start. I cannot seem to find where I can change this setting. The line coding and framing are all correct, so it seems that this would be the issue but I don't know if the channel bank can do it.
  • 497 Answers
Http://, i dnt know if this wud help..please check it out
Have a nice day!
Posted on Jun 10, 2008
I have a carrier debonair 450 it is blank and not working it does not take batteries. needing help
Carrier Thermostat 33CS450-01 User's Guide ... > ... > Carrier Thermostat
Appliance manuals and free pdf instructions. Find the user ... Carrier 33CS450-01 Thermostat User Manual. Page 1 ... Carrier Corporation 04/06. Use with most ...
Sep 10, 2015 | Home
How do you adjust valves on a 2006 3.5L V6 Toyota Avalon?
There is a Toyota Technical Service Bulletin issued for this:-
T-SB-0291-08 September 11, 2008 2GR-FE Valve Timing
Procedure Service Category Engine/Hybrid System Section Engine Mechanical Market USA Applicability YEAR(S) MODEL(S) ADDITIONAL INFORMATION 2005 - 2009 Avalon 2007 - 2009 Camry VDS(s): BK46K 2008 - 2009 Highlander 2006 - 2009 RAV4 Engine(s): 2GR VDS(s): BK31V, BK32V, BK33V, BK34V, ZK31V, ZK32V, ZK33V, ZK34V, ZK35V 2007 - 2009 Sienna Introduction This service bulletin provides information regarding valve timing inspection and service guidelines for vehicles equipped with 2GR-FE engines. © 2008 Toyota Motor Sales, USA Page 1 of 5 T-SB-0291-08 September 11, 2008 Page 2 of 5 2GR-FE Valve Timing Procedure Introduction (Continued) Figure 1. 3 2 1 5 9 8 7 6 4 1 RH Bank Intake Camshaft Timing Gear 2 RH Bank Exhaust Camshaft Timing Gear 3 RH Bank No. 2 Timing Chain 4 Crankshaft 5 Idler Gear 6 Timing Chain 7 LH Bank No. 2 Timing Chain 8 LH Bank Exhaust Camshaft Timing Gear 9 LH Bank Intake Camshaft Timing Gear Warranty Information OP CODE DESCRIPTION TIME OFP T1 T2 N/A Not Applicable to Warranty © 2008 Toyota Motor Sales, USA T-SB-0291-08 September 11, 2008 Page 3 of 5 2GR-FE Valve Timing Procedure Inspection 1. Set the No. 1 cylinder to TDC/compression. A. Set the timing mark to 0 on the timing chain cover by rotating the crankshaft clockwise. B. Verify the timing marks on the camshaft timing gears are in general alignment with the timing marks of the camshaft bearing cap: TIMING MARK IDENTIFICATION CYLINDER BANK INTAKE GEAR MARK EXHAUST GEAR MARK RH Bank (Bank 1) Small Mark Single Line LH Bank (Bank 2) Large Mark Double Line HINT When the engine is correctly timed, the timing marks will NOT perfectly align. Figure 2. Figure 3. RH Bank Exhaust Camshaft Timing Gear 1 2 1 Bearing Cap Timing Mark 2 Gear Timing Mark Figure 4. RH Bank Intake Camshaft Timing Gear 2 1 1 Bearing Cap Timing Mark 2 Gear Timing Mark © 2008 Toyota Motor Sales, USA T-SB-0291-08 September 11, 2008 Page 4 of 5 2GR-FE Valve Timing Procedure Inspection (Continued) Figure 5. LH Bank Intake Camshaft Timing Gear 1 2 1 Bearing Cap Timing Mark 2 Gear Timing Mark Figure 6. LH Bank Exhaust Camshaft Timing Gear 1 2 1 Bearing Cap Timing Mark 2 Gear Timing Mark HINT If the timing marks appear vastly out of alignment, turn the crankshaft one revolution (360 ) clockwise and note the position of the timing marks. Component Removal Guidelines 1. If engine disassembly is required that involves removing the camshafts or timing gears, set the #1 cylinder to TDC compression, wipe away any oil, and mark the following items in relation to each other prior to disassembly: • Timing gears • Timing chain • Timing chain No. 2 NOTE This relationship MUST be maintained. The intake gear is timed in relation to the crankshaft via the timing chain; the exhaust gear is timed in relation to the intake gear via the No. 2 timing chain. © 2008 Toyota Motor Sales, USA T-SB-0291-08 September 11, 2008 Page 5 of 5 2GR-FE Valve Timing Procedure Component Removal Guidelines (Continued) 2. If NEW camshaft timing gears or the No. 2 timing chain are being installed, the two yellow links on the No. 2 timing chain can be used to ensure correct relationship between the intake timing gear and the exhaust timing gear. Figure 7. 1 1 Yellow Link A. Align the paint mark on the timing chain with the intake gear timing mark (to ensure the intake gear is correctly timed to the crankshaft). Figure 8. RH Bank and LH Bank 3 3 4 3 3 4 5 4 5 4 1 2 1 RH Bank 2 LH Bank 3 Yellow Link 4 Gear Timing Mark 5 Timing Chain Paint Mark B. Align the two yellow links on the No. 2 timing chain to the timing marks on
May 04, 2015 | 2006 Toyota Avalon XLS
Secret Code
is this another form of social hacking? Shouldn't you contact the commercial provider (Wide Bank?) and not some random people on the internet??
