Question about Averatec 3200 Notebook
Besides the fan underneath the pc. it runs hot
As above mentioned this notebook runs hot, I saw a solution regarding heat problems with other averatec models, would I use the same criteria, regarding this heat problems.?
Thanks for your help
Mark
  • Anonymous Jun 12, 2008
    I used to use a fan to cool mine all the time. But the repetitive use took a toll on all my USB ports and none of them work. The laptop runs extremely hot all the time.
Low tech solution.
Have the same problem no matter what brand/model laptop I use. So what I do is take the bottlecaps off of a beer bottle and superglue them where the pads are located for a little extra space to vent heat. I also went in and pulled the heat sink for the CPU and the video (? really not to sure, there is a second heat sink and I pulled it) chip and put Artic Silver heat compound in place of the pads they use to transfer heat.
It doesn't sound like much but it helps dissapate alot of heat. My laptop still has some heat issues. But the only way I am going to get rid of those is if I use the bottlecaps off of a two liter for spacers instead of beer bottle caps. And that would, of course, defeat the purpose of having a laptop, or subnotebook in this case, as those caps protrude almost a full inch from the bottom.
Posted on Apr 22, 2009
  • Averatec Master
  • 5,568 Answers
Sad engineering-
See if one of the available aftermarket 'fixes' seems suitable for your units:
http://www.google.com/search?sourceid=navclient&ie=UTF-8&rls=GGLG,GGLG:2005-37,GGLG:en&q=laptop+cooling+base
This is unfortunately, not an uncommon problem. Modern processors dissipate way too much heat in a small area, one of the prices of ever more dense packing of circuits in the quest for more speed and processing power.
Posted on Jun 30, 2008
Dell Inspiron1410 running 50% CPU usage with no other processes running in background. This after a nice repair install of Windows XP professional. High fan noise and heating up! Thanks
Hello Saman Tarik,
Task manager may say there are no other processes running but if you look in the next tab, "Services" you will find there are many things running.
The processor will run at a lower percentage when it is not busy.
As for running hot, I would suggest that the heat sink fins need cleaning out, I was surprised at how much fluff had accumulated in them, preventing a good air flow.
I have upgraded my processor from 1.5Ghz to 2.5Ghz which runs hotter so I bought a ZALMAN ZM-NC1500 USB and the hottest my CPU has reached is 41 degrees when both cores are running at 100%.
I hope the above information is of use to you.
Kind regards,
Ron.
Nov 21, 2013 | Dell Inspiron 8600 Notebook
Samsung NP30535a-A03US Charger Or Powerjack Overheating
Hello Tanfe Deremy.
Your problem is defenitly the power jack. the pin in the middle of the p-jack got loose and this wiggeling contact is the reason for the heat.
regards
Gue.
Jun 28, 2013 | Samsung Np305e5a-a03us Notebook 15.6" Led...
Fan is running high all the time
Hello
Thank you for using FIXYA!
Let me start by stating the the revolution speed of the fan is directly linked to the heat experienced by the CPU on the motherboard. So, this typically points to an overheating issue.
At the link below you will be directed to a page which will give you step by step instructions on how to clean the CPU Heat-sink and fan.
Click HERE to navigate to the page.
If the problem still persists after you have tried the above mentioned, you will need to contact me so that we can look into the problem.
Feel free to let me know if you have any questions.
Kind regards
Lock123
Feb 21, 2011 | Computers & Internet
My gateway m520x will run shutt down
Sorry you are having trouble. Laptops run a little hot but I think you are right about the overheating. The cheapest fix is to get an underneath cooler from somewhere like Best Buy. They sell for around $20. To really fix the problem will require finding out why it is getting hot. Usually this is a program that is "hogging" the processor's time. There are programs available that will make your fans run faster and processor run cooler. Some are free. Some cost a lot. If the fan has stopped or slowed it needs to be replaced. If you are very patient you can attempt to replace it yourself but be aware many a laptop has died as a result of being opened improperly. My advice is take to a shop if under cooler does not help.
I hope this helps
Apr 04, 2010 | Gateway M520X PC Notebook
I have a presario R3000 notebook. just like to ask if the fan for ventilation underneath is working in a certain temperature. or it will automatimatically running when i plug in.. can some one help me....
There are several models of this notebook depending on the processor. Some only have one fan, otehrshave two. When operating the fan should start running. I have the higher spec R3000 and my fans start soon after the machine is turned on and sometimes throttle down if I have no activity. Upon starting to use it, they soon start again. Considerable hot air will come out the right back and side.
DO NOT block the air intake(s) on the bottom of the unit !!! You can burn up the processor.
Sep 25, 2009 | Compaq Presario R3000 Notebook
Acer 2420
Here you go:
http://www.nodevice.com/manual/acer/page9.html
Aug 21, 2008 | Acer TravelMate 2300 Notebook
Laptop running hot - Fan cycling on and off every 10-20 seconds
My guess is that CPU fan, it there is one, is not working properly and your computer is heating up. Is it turning off, too, occasionally after a period of time? Suggest a new CPU fan.
Jun 14, 2008 | Dell Inspiron B130 Notebook
Heat vents
The vents on the side are sufficient - but the fan should run when you turn it on. If the fan is broken or worn out, your computer will overheat and crash - fans can be replaced but a technician or service shop would need to do it, it's not easy to get laptops open. So, to fully answer your question, there is not supposed to be a heat vent on the bottom. But the fan should probably be running when you turn it on. If the seller of the laptop didn't mention a broken fan you might want to contact them and ask if they know.
Jun 10, 2008 | Dell Latitude D600 Notebook
Overheating with certain programs
Hi jennie,
One of the most common problems with older & a lot of newer notebooks has been battery's over heat & the system shuts down. I suggest you remove the battery & run off the AC power cord. Run the programs you mentioned & see if the notebook shuts down. This is only a test.
Packard Bell has a site where it can Diagnosis & Repair some problems loacated at this link. Try it.
http://support.packardbell.com/uk/item/index.php?m=home&pn=P820000001
Mar 07, 2008 | Computers & Internet
Averatec 3200 Notebook Logo
192 people viewed this question
Top Averatec Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Avishek Samaddar
Avishek Samaddar
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
