Is the device still recognized by your PC? If not, you can try plugging into different USB ports to see if it is related to that otherwise it seems like the device may be defective.
Make sure you have the remote sensor plugged all the way into the connector on the card. Also check your taskbar for the "remote" icon which confirms you have "irblaster32.exe" installed.
okay after more reading I found I needed to hook up the A/V output on my camcorder to my line-in input on the capture card (WinTV-hvr-1600) and now audio is working!
Yes, but what it can connect to depends on what Dish DVR you have. The newer, HD ones only have HDMI, S-Video, and that 5-split coax as outputs for the main TV since you only get these box's if you have and HDTV.
This is because regular old coaxial is no longer good enough for them. This means you must connect the newer DVR's to the S-Video input on the Hauppauge1600 since it is the only input to the card the Dish DVR supports.
If your DVR is older and has the coax out, you can use that and connect it to the Hauppauge analog input.
I have a Hauppauge WinTV HVR-1600. I have a comcast digital box hooked up to my PC. Signal is bad and black and white media. I installed the "current" driver two weeks ago (mid October) Work great! We had to perform a PC recovery. I downloaded the "current" driver. Got weak signal and black and white only.
There may be an input selection between Composite and S-Video that needs to be toggled in your Hauppauge software.
Your Hauppauge card may also be in the wrong signal format mode (NTSC or PAL). Your source device and your Hauppauge card need to be in the same mode (both NTSC or both PAL) for the capture to work properly.
If your NV-VP33 is a SCART output, then you may need to check your SCART adapter and your device as not all devices output both S-Video (Y/C - two signals) and Composite (CVBS - one signal) type signals.
If your SCART adapter has both Composite and S-Video outputs, try the other one.
And finally... if you're playing an NTSC tape/DVD in a PAL player, it doesn't mean the output is true NTSC 3.58. Most times it's NTSC 4.43 which is OK for TVs, but NOT okay for video capture devices. Video capture devices need true NTSC 3.58 to sync the color carrier properly.