May 21, 2013 | Carrier Access Wide Bank 28 W/ 2...
I have the BC370CRS SCANNER I am trying to clear all the memory and reset it. It is telling me to hold down 2, 9, and hold and turn it on. That is not working. Can you please tell me another way to do...
Locking/Unlocking Banks When you are scanning conventional banks, the scanner displays the digit corresponding to all unlocked banks. To lock out a bank so that the scanner does not scan its channels, press the letter that corresponds to the bank. The bank's letter disappears from the display. To unlock locked-out banks, simply press that bank's letter again. The bank's letter appears on the display and the scanner includes that bank when scanning. Note: You cannot lock out all banks. One bank must be unlocked at all times. Locking/Unlocking Channels To lock out a channel so that the scanner does not stop on it while scanning, press L/O when the scanner is stopped on that channel, or manually select the channel and press L/O. To unlock the channel, manually select it and press L/O again. Restoring All Locked Out Channels You can restore all locked-out channels in a bank only when the bank is selected for scan. Follow these steps to restore all locked-out channels in a bank. 1. If you de-selected the bank, press SCAN then press the bank's letter. 2. Press MANUAL. 3. Hold down L/O for about 2 seconds. The scanner beeps twice and unlocks all To delete a stored frequency, press 0 then press E. Channels with no frequencies are automatically locked out hope this helps
Mar 29, 2011 | Uniden BC370CRS Base Scanner
Does anyone have modem setting and cable pin out for a Wide Bank 28?
The pin out is the usual RS-232 (25-Pin TL1 or 9 Pin TL1). If they are not working, check if they got disabled.
You can find the documentation on It also describes how to handle the xmodem.
Mar 14, 2011 | Carrier Access Wide Bank 28 DS3...
Displays Error Code 1203 - What is that? User Manual is lost.
The error 1203 error message on the operator panel could indicate a problem with one of the ink cartridges. Please follow the steps given below:
1. Please make sure the All-In-One is powered on.
2. Pull the control panel towards you, and then open the cartridge access door. The print cartridge carrier moves and stops at the loading position.
3. Pull the old cartridges towards you, and then lift them out.
4. With the cartridges out of the printer, shut the access door and the control panel.
5. Power the printer OFF and then back ON.
6. Please check the operator panel to see if the same error has returned or if a new message has appeared.
7. If the message displayed is 1203, there is something wrong with the printer hardware.
If the message now displaying is Cartridge Missing, do the following:
1. Reinstall the cartridges into the printer.
2. Insert the color cartridge in the left carrier. Insert the black cartridge in the right carrier.
3. Push back firmly on the cartridges until they snap securely into place.
4. Close the cartridge access door, and then close the control panel.
5. If the 1203 message is still present on the operator panel, you need to insert one cartridge at a time to determine which cartridge is producing the failure.
6. With one cartridge in the carrier, close the access door and control panel.
7. Please check the operator panel. If the 1203 error is displayed, this cartridge is the defective item. If the Cartridge Missing message is displayed, the second cartridge is producing the failure.
8. Please replace the defective cartridge.
May 05, 2009 | Lexmark X7170 All-In-One InkJet Printer
Phone only rings three times before going to my message bank
If its going to your carriage service provider message bank then you need to reset this for a longer period. The carrier message bank is managed by the carrier.
If the cordless has an answering service, then you need to scroll through the menu on the phone to select answering functions and select 6 rings or longer.
May 04, 2009 | Uniden Cordless Phone
D3000 with orion chanal bank
please give me an clear details..
Dec 15, 2007 | Quintum Tenor D3000
Carrier Access Bank I Multiplexer (930-0002) Logo
178 people viewed this question
Top Carrier Computers & Internet Experts
Martin Murray
Are you a Carrier Computer and Internet Expert? Answer questions, earn points and help others
