Motorola Mobility V220 Logo
Posted on Jun 10, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Electrical Problem with my Old v220 Phone
This problem prompted me to replace this phone a couple years ago but I was wondering if I could perhaps fix it now so that I have a backup phone if my current one craps out.
When powering up the phone, it loads successfully and functions normally, but 5-10 seconds after powering up it suddenly cuts power, and further attempts to turn it back on result in the lights of the phone flashing on and then off when not plugged into the wall charger. When plugged into the wall charger, the lights seem to be permanently stuck "on" at about half the intensity of normal, and it *looks* as if there is a short in the main power circuit. It is willing to turn on normally again after about 5 minutes. It's as if there is a short in the main power circuit somewhere, but after taking the phone apart, no obvious problems jump out at me. I thought the battery might have a bad connection in the contacts, so I added a small bead of solder to each one, but it still exhibits the same behavior. I've tried power the phone up with the BIOS battery(s) taken out but it still behaves the same. I've read that this seems to be a common problem with all Motorola phones to this day. Is this perhaps a problem in the circuitry? Or a faulty chip or other component?
Thanks,
Calculon000
Anonymous
Level 3:
Brigadier General:
  • Master 7,752 Answers
  • Posted on Jul 02, 2008
Anonymous
Master
Level 3:
Brigadier General:
Answers
7752
Questions
Helped
1414973
Points
13016
Not to sure what it really is why them...but you can take the phone and have the firmware reflash or upgraded on the phone for this to work
1helpful
I have just found my mobile phone LGCE0168 after losing it 6 months ago. How can I restart the Tesco PAYG sim card
I am wondering if you have tried another sim card in your newly found phone?
In theory there should be no problems just put your sim back in and make calls.
I am wondering If Tesco have changed service provider in the last 6 months? If they have it could explain your problem.
Asda mobile changed provider about a year ago from Vodafone to EE and my phone stopped working because it wasn't an unlocked phone. As it turned out I had to replace my phone for one that was unlocked because it wasn't worth the expense and trouble of having the old one unlocked. The old one still works fine on Vodafone and O2.
Just a thought. Another thought is perhaps it developed a fault while it was lost or maybe someone has been fiddling with it in that time.
There are lots of aftermarket phone shops around with specialists to give advice. The Tesco helpline might be able to help.
Feb 02, 2015 • Cell Phones
My phone wont get a charge
Hi
Have you tried this:
Replacing the changer.
Replacing the phone's battery.
If you have,then you may have to have it checked in a repair shop.
If its couple of years old,may be time for replacement perhaps.
Mar 06, 2012 • Cell Phones
1helpful
Blank screen motorola v220
You should store your numbers on your sim its safer. But the answer to the problem is you cant unless you replace the screen. Alternatively you could try adding an external phone screen via the phone usb port.
2answers
Gas leak
you should call service
take the phone and have the firmware reflash on the phone this will correct the issue you are having.
Subsidy password
Stop posting IMEIs It dont do any good.
If its an old cingilar, cust service might unlock for you..
Otherwise the is no ^%^$^**^ IMEI unlock thing for the V220.
Just stop it already.
Google any of the following steps..
USB adapter
Motorola P2K drivers for XP
Motorola or other flash tools
enter phone service mode
connect phone to pc
flash back to V 364 firmware
run unlocker
flash unlock firmware
enter dummy unlock
reflash to v365 firmware
More details googling above and reading lots
OR.. Pay $10-20 have someone else do it...
I wont, too much work...
Motorola v220
not really you need to have the microphone check on the phone it could need replacing or servicing so take it to a mobile technician to hvae it fix.
Screen wont work
If you have a dead screen: You must Disconnect the ribbon cable between main case and LCD screen. be carefull lifting the connector and put it back in place. To reach the ribbon cable, you have to disassembly the phone. Google search with 'Motorola V220 Full Housing Installation' for a detailed procedure with pictures. attention: It may void any waranty!!
8answers
Motorola v220
you got a very easy to do problem but you gona need another v220 and some help, what we do is working step by step with the 2 celu tell your friend to go on the good one and you do the same in yours it well do ti or take your celu to the store threy have yonks for solve that problem and beliveme there will be a large cuantities of v220....good luck
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
