Question about HP Pavilion dv9000z Notebook
Hard drive or fan click?
I recently got a new HP Pavilion dv9700 notebook and it seems to be running fine. However, every so often I hear a clicking noise from the left side of the keyboard. It sounds to me like the dreaded hard drive click but I can't be sure. Seems to read and write fine to the hard drive. The sound happens sporadically and can't be re-produced. I'm wondering if this could also be the CPU fan clicking on/off?
Thank you!
  • scott_s63043 Jun 10, 2008
    Hey, thanks for replying. Forgive me but how do view/edit this setting?
    Thanks for your help. I made the adjustment you recommended. I have my fingers crossed that it's just a noisy hard drive and the click that I hear is actually indicative of something positive happening. :)
    Thanks again!
  • HP Master
  • 5,568 Answers
Very unlikely that you are hearing any fan turn off and on since these are temperature controlled varable speed devices, not serviced by a relay that you can hear.
Some hard drives are audible even when working normally so that is not necessarily a sign of a dying drive.
Check your system settings to see if the drive is set to park and turn off too often.
I keep mine set at 30 minutes so it isn't cycling more than needed or running all the time.
Posted on Jun 10, 2008
  • Steve Allison
    Steve Allison Jun 10, 2008
    If HP hasn't fooled with the Windows Control Panel (I'm not a fan) you should find a folder named Power Options.
    There are several tabs but the default tab lets you choose how long you want the monitor and hard drive to wait before going to standby.
    If you tend to leave your system on from AM to PM, it wouldn't hurt to set these so if you are ignoring the system for a while, it can save some power and a little wear and tear on some items.
    Again, if it has not been altered or 'improved,' you should be able to access the Control Panel via the 'Start' menu.
    You will see a multitude of folders that let you improve or totally trash your system operation.
    You might want to open each folder just for gaining some insight into things you might want to toy with if your schedule permits.
    Anything that can be dangerous is customarily accompanied by a warning though so most 'dangerous' things can only be changed intentionally.
My dv9700 came up with startup system error in windows 7..error wont allow this to boot and telling me to replace hdd..can i repair this instead
Chances are you need a new (bigger) Power supply in it and a new hard drive. The power supply did not provide enough power to the hard drive at some time recently and the files written to it by windows have been corrupted.
Dec 19, 2013 | HP Pavilion dv9500 dv9600 and dv9700 FF...
HP Pavilion dv7-1285dx keeps overheating and shutting down
sure it does all PCs do that, full of lint, all do.
we clean it.
it has fan and vents
all fans all vents and heatsinks must breath or it overheats.
all do that not cleaned, drive your car around with the radiator blocked, boom.
all PCs run slow overheated, by DESIGN.
this slow down , reduces heat, and saves CPU/GPU burn up.
just like my chevy, truck, it cuts cylinders to save the engine.
same deal both.
same deal; same reasons.
http://www.pcdied.com/overheated.html
Aug 15, 2017 | HP Pavilion dv7-1285dx Notebook
My HP laptop (pavilion dv9700) will not start up. It was working fine then suddenly shut off while the cord was plugged in. The blue ring still lights up where you plug in the power chord, but nothing else...
Try the following:
  1. Unplug the power cord from the laptop.
  2. Remove the battery.
  3. Press and hold the power button for 10 seconds.
  4. Re-insert the battery.
  5. Plug in the power cord.
  6. Try turning on the computer.
Jun 07, 2011 | HP Pavilion dv9000z Notebook
I cant hear anything on my hp pavillion dv9700 laptop. how do i fix it.
You need to install your sound driver. Ig you fo to this HP website below there you will be able to find and download your sound driver and audio manger too.
http://h10025.www1.hp.com/ewfrf/wc/searchResults?product=3636841&tmp_qt=driver&tmp_product=HP+Pavilion+dv9700+CTO+Entertainment+Notebook+PC&lc=en&dlc=en&cc=us
Once installed ensure the speaker is plugged in correctly,and not Muted.
Jun 18, 2010 | HP Pavilion (PN153AAR) PC Desktop
HP Pavilion dv9700 will not see its hard drive please help
If the hard disk is absent in the BIOS then it has died, nothing you can do, replace it.
Apr 13, 2010 | HP Pavilion dv9500 dv9600 and dv9700 FF...
How do u take out hard drive on a hp pavilion dv9700
Hello
This should give you a good idea on what steps to follow.
Just click on the link and you will be directed to a page where you can see step by step instructions in regards to the HP pavillion series.
http://www.insidemylaptop.com/remove-hard-drive-memory-wireless-card-keyboard-hp-pavilion-dv9000/
Kind regards
Andrea
Dec 16, 2009 | HP Pavilion dv9700t Notebook PC
Hi, my DV9700 battery does not charge, adapter works but does not charge or run the computer on its own. I have had it checked and everything seems fine, they suggest the motherboard but I explained that...
This may sound stupid but try this, for some reason this seem to work on 6 and 9000 units with charging problems.
With the unit running, disconnect the battery and allow the unit to run for 60 seconds, then plug the battery back in, again with the unit running.
Nov 30, 2009 | HP Pavilion dv9500 dv9600 and dv9700 FF...
HP Pavilion dv9700 black after closing lid.
when you changed it to do nothing on battery or power did you save these settings........I know it is a silly question but it sounds like the laptop is going into Hibernate mode
Jul 31, 2009 | HP Pavilion dv9700t Notebook PC
HP Pavillion dv9700 won't power up
Try removing the battery and using only power cord to turn the laptop on. If that fails, try turning it on without power cord, just on battery.
If none of those work, then most probable cause of your problem is motherboard. Hopefuly you are either under manufacturer warranty or you have extended warranty with your vendor where you've purchased the laptop.
If your laptop turns on on power cord, but without battery, then battery is the problem. Also, if laptop turns on when it's only on battery but it doesn't when you plug ac cord in it, then the adapter is the problem.
Jun 01, 2009 | HP Pavilion dv9700t Notebook PC
HP Pavilion dv9000z Notebook Logo
138 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
