Question about Quasar SP-3235 32" TV
Thomson 28WF25UG My tv will not come out of standby by remote or using the buttons on the tv itself.The power on light flashes amber a few times then turns red and flashes a few times then the red light stays on.It's the same when i turn my satellite box on/off also.This a uk model . Thanks
  • Bob909 Oct 31, 2008
    My Thomson 28WM100T also stays in standby mode as soon as it's plugged.
    The screen stays dead. No flashes nothing. if I press the program + button I hear a click and the red light blinks a bit and thats it. Nothing happens.
    Could it be the light bulb or a fuse? How do I replace these without being electrocuted. Thank you!
Are there any instuction, with illustrations to do what you just explained. I have no idea where the horizontal transistor is.
Posted on Oct 31, 2008
  • 70 Answers
The t.v is in protect mode.
what you will need to do is to first check that the horizontal transistor is not short circuited, if so you would need to check whether there are dry joints around the flyback transformer and the horizontal areas, next in line is to check for high b+ ususally disconnecting collector of hori transistor you get an accurate reading of b+. also check the vertical i.c. if all these are ok then the didtal plug in board is the culprit.
Posted on Jul 10, 2008
Proscan LED TV Will power up the red standby light & standby on amber when turned on but does not show picture or sound unless I unplug and replug over
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 14, 2016 | Proscan Televison & Video
When turning on tv. screen will display Bravia image & then go blank. red light flashes SIX times
Power off the television. Wait a few minutes, then power it back on. If this does not correct the issue leave the power on, point your remote control towards the Sony television and hold the down arrow button. While holding the down arrow button press the "Power" button. Release the down arrow button and the Sony TVicon1.png will reset itself to factory settings. Once the television performs a scan on itself your problem should be gone.
Good Luck Ed Pinero
Read more: How to Troubleshoot the Standby Indicator Flashing on a Sony TV ' eHow.com http://www.ehow.com/how_5925008_troubleshoot-indicator-flashing-sony-tv.html#ixzz2KBk1cWbu
Feb 02, 2013 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Kdl-46s2010 Turns itself off, standby light does not flash to show fault
This might be your main board on the tv. If the tv is still under warranty I would bring it back in for repair.
Apr 26, 2017 | Televison & Video
What does standby mean? my tv will not come on but the red standby light is on. How can i fix my tv.My tv is an sony 40" trinitron wega brand.
If standby red light is solid then press power or channel button on remote of tv itself to turn it ON.
And if red light is blinking/ flashing then it is an indication that tv got problem and tech visit is needed to sort out problem.
Thanks.
Apr 20, 2011 | Sony Televison & Video
STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
Jun 19, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
May 16, 2009 | LG Televison & Video
My thompson dtr box will not turn on now.it stays on an amber light and doesnt want to do anything else.1day it was fine,now its not.
Message taken from TopUpTV
Does your Thomson DTi6300 fail to power on normally and displays a solid amber light? During the past few days we have been made aware of an issue affecting a number of our customers with a Thomson DTi6300 box. Customers have been experiencing problems with their box failing to come out of standby mode and typically showing a constant amber light on the front panel.
This fault is due to a broadcast issue which  has led to a corrupt file being loaded onto the hard disk.
Only Thomson DTi6300 boxes have been affected. If you have been experiencing problems of this nature first of all try switching your box off at the wall and leave for twenty seconds. If this does not work, please try the following procedure.
Please note this will unfortunately cause recordings in your programme library to be lost which we?re very sorry about. You may have to try this procedure a few times in order to resolve the issue as it requires complete attention and precise timing.
1.       Disconnect the power supply from the unit by removing the power cable from the back of the box.
2.       Wait 20 seconds and then put the power cable back in while pressing the 'standby/power on' buttonrepeatedly on the front panel of the box.
3.       Release the standby button as soon as you see a light flash on the front of your box and thenimmediately press the arrow buttons on the front panel quickly and in the following sequence:  Up, Down, Left, Right (please note this is not the order the arrow buttons appear on the box).
4.       Your box should then show the amber light with the green light flashing until the disk re-format has been completed which will take around 60 seconds. The box should return to a solid red light (standby) automatically. If after 2 minutes your box still does not display a solid red light, please repeat steps 1-4.
5.       When you return to the TV GUIDE screen, you will now need to scan for channels to restore your Top Up TV channel logos. To do this, please select Option 4 (set-up) from the Main Menu, followed by option 1 (scan for channels).
6.       IMPORTANT: Once you have completed your channel scan, you will need to select option 5 from the Main Menu (Choose your channels) to re-select all those channel providers you would like Top Up TV to download shows from.
We?re really sorry if you have been affected by this issue and greatly regret any inconvenience this may have caused.
May 06, 2009 | Televison & Video
Thomson DTI6300-16, The amber light constantly flashes, no red or amber lights appear! any help/advise would be welcome
May 04, 2009 | Televison & Video
Top up tv+ digital tv stopped working.
i had same prob, tried unplugging three times
then unpluuged for 5mins
, plugged back in left it alone, ie didnt touch remote or front panel, until it settled down ~15mins, green light came on (doesn't normally)
and everthing seems ok now
May 03, 2009 | Televison & Video
Quasar SP-3235 32" TV Logo
121 people viewed this question
Top Quasar Televison & Video Experts
 Grubhead
Grubhead
jason
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
