Question about Apple iPod nano
My ipod 4G does not turn on
My ipod doesn't turn on. How do I reset it?
Thank you
    Guru:
  • 158 Answers
You don't need to rset it, because I think your ipod is dead. This happened to me to. I was listening to it when I arrived at my destination, and I thought I turned it off and I put it in my pocket. Later that day when I went to listen to it, it wouldn't turn on at all. Aparently, it had stayed on. Hold the pause button for five to ten seconds. The apple symbol will appear on your ipod. Immeadility put it in your docking station before it goes away. Your ipod will turn on, and itwill start charging.
I hope this helps. Please rate my solution.
Posted on Dec 02, 2008
    Master:
  • 497 Answers
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Have a nice day!
tc
Posted on Jun 10, 2008
How do I reset an ipod mini 4G?
To reset iPod mini:
1. Toggle the Hold switch on and off (set it to Hold, then turn it off again).
2. Press and hold the Select and Menu buttons for at least 6 seconds, until the Apple logo appears.
Download Apple iPod Mini Manual
Aug 21, 2014 | Apple Mini IPod
How do you restore a ipod touch 4g
The fourth generation iPod is identified as the iPod with the click wheel and color display, and also known as the iPod Photo. All models of the iPod 4G include the click wheel and full color display, making it easy to view album artwork and photos. Subsequent versions of the iPod also have video capabilities. If you are having trouble with your iPod 4G, there is a series of steps you can follow to try to fix the problem. Start by resetting the iPod (see Below). http://www.apple.com/support/ipod/five_rs/photo/ If this doesn't do the trick, you may need to restore the iPod, which replaces potentially corrupt software components. Doing so will erase all the iPod's files, so you should make sure you have your files backed up in the iTunes Library.
Download and install the latest version of iTunes. Open the program. Connect your iPod to your computer using a USB cord. Select your iPod from the device list in iTunes once it appears. Click "Restore" on the "Summary" tab of the main screen. iTunes will prompt you to select from one or more restore options. Choose how you want to restore the iPod. The first part of the restore will begin. You'll see a progress bar on the screen. Leave the iPod connected to finish the restore, as iTunes prompts you to do. The iPod will now show an Apple logo and progress bar on its screen. Follow the prompts of the iTunes Setup Assistant when it appears onscreen. Enter a name for the iPod. Choose your syncing preferences. Reload your iPod files from the iTunes Library.
Apr 07, 2013 | Apple iPod touch 4th Generation MP3 Player
It wont turn on. i have tried to reset it but all that appears is an apple then it ticks and the screen turns white and it directs me to the apple website then turns off
Welcome to Fixya
Looks like the software just hanged-up on you. Try to reset the Ipod by following the procedures below.
1st option:
Turn the Hold switch on, then back to off.
Press and hold the Menu and Select buttons for 10 seconds (until the Apple logo appears).
You may need to repeat the reset several times.
If the reset doesn't help, then put the iPod into forced disk mode.
2nd option (Disk Mode):
Plug the iPod into a high-powered USB port, let it sit for 2 hours, then disconnect it. If you have a wall charger, plug in the iPod, then follow these steps while it is still plugged in.
Press and hold the Menu and Select buttons until the Apple logo appears
Immediately switch your figures to press and hold the Select and the Play/Pause buttons until "Disk Mode" appears at the top.
For a lot of people, this solves the problem. Connect the iPod to the computer and (assuming it shows up) reset the iPod again to get it out of Disk Mode. If at this point you still have the white screen, restore the iPod using the restore function in iTunes under the Summary tab (this will erase everything on the iPod and put it at factory settings).
Note: Do not disconnect or eject the iPod until the store is totally done. After you think it's done, wait another five minutes.
Thank you for using Fixya!
Feb 25, 2011 | Apple iPod classic MP3 Player
A few hours ago, my ipod touch 4g had about half of the screen white. Is there any way i could fix it without paying?
Welcome to Fixya
1st option:
Dec 31, 2010 | Apple iPod nano
My ipod nano 4G is locked.
try plugging it into itunes and reformatting it to its original state, if that doesn't work turn it off by pressing the menu and play button, then directly aftewr push the menu and revers button, i think you can reset it from there.
Jul 24, 2009 | Apple iPod nano
My Ipod Nano 4G won't open
  1. First make sure that your iPod’s hold button isn’t on. This is the little switch at the top left corner of the iPod video that you can move to “lock” the iPod’s buttons. If this is on, you’ll see a little orange area at the top of the iPod nano and a lock icon on the iPod’s screen. If you see either of these, move the switch back and see if this fixes the problem.
  2. If the hold switch wasn’t the problem do the following:
  3. Move the hold switch to the on position and then move it back to off.
  4. Hold down the Menu button on the clickwheel and the center button at the same time. Hold these together for 6-10 seconds. This should restart the iPod nano. You’ll know the iPod is restarting when the screen changes and the Apple logo appears.
  5. If this doesn’t work at first, you should repeat step 4
Jul 06, 2009 | Apple iPod nano
My ipod tells me to go to apple.com/support/ipod
press the menu and the enter button at the same time it should reset the firmware and the ipod will turn on
worked for me
Jun 18, 2009 | BoxWave Corporation Apple iPod 4G (40GB)...
Ipod nano 4G
Reset iPod nano
(if your iPod nano isn’t
responding)
Set the Hold switch to Hold and turn it off again. Press the Menu
and Center buttons at the same time for about 6 seconds, until the
Apple logo appears.
May 22, 2008 | Apple iPod nano
Ipod
If your iPod nano won’t turn on or respond
1) Make sure the Hold switch is off.
2) If that doesn’t work, connect iPod nano to your computer’s USB or FireWire port. Your
iPod nano battery might need to be recharged.
3) If that doesn’t work, your iPod nano might need to be reset.
a) Toggle the Hold switch on and off (set it to Hold, and then turn it off again).
b)Press and hold the Center and Menu buttons for at least 6 seconds, until the Apple logo appears.
4) If that doesn’t work, you might need to restore iPod nano software.
Mar 12, 2008 | Apple iPod nano
Ipod nano 3rd gen.
First make sure your hold switch isn't on. It's on the top or bottom and slides back and forth. It needs to be switched to the left. Once it is to the left, here's how you reset:
You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
Dec 28, 2007 | Apple iPod nano
Apple iPod nano Logo
279 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
